clubman Posted November 19, 2018 Share Posted November 19, 2018 FUNCTION 10 (COMPRESSOR) ON MY HORNBY R 3392 TTS CLASS 40 LOCO DOES NOT WORK , ALL OTHER FUNCTIONS ARE OKAY,HAS ANYONE HAD THIS PROBLEM AND SOLVED IT? Link to comment Share on other sites More sharing options...
Chrissaf Posted November 19, 2018 Share Posted November 19, 2018 Clubman, please do try an avoid writing in ALL capitals. In forum terms, this is considered shouting. Not only that, but when a post is a lot longer than yours above and ALL capitals, it does make it a little harder to read..It is a fallacy to think that a post written in capitals will be given more attention by forum contributors. They are all responded to on the merit of the question asked or issue raised. Link to comment Share on other sites More sharing options...
Rog RJ Posted November 19, 2018 Share Posted November 19, 2018 I usually ignore posts in all caps. PS. It's considered to be shouting on virtually all forums, not just the Hornby forums. Link to comment Share on other sites More sharing options...
walkingthedog Posted November 19, 2018 Share Posted November 19, 2018 OK but can’t somebody answer his question? Link to comment Share on other sites More sharing options...
Howbi Posted November 19, 2018 Share Posted November 19, 2018 Clubman, which controller are you using?...........HB Link to comment Share on other sites More sharing options...
Chrissaf Posted November 19, 2018 Share Posted November 19, 2018 I think I know where you are going with that question HB..More importantly, if your controller is the Hornby Select, as I think HB suspects, then what software revision is it (the first number to be displayed on screen during the power up sequence). Link to comment Share on other sites More sharing options...
WilliamDavid Posted November 19, 2018 Share Posted November 19, 2018 Two things come to mind.Is the CV for that function reading 0?Are you using the Elite? If so, is the function button working? Link to comment Share on other sites More sharing options...
96RAF Posted November 20, 2018 Share Posted November 20, 2018 Function 10 on the Elite is selected via the second Function screen (F10-19) and then the zero button.If Select then firmware likely to be OK as OP says all other functions are working.Rob Link to comment Share on other sites More sharing options...
clubman Posted November 20, 2018 Author Share Posted November 20, 2018 my apologise for using upper case as a newbie i was unaware that only lower case should be used .however suggestions from the forum has solved the problem.cv166 which controls the compressor sound was set to 0,by changing to 4 all is well .i use select on my layout and rail master with a programming track for settings. i did have problems with 0 on the select not working but hornby put it right.thanks for the help Link to comment Share on other sites More sharing options...
