Stowmarket66 Posted April 20, 2019 Share Posted April 20, 2019 Hi Folks,I purchased a brand new 37 TTS sound chip a few weeks ago and everything was fine. Fitted to my Bachmann 37 and it worked "straight out of the box" so to speak.I went to play trains (!) the other evening and although the sound worked fine, the loco jumped along the track as if it was being given pulses of power about every half second.Any suggestions please as I'm fairly new to DCC and especially DCC sound.My layout is a straight piece of track, no points, nothing I can think of that I've done wrong.Thanks Link to comment Share on other sites More sharing options...
Howbi Posted April 20, 2019 Share Posted April 20, 2019 Hi Stowmarket66, welcome to the Forum..........if you have a controller capable of changing CVs such as the Elite or Railmaster you should try writing a value of 1 to CV150...........this has proven to cure most slow running problems..........HB Link to comment Share on other sites More sharing options...
2e0dtoeric Posted April 21, 2019 Share Posted April 21, 2019 Clean the track, wheels, and pick-ups. - - and not with a piece of sandpaper or a metalworker's file!How have you got the controller (which one is it?) connected to the track - using those silly flimsy track clips, or a proper soldered connection? Those clips are ok for dc operation, but the connection can be a bit slack for DCC use, giving rise to all kinds of anomalies.Also check it IS a DC connector, if you must use one, not an analogue one. The conversion is easy - just cut out the little capactor under the cover! Link to comment Share on other sites More sharing options...
walkingthedog Posted April 21, 2019 Share Posted April 21, 2019 Eric meant check it is a DCC connector not DC. Link to comment Share on other sites More sharing options...
Fishmanoz Posted April 21, 2019 Share Posted April 21, 2019 Eric also meant that if it is a DC connector, it is easily converted by flipping open the cover and removing the capacitor inside. Eirc also forgot to add the best track cleaner is IPA and a soft cloth. A track rubber can be used infrequently on stubborn dirt. But the more likely solution will be HB’s change to CV150, documented many times here to cure jerky slow running. Link to comment Share on other sites More sharing options...
RDS Posted April 22, 2019 Share Posted April 22, 2019 I recently had a problem with a new Bachmann Steam Loco where it just lurched forward after attempting a slow start or when stopping. .I was using a Decoder that had worked prefectly in another Bachmann Class 47. I received some excellent advice from Bachmann Technical that it was likely caused by the back EMF setting. They recommended that I changed CV54 to a value of 5 and CV55 to a value of 60. This cured it perfectly. Your problem may be completely different of course but it is likely that a change is required to one of the CV's. Link to comment Share on other sites More sharing options...
Fishmanoz Posted April 22, 2019 Share Posted April 22, 2019 Bachmann locos and decoders needing those BEMF CVs adjusted has been noted here before. I seem to remember there is something on the Bachman site documenting it too. Certainly not applicable to TTS as it doesn’t support those CVs. Link to comment Share on other sites More sharing options...
96RAF Posted April 23, 2019 Share Posted April 23, 2019 Bachmann locos and decoders needing those BEMF CVs adjusted has been noted here before. I seem to remember there is something on the Bachman site documenting it too. Certainly not applicable to TTS as it doesn’t support those CVs. TTS equivalent is adjusting motor P and I values as applicable to each motor algorythm CV150. Hence adjust CVs 151/152 or CVs 153/154. Link to comment Share on other sites More sharing options...
Fishmanoz Posted April 23, 2019 Share Posted April 23, 2019 And to stop you fiddling around in the dark adjusting those CVs (not just 150), there is a very good “How To” somewhere on here. I would expect someone to give you a link to it soon. Link to comment Share on other sites More sharing options...
TerryR Posted April 30, 2019 Share Posted April 30, 2019 Well done on finding a class 37 TTS decoder, those things seem like gold dust at the moment! Link to comment Share on other sites More sharing options...
