slowshunter Posted December 28, 2017 Share Posted December 28, 2017 Hi, I'm trying to build a lay-out for my grandson. I've acquired several engines and coaches and also extra track. On a website a lay out which looked pretty good to me and a perfect size (6x4). But I can't find it now because I forget which website I found it. I need help in identifying the individual track pieces. I've used the Anyrail track planning software which I've found to be pretty good. But the plan does not identify the individual track pieces to make up the plan. The track plan I am using is titled Hornby_Track_Plan_2E_6x4.png - IrfanViewCan anybody help me by showing the plan and indicating the Hornby track pieces I need.Does anybody have any track plans which would fit a 6'x4' board? It's my intention to add buildings once I have the right lay-out.Cheers,Phil Link to comment Share on other sites More sharing options...
Tony57 Posted December 28, 2017 Share Posted December 28, 2017 HiCan you give a brief discription of the layout you are thinking about as I have a disk with 6 of the Hornbytrack plans as pdfs as well as hard copies so will be able to assist. the Disk has a number of 6x4 layouts from a single circuit to 3 circuits plus goods and engine shed sidings Tony Link to comment Share on other sites More sharing options...
Howbi Posted December 28, 2017 Share Posted December 28, 2017 You'll find a load of plans here....... http://www.freetrackplans.com/Home.php ................HB Link to comment Share on other sites More sharing options...
TrainDriverJ Posted December 28, 2017 Share Posted December 28, 2017 RDS set out the exact requirements for hornby’s 2E plan in 2015. Here is the link https://www.hornby.com/uk-en/forum/help-needed-8414/? Good luck! Link to comment Share on other sites More sharing options...
Chrissaf Posted December 28, 2017 Share Posted December 28, 2017 Although the link to RDS' previous post gives a list of probable track parts. I would still follow the link provided by Howbiman. The Hornby 2E track plan is downloadable from there (Downloads Tab), in Anyrail format - or just follow the link below for the "HornbyPlans.Zip" file. Once the "Plan 2E" is unzipped from the downloaded file, and loaded into Anyrail (that you say you have already got a copy of), it should give you an inventory of all the parts required and show where they go. You will need a forum Anyrail user (there are some on here) to advise how to access this parts information in Anyrail, if you get stuck..http://www.freetrackplans.com/Download.php Link to comment Share on other sites More sharing options...
slowshunter Posted December 30, 2017 Author Share Posted December 30, 2017 Tony 57 Hi, The layout I'm trying to create is 2 ovals, 1 inside the other with sidings of the inner oval to form a station of 3 platforms and if it fits another siding of either the top or bottom straight of the outer loop. I'm thinking of 3rd Radius double curves for the outer loop and 2nd Radius double curves for the inner loop. Thanks for any help you can give me.Cheers,Phil Link to comment Share on other sites More sharing options...
slowshunter Posted December 30, 2017 Author Share Posted December 30, 2017 Howbiman, Train Driver John and Chrissaf thank you for your help. I'll have a look at the items you've steered me to. Hopefully you guys and Tony 57 will bring an end to my headaches! I'm doing this for my grandson so I can hand the entire layout to him when he's old enough. As he's just 2 I reckon I have a few years of fun first!Cheers,Phil Link to comment Share on other sites More sharing options...
Tony57 Posted December 30, 2017 Share Posted December 30, 2017 Hi Slowshunter.Found another disk with 10 of the 11 track plan books Hornby have issued.Had a good look at them all, there are three which fitted your discription they are in Edition 2, plans 4 and 5 and in Edition 3, plan 4.I suggest you use links supplied by the others and have a look at the plans Link to comment Share on other sites More sharing options...
Fishmanoz Posted December 30, 2017 Share Posted December 30, 2017 Don’t have Anyrail open to check, and it may depend on the version you have but, confirming what Chris said that it most certainly does give you an inventory of track pieces. Memory says it’s likely to be under the File tab. Link to comment Share on other sites More sharing options...
Howbi Posted December 30, 2017 Share Posted December 30, 2017 In AnyRail under FILE tab click INFO then choose List of Materials.......HB Link to comment Share on other sites More sharing options...
slowshunter Posted January 2, 2018 Author Share Posted January 2, 2018 Big thank you to everybody here especially you chaps who have helped me specifically with this issue, Tony57, Howbiman, TraindriverJohn, Chrissaf and Fishmanoz. I had a lay-out up over Hogmanay with The Flying Scotsman, Virgin Pendolino, an old Class 26 like one of the engines my late dad used to drive up in Inverness and Thomas the Tank Engine with Aniie and Clarabelle. My grandson loved it. Up to now he's had Trackmaster stuff with battery operated Thomas so to see the "real thing" was wonderful. Link to comment Share on other sites More sharing options...
