St1ngr4y Posted January 4, 2020 Share Posted January 4, 2020 Having tried various combinations of the INI parameters concerning controller communications on my system which uses an Elite as Controller A and an eLink as Controller B, I have the following observations to make based on the contents of the RM LOG.TXT file after each session. a) If the Controller A is an Elite, the software generates an extra Check Controller=0 during startup, overriding whatever value the user has set in the INI file. It doesn't actually create a new entry in the INI file, but it does record a line in the log file. I would guess that the reason for this is that, according to the RM Guide, "Check controller=0 1=check for the presence of eLink controller every 5 secs. 0 turns this off". In other words, a value of 1 for this parameter is only applicable if Controller A is an eLink, and it may have a detrimental effect if a value of 1 is used for an Elite as Controller A, so it forces a zero value to be used if the Controller is an Elite. b) The initialisation log messages for each controller are different depending on the value of Alternative comms i.e. the way the controllers are initialised is different depending on whether 0 or 1 is used as the parameter. HOWEVER, RM seems to be using the value of Alternative comms=n for both Controllers A and B, i.e. the value of Alternative comms2=n is being ignored completely. Perhaps HRMS can confirm my findings ? Ray Link to comment Share on other sites More sharing options...
St1ngr4y Posted January 4, 2020 Share Posted January 4, 2020 Further to my previous post, if Controller A is an eLink and Controller B is an Elite, there is a circumstance where an extra line is generated "Check Controller=1". Now my head hurts... I'm going back to my original setup which still works fine. Ray Link to comment Share on other sites More sharing options...
BagEndJct Posted January 8, 2020 Share Posted January 8, 2020 I had a popup this morning asking if I wanted to see the News.Part of which was this Multi aspect signals from the likes of Train-Tech are now fully supported with clever interlocking facilities. Control two, three and four aspect signals, including flashing main line signals and even direction feathers. You can also control an entire array of signals by just pressing one signal and of course full signals control is available within programs that you create. You can even now switch points and run programs as a result of touching a single signal.Can any T-T signal users please confirm if this is so, in particular the direction feathers and single signal control. It does not mention sensor signals, only what I presume are the original digital signals. Rob. I was very interested to read this. I use a number of TT signals, some with direction feathers, and if these now work properly within RM I will be a very happy bunny. Are you aware of any documentation on this? My layout is out of action at the moment for a Spring Clean so I cannot test this. I have dismantled everything and first need to clean the track. However, weather is cool and damp as is my enthusiasm to get going on this at the moment! As soon as we're up and running again, I'll test what I can and report back! Link to comment Share on other sites More sharing options...
96RAF Posted January 9, 2020 Share Posted January 9, 2020 BEJAll I can find is that the signals are present in the various drop down menus and setup boxes. The words came from the ‘whats new‘ inclusion with the update.I didn't trawl the manual page by page yet due to being busy on other things. Link to comment Share on other sites More sharing options...
tony_forward Posted January 12, 2020 Share Posted January 12, 2020 update 1.72? it says at the top of the forum that latest version is 1.71 ? RailMaster Current Version: v1.71 release 0 - Updated 09-07-19 Link to comment Share on other sites More sharing options...
Chrissaf Posted January 12, 2020 Share Posted January 12, 2020 Tony,The reason that explains your comment is documented in this thread:https://www.hornby.com/uk-en/forum/forum-administration-update-30025/?p=1.Ignore what the text says, the link will always download the current latest version.....whatever that it is at that time. Link to comment Share on other sites More sharing options...
96RAF Posted January 12, 2020 Share Posted January 12, 2020 I have requested that the red link text be changed to say ‘...Latest version of RM download, or similar...’ as it would be self explanatory and would self manage, but to no avail. Link to comment Share on other sites More sharing options...
St1ngr4y Posted January 14, 2020 Share Posted January 14, 2020 BEJAll I can find is that the signals are present in the various drop down menus and setup boxes. The words came from the ‘whats new‘ inclusion with the update.I didn't trawl the manual page by page yet due to being busy on other things. Hi Rob & BEJ, I've just been having a look at the configuration of TrainTech signals in 1.72. On page 84 of the latest User Guide, it gives an example of a 4-aspect signal with flashing lights, and it states that 4 consecutive decoder addresses are used to achieve this./media/tinymce_upload/c8e0a01ccb0329e731851e708667cb1d.pngI tried this exact configuration, but I didn't see the same "sequence" as displayed in the guide.../media/tinymce_upload/86530e8df2fd766fbb19334cba0b9db7.png On my layout, I have a 2-aspect Home with l/h feather and a 4-aspect with l/h feather, but when I tried to re-configure these using 1.72, the extra address needed for the feather was just not present in the sequence. Another general point - this sequence defines the order of display aspects which will be shown on the signal each time the icon on the layout diagram is clicked. So to take the most extreme example of a 4-aspect signal with a feather and flashing capability. I would guess that such a signal would require 4 addresses, as followsBase address red / greenBase address+1 single yellow / double yellowBase Address+2 feather on / offBase Address+3 flashing on/off How can anyone possibly construct a sequence of (address & on/off) commands to cater for all of the possible combinations for such a signal? For example, if the signal is currently at Red and you want to switch it to double yellow flashing with feather on. Each click might lead to the following sequence of commands...single yellowdouble yellowgreensingle yellow feather ondouble yellow feather ongreen feather onsingle yellow feather on flashingdouble yellow feather on flashing A total of 8 clicks on the icon to step through to the required aspect. It seems crazy to me. IMO a better solution would be to have, for example, the feather as a separate icon which could snap into position to a colour light signal at design time, rather like the red/green buttons snap into position on a point. The feather would then be configurable in terms of allocating its address, and operationally could be clicked independently of the signal to change only the feather aspect. Ray Link to comment Share on other sites More sharing options...
St1ngr4y Posted January 15, 2020 Share Posted January 15, 2020 The last post seems to have originated on Jan 1 but has just been approved. Do we have a new "Adam"? Ray Link to comment Share on other sites More sharing options...
Scumcat 01 Posted January 15, 2020 Share Posted January 15, 2020 Is this update safe to download yet? I've been putting it off because at the moment my system is running quite well. New updates tend to mess everything up:) Link to comment Share on other sites More sharing options...
RB51 Posted January 15, 2020 Share Posted January 15, 2020 Do we have a new "Adam"? Looks as though someone has found the right buttons. Not aware of a new "Adam". R- Link to comment Share on other sites More sharing options...
Chrissaf Posted January 15, 2020 Share Posted January 15, 2020 The last post seems to have originated on Jan 1 but has just been approved. Do we have a new "Adam"?.No not yet.....the ComMods escalated the issue to SK........it appears he (SK) has tasked a senior manager (a name I can't reveal) to action the issue. This manager has put in place a temporary admin solution pending a final solution. Hence why there has been a flurry of image approvals today....it transpired that after Adam left, no one in Hornby was monitoring the forum mail inbox in his stead. Link to comment Share on other sites More sharing options...
phil_symonds Posted January 29, 2020 Share Posted January 29, 2020 The update to v1.72 caused my Railaster to stop working but the solution was simple for me.Un registerUn-install railmaster.Download the lastest version.Install from the lastest version rather than updating.Re register.Hope that works for you, it did for me. Link to comment Share on other sites More sharing options...
96RAF Posted January 30, 2020 Share Posted January 30, 2020 Sounds like my printer software - their recommended immediate action for any problem is a reinstall. This should never be necessary as RM installs all updates over the existing installtion. Link to comment Share on other sites More sharing options...
Fishmanoz Posted February 1, 2020 Share Posted February 1, 2020 As Rob says, that uninstall process was likely almost completely unnecessary given installing the latest update over the top achieves exactly the same result. But with one exception - an update does not change the Railmaster.ini file, a new install creates a new one. Given your setup was all wired up and operating when the install was done, RM should have created the right details in the ini file and obviously has. You could have achieved this far more simply in one of two ways: - Follow one of the multiple sets of instructions, usually from Chris on how to edit it to the correct contents for the latest update, or - Just renamed (or deleted but not recommended) the existing version then re-installed the latest update, and that would have created exactly the same new ini file that your whole rigmarole produced. There's nothing particularly wrong with what you did, as long as you backed up all of your track plans, programs and loco roster first so you don't lose them, it's just not necessary. Link to comment Share on other sites More sharing options...
cowside Posted April 3, 2020 Share Posted April 3, 2020 I run v1.65 with ProPack and it works fine, even for Voice Control on a Windows 7 PC. Loco details not in 1.65 are easily added. Given the hassles that always come with an upgrade,is it worth upgrading to v1.72 or later? What is the gain? Link to comment Share on other sites More sharing options...
Chrissaf Posted April 3, 2020 Share Posted April 3, 2020 What is the gain?.For you....probably none.....if it ain't broke.....don't fix it....but it does mean a lot of extra hassle to keep preventing RM from auto updating ......I assume that you keep your RM PC disconnected from the Internet. Not an issue so much for you these days as Windows 7 is now unsupported and no new Win 7 updates are being provided by M.S..I seem to recall that version 1.65 was one of the most stable RM releases to date so far. But there again, my memory may be corrupted just like so many other RM releases.. Link to comment Share on other sites More sharing options...
96RAF Posted April 3, 2020 Share Posted April 3, 2020 If you manually download the latest update but don’t install it you can look in the release notes and review each update since v1.65 to assess whether it is worth updating to take advantage of any listed benefits. Link to comment Share on other sites More sharing options...
cowside Posted April 4, 2020 Share Posted April 4, 2020 Thanks to you both. Having seen too many buggy software 'upgrades' I'm going to stick with v1.65. It's bad enough now without self-inflicting more pain sorting out unnecessary issues! Link to comment Share on other sites More sharing options...
