Jeffrey Y Posted November 10, 2018 Share Posted November 10, 2018 Hello, this may sound slightly mad, but I see one can move the position of the magnet within the chassis, what woukd happen if a magnet was placed in each position? Any benefit or a silly idea. Thoughts appreciated Many thanks Jeffrey Y Link to comment Share on other sites More sharing options...
gorp Posted November 10, 2018 Share Posted November 10, 2018 too much magnet can leave you stuck to the trackhowever in the past many have used multiple magnets when racingonly if you try will you find out if you like it better Link to comment Share on other sites More sharing options...
Jeffrey Y Posted November 11, 2018 Author Share Posted November 11, 2018 Many thanks, I'll try it to see, good to know it can be done, - thanks, Jeffrey Y Link to comment Share on other sites More sharing options...
Andy P. Posted November 11, 2018 Share Posted November 11, 2018 Heavy magnet attraction can also cause the motor to overheat.Before you use magnets to keep the cars on the track you should clean the track, true and sand the tires and use some form of sticky tape like packing or duct/gaffer tape to clean them.Google sanding or truing slot car tires and you will see a ton of how to videos online. Link to comment Share on other sites More sharing options...
gorp Posted November 11, 2018 Share Posted November 11, 2018 Have never lost a can due to magnets.Now use less or none like way back in the dark ages. But this discussion only applies to analog only.Advise never using more magnet than stock when running digital. Link to comment Share on other sites More sharing options...
MashaFX Posted November 18, 2018 Share Posted November 18, 2018 We can always add more magnets. We can even get stronger magnets for the same slot. However, I wouldn't recomend it. We do all need to go down that path and try it but cars stuck to the track are no fun, no power slides. I'd add borders before magnets. Full throttle all they way round, no need to slow down, it ruins the dexterity of the game. Cars with well maintained tyres will corner extremely fast. If your cars aint sticking well, check the tyres, true them. Cars with greater magnetraction are slower. You won't get as fast acceleration on the straights. Link to comment Share on other sites More sharing options...
Sexycal Posted March 31, 2019 Share Posted March 31, 2019 So I bought a couple of magnets gold plated were only $ 11from lakota, so I'm an idiot because they said I could stack them. But it sounds like I was misinformed. Live and learn. Link to comment Share on other sites More sharing options...
