Porkster Posted November 4, 2021 Share Posted November 4, 2021 Can anyone advise me on whether I can join a code 83 crossover to my code 100 Hornby track. Link to comment Share on other sites More sharing options...
Chrissaf Posted November 4, 2021 Share Posted November 4, 2021 Atlas make Code 83 to Code 100 transition joiners. How suitable these are for Hornby and/or Peco track I couldn't say. But the low cost of the transition joiners puts the 'trial n error' concept into affordable to try territory.https://www.modeltrainstuff.com/atlas-ho-551-code-83-to-code-100-transition-joiners-12/I assume that you are refering to a Peco Code 83 diamond crossover track piece. Don't forget that Peco Code 83 track geometry is completely different to Hornby. Therefore you may have more layout design geometry issues to resolve than just connecting track together. Link to comment Share on other sites More sharing options...
Going Spare Posted November 4, 2021 Share Posted November 4, 2021 There will be a 'step' where the lower code 83 rail meets the taller code 100 rail. Peco suggest SL110 (code 75 & 83) rail joiners rather than SL10 (code 100). Link to comment Share on other sites More sharing options...
Going Spare Posted November 5, 2021 Share Posted November 5, 2021 I am still unable to edit posts so was unable to acknowledge Chrissaf's more comprehensive reply.Also, while unable to compare the two track systems in detail (code 75/100 for UK/European) and code 83 which I believe was introduced for modellers with American-themed layouts, I think there will be a difference between the appearance of the code 83 track unit adjacent to code 100 trackage - sleeper spacing and size. Link to comment Share on other sites More sharing options...
RDS Posted November 5, 2021 Share Posted November 5, 2021 @Going SpareAt the top right hand corner of your post, you should have 3 vertical black dots. Left Clicking on those (assuming you use a PC with a mouse) brings up a number of options, one of which is Edit.If you use an Android device, you just touch the 3 dots to bring up the options, which may be the same if you have an ipad or other Apple device.However, you do not need to Edit to acknowledge another post. Just raise a new post. Link to comment Share on other sites More sharing options...
Brew Man Posted November 5, 2021 Share Posted November 5, 2021 @RDSFor a PC with mouse it is 'Left Click' not right. Don't want to confuse GS further grinningRDS Moderator Edit - Of course, Mistake edited, Thanks Link to comment Share on other sites More sharing options...
Chrissaf Posted November 5, 2021 Share Posted November 5, 2021 On an Android tablet (touchscreen) it is a basic screen press click. This is equivalent to a Win PC left mouse click. Link to comment Share on other sites More sharing options...
96RAF Posted November 5, 2021 Share Posted November 5, 2021 @RDSFor a PC with mouse it is 'Left Click' not right. Don't want to confuse GS further grinning One of my Win10 PCs will not react to a left click on Edit. I have to double click but this doesn’t always ‘catch’. I will try right click instead. Edge browser.iPad is simple press on the menu item. Safari browser. Link to comment Share on other sites More sharing options...
Brew Man Posted November 5, 2021 Share Posted November 5, 2021 If I right click the three dots I get the usual Windows menu - Cut, Copy, Paste etc. Link to comment Share on other sites More sharing options...
Going Spare Posted November 5, 2021 Share Posted November 5, 2021 Thank you for all your help, gentlemen. Just to call me a liar, I have just tried to edit my last post - I am using Google Chrome through Windows 10 on a laptop. The first couple of attempts failed: as usual, having reached 'edit' by left-clicking on the three dots, left-clicking on 'edit' produced nothing. I then tried right-clicking on 'edit' after left-clicking, which did not achieve anything, so I left-clicked again, which produced the edit screen! Perhaps this was interpreted by the laptop as a double-click as Rob mentioned, so I will persevere!Noting RDS's comment about starting a new post, I feel there are already too many unnecessary posts clogging-up the threads and prefer to add a simple edit where appropriate.To Brew Man: thank you. Confusion reigns all too easily!Edit: Success. I don't know why, but the system now works. Thanks once again. Now back to the original subject matter of the thread. Link to comment Share on other sites More sharing options...
Brew Man Posted November 5, 2021 Share Posted November 5, 2021 To Brew Man: thank you. Confusion reigns all too easily! You're not alone there, mate! joy Link to comment Share on other sites More sharing options...
Porkster Posted November 5, 2021 Author Share Posted November 5, 2021 Thanks for all the comments. I am building my second large layout using code 100 Hornby track. I was considering installing a Walthers code 83 #6 double crossover. The simplicity of installation appealed to me, however the complication of conversion from 100 to 83 and back probably negates any other advantages. Link to comment Share on other sites More sharing options...
Porkster Posted November 5, 2021 Author Share Posted November 5, 2021 I notice Peco have a Streamline SL-90 100 Double Slip. Is this the same thing? Link to comment Share on other sites More sharing options...
Going Spare Posted November 5, 2021 Share Posted November 5, 2021 The rail used in the SL-90 is the same as Hornby's but Chrissaf's warning regarding track geometry still applies. Peco Streamline (SL products) is a different beast to Hornby's and Peco's Setrack (ST products) trackage. Link to comment Share on other sites More sharing options...
ColinB Posted November 8, 2021 Share Posted November 8, 2021 I have a Peco double slip on my layout, in fact I have two. I bought them because the Peco crossover has too much plastic in the "frog" area which is probably why you want to use code 83 track because I assume that crossover has less plastic. I thought the double slip would act as a cross over but it doesn't seem to on my layout, if only seems to work on one route. I can understand Hornby having a lot of plastic in their "frog" area on crossovers but why Peco have the same defeats me. Interestingly on their code 75 track the crossover is much better designed, why they couldn't move that same design back to code 100 track. I suppose they assume that code 75 is the future. Link to comment Share on other sites More sharing options...
naugytrax Posted November 11, 2021 Share Posted November 11, 2021 But the "double crossover" in Code 83, listed in the Walthers catalog, is a completely different beast from a "double slip" by Peco or anyone else. The double crossover is a pair of single crossovers between parallel tracks, one left-handed and the other right-handed, superimposed with a diamond crossing in the middle. See https://www.walthers.com/code-83-nickel-silver-track-6-turnout-double-crossoverIt's not equivalent at all.BTW, if ordering from Walthers, they carry the Atlas Code 83-to-100 transition rail joiners. It's not clear whether these compensate for the difference in rail height. Link to comment Share on other sites More sharing options...
