Forum-1211528 Posted June 26, 2018 Share Posted June 26, 2018 I have a large layout that uses TRI-ANG super 4 track the power clip that connects the controller is a brown one very different to the Hornby black one but you connect a Hornby DCC controller to the Tri-ang poer clip connecting it to super 4 track that all works fine and i expect with super 3 track too so you can use that with dcc but forget Triang locos as all mine are staying dc!! Link to comment Share on other sites More sharing options...
Triumph Owner Posted June 26, 2018 Share Posted June 26, 2018 I presume this connector does not contain a capacitor. The modern ones do, which filter out the AC data signal, which is superimposed on the track DC signal. Paul Link to comment Share on other sites More sharing options...
Howbi Posted June 26, 2018 Share Posted June 26, 2018 You have a choice with power tracks, DCC or DC versions..........HB Link to comment Share on other sites More sharing options...
Fishmanoz Posted June 26, 2018 Share Posted June 26, 2018 Paul, just to clarify that for DCC there is no “track DC signal”. DCC is a square wave at over 10kHz with the data modulated onto it by varying the mark-space ratio. If you analyse this, the capacitor probably leaves the 10kHz largely intact but will certainly degrade the harmonics present in the square wave, and the higher frequencies in the modulated signal. Link to comment Share on other sites More sharing options...
Ruffnut Thorston Posted July 4, 2018 Share Posted July 4, 2018 The 'Standard' R.487 Tri-ang Super 4 power clip does contain a capacitor!It is under the raised section across the ends of the sockets for the connecting pins. I have modified a R.487 to use with DCC, by carefully removing the clip base, which is held on with three small eyelets (rivets).The capacitor can then be removed, and the base glued back in place... It is generally thought that a capacitor across the DCC conections is a Bad Idea.... In general, Tri-ang and Hornby Power clips were all fitted with capacitors. In fact, Tri-ang used to reccommend that, if interference was caused by a layout, extra power clips were fitted (with no wiring). This put more capacitors across the power feed.... There is a capacitor in the Series 3 Power Clip as well.Also a capacitor in the 'Standard Track' power connecting and uncoupling rail. (And the special suppressor straight track!) Most of the original plastic R.602 System 6 Power Clips do not have a capacitor fitted, whereas some China made versions DO have a capacitor fitted! Link to comment Share on other sites More sharing options...
