Shadow.Monk Posted September 28, 2018 Share Posted September 28, 2018 Is super glue safe for me to use on my locomotives? I would like to glue the vacuum pipes in so they are secure :) Cheers! Link to comment Share on other sites More sharing options...
DBfan Posted September 28, 2018 Share Posted September 28, 2018 Never use superglue try a dab of PVA glue. It will certainly hold the vacuum pipes in. Link to comment Share on other sites More sharing options...
walkingthedog Posted September 28, 2018 Share Posted September 28, 2018 I generally use a minute drop of super glue. Link to comment Share on other sites More sharing options...
atom3624 Posted September 28, 2018 Share Posted September 28, 2018 Will you need to remove them at any stage? Sometimes, it's a help to be able to remove the vacuum pipes on steam locomotive tenders if the lid has to come off for DCC chip access, etc. Failing that, I normally use Humbrol polystyrene cement, once I'm certain the 'fit' is right.If it's really tight, but will mount properly, you may want to mount without adhesive. Al. Link to comment Share on other sites More sharing options...
The son of Triangman Posted September 28, 2018 Share Posted September 28, 2018 If you plan to sell at a future date or may want to sell, then a drop of pva is best. Also buying a spare vac pipe sprue with pipes attached and putting that in the box as per new is a good idea. The loco will be worth more than a loco fitted with the pipes etc. Link to comment Share on other sites More sharing options...
walkingthedog Posted September 28, 2018 Share Posted September 28, 2018 Heljan sell most of their loco with factory fitted bits. Link to comment Share on other sites More sharing options...
WilliamDavid Posted September 28, 2018 Share Posted September 28, 2018 I now use the gel type superglue.A small blob applied with a cocktail stick.Very controllable . Link to comment Share on other sites More sharing options...
walkingthedog Posted September 28, 2018 Share Posted September 28, 2018 Me too William. Wouldn’t recommend a cocktail stick, you might get a splinter 😆 😆 Link to comment Share on other sites More sharing options...
Shadow.Monk Posted September 28, 2018 Author Share Posted September 28, 2018 Took the risk, everything went according to plan! :) Link to comment Share on other sites More sharing options...
Fishmanoz Posted September 28, 2018 Share Posted September 28, 2018 Easy to avoid splinters from cocktail sticks WTD, leave the sausage attached and handle from that end. Link to comment Share on other sites More sharing options...
NWR-Gordon-4 Posted September 29, 2018 Share Posted September 29, 2018 I use the tinest bit of super glue too, for vaccim pipes. They need a glue, as they don’t stay in the slot on the bufferbeam sadly, without glue. GNR-Gordon-4 Link to comment Share on other sites More sharing options...
Shadow.Monk Posted September 29, 2018 Author Share Posted September 29, 2018 It was these guys who needed them gluing in :) Glad all is well now :D/media/tinymce_upload/11c953f9b3d3ae5f6133ad3e40c4f9f8.jpg Link to comment Share on other sites More sharing options...
NWR-Gordon-4 Posted October 1, 2018 Share Posted October 1, 2018 Great photo, Shadow.Monk. 😀 GNR-Gordon-4 Link to comment Share on other sites More sharing options...
