Potterton Posted September 17, 2021 Share Posted September 17, 2021 Just a general enquiry and please forgive my ignorance of all things DCC.I'm interested in purchasing a second hand loco which is DCC fitted and described as "will not run on DC." If I were to purchase this loco would it run if I simply removed the decoder or would it have to have a blanking plate refitted? Link to comment Share on other sites More sharing options...
Going Spare Posted September 17, 2021 Share Posted September 17, 2021 That depends upon how the decoder has been connected. If a socket was available, a blanking plate will be needed, or removal of the socket as well and restoring the wiring providing a direct connection between pick-ups and motor. If a socket was not pre-fitted or introduced and the decoder was hard-wired, the pick-ups-to-motor wiring will need reconnecting when the decoder is removed. Link to comment Share on other sites More sharing options...
96RAF Posted September 17, 2021 Share Posted September 17, 2021 It will run on DC if you have access to a DCC controller to change CV29 to re-enable DC running. Some decoders default this to off. Link to comment Share on other sites More sharing options...
Fishmanoz Posted September 18, 2021 Share Posted September 18, 2021 Putting Rob’s another way, DCC fitted locos will run on DC unless DC Running has been disabled in the decoder in CV29. So there is no need to remove the decoder if you can find someone with a DCC controller to turn DC Running back on. Link to comment Share on other sites More sharing options...
ColinB Posted September 18, 2021 Share Posted September 18, 2021 Although if you change CV29 to a 1, the loco will run on DC, I have found that it doesn't run quite as well as if it didn't have a DCC decoder fitted. I did a test with one of my locos by running it with and without a Hattons decoder. With the decoder fitted it needed a higher DC voltage to get it moving. It could be something to do with the PWM out of my Hornby controller but I don't have a true DC source to test any further. Link to comment Share on other sites More sharing options...
Howbi Posted September 18, 2021 Share Posted September 18, 2021 That is incorrect, a value of 1 only changes direction. New decoders usually have CV29 set to 6.......2 for 128 speed steps plus 4 for DC running.......HB Link to comment Share on other sites More sharing options...
Potterton Posted September 19, 2021 Author Share Posted September 19, 2021 Thank you for the replies chaps. Where can obtain blanking plates? I am aware that I would need specific ones for specific locos and that there is no "one size fits all." Link to comment Share on other sites More sharing options...
Howbi Posted September 19, 2021 Share Posted September 19, 2021 This is one solution using copper speaker cable. Join pins 1 & 8 and pins 4 & 5 Link to comment Share on other sites More sharing options...
96RAF Posted September 19, 2021 Share Posted September 19, 2021 @colinThe reason it takes more throttle to get a decoder equipped loco going on Dc is because the decoder requires a certain voltage to boot and recognise that it is seeing DC not DCC hence the lag.@pottHowards shorting link will work fine as long as you don’t have need/lights. Link to comment Share on other sites More sharing options...
Potterton Posted September 20, 2021 Author Share Posted September 20, 2021 @Howbi and 96RAFThanks very much gentlemen. That is really useful.Would the joining of No.1 pin to No.8 and No.4 to No.5 apply regardless of the number of pins a socket may have? (Please forgive my ignorance.) Link to comment Share on other sites More sharing options...
96RAF Posted September 20, 2021 Share Posted September 20, 2021 That only works for the 8-pin socket.You need to pull the NEM spec for the 4, 6, 18, 21 pin sockets and see which pins to short for basic motor control and/or added lighting for them. Easily found by Google. Link to comment Share on other sites More sharing options...
Rog RJ Posted September 20, 2021 Share Posted September 20, 2021 @Howbi and 96RAFThanks very much gentlemen. That is really useful.Would the joining of No.1 pin to No.8 and No.4 to No.5 apply regardless of the number of pins a socket may have? (Please forgive my ignorance.) It only applies to 8 pin sockets and decoders. Different sockets need different numbered pins to be connected together. Link to comment Share on other sites More sharing options...
ModelerXYZ Posted September 20, 2021 Share Posted September 20, 2021 To unconvert a loco, chop off the decoder, and solder the Red wire to the orange, and the black wire to the grey wire. This will remove the decoder and the wires will be connected in the right place. Or solder a wire from the pickups each side to the respective side of the motor. Check where to solder first.I converted and unconverted Thomas the tank engine once. XYZ Link to comment Share on other sites More sharing options...
Potterton Posted October 1, 2021 Author Share Posted October 1, 2021 Thanks. Do the colours referred to apply to all decoders regardless of manufacturer? Link to comment Share on other sites More sharing options...
ModelerXYZ Posted October 1, 2021 Share Posted October 1, 2021 They should- Its a DCC standard set by the National Model Railway Association. Link to comment Share on other sites More sharing options...
Fishmanoz Posted October 2, 2021 Share Posted October 2, 2021 It would be much neater if you first unsoldered the decoder, then connected the pickup wires from each side to the motor connection on the same side, rather than joining the ends of the decoder wires to each other. The only difference is leaving those decoder wire ends out to make for a better job. Link to comment Share on other sites More sharing options...
Potterton Posted October 17, 2021 Author Share Posted October 17, 2021 Thanks for all the replies and advice. Link to comment Share on other sites More sharing options...
