Seacommander Posted November 20, 2021 Share Posted November 20, 2021 I would be grateful if somebody could point me in the right direction to find a supplier of a panel mounted power input socket and matching plug of the dimensions for the Elite/Select units.If my measurements are correct the pin is 3mm diameter and the outer diameter of the plug is 6.5mm and about 10mm long. They seem to be as rare if not rarer than the proverbial hen's teeth. Link to comment Share on other sites More sharing options...
96RAF Posted November 20, 2021 Share Posted November 20, 2021 Correctish - the jack plug is widely available as 6.3 x 3.0 but I have only ever found one panel mount socket and that had a single order surcharge making it uneconomic to order from America. I robbed a pcb mount socket from a dead eLink.Edit - the UK initial supplier was either Digikeys or Mouser but having just spent some time struggling with slow site response I gave up. The product was to be supplied from America though. Link to comment Share on other sites More sharing options...
Chrissaf Posted November 20, 2021 Share Posted November 20, 2021 As Rob says, the correct size is 6.3mm x 3.0mm. Again as Rob says, the plugs are readily available if you search eBay using the 6.3 x 3.0 DC Plug term. The matching socket is a genuine example of 'hens teeth'. Why they should be unavailable, even from China, is a complete mystery.Note that 6.3mm x 3.1mm plugs are also compatible with Hornby 6.3mm x 3.0mm controller sockets. Link to comment Share on other sites More sharing options...
Brew Man Posted November 21, 2021 Share Posted November 21, 2021 I'm guessing the sockets are available in China, but I can't find any either. I found a number with a 6.3mm barrel size but nothing more than 2.5mm pin. Link to comment Share on other sites More sharing options...
96RAF Posted November 21, 2021 Share Posted November 21, 2021 I bought one of these to make a cat-o-nine-tails power splitter, but while the plug end fits Hornby HM6K modules and controllers the Hornby PSU does not fit the socket end.https://www.acadaptorsrus.co.uk/white-5m-long-extension-cable-lead-cord-6-3-3-0-dc-6-3mm-x-3-0mm/This is the best I can do for plugs and sockets but note the charge per order from America despite being ordered from UK. I do not guarantee these match each other nor if they are compatible with Hornby plugs and sockets.Sockethttps://uk.farnell.com/mcm/27-5870/gender-jack/dp/2804458?ICID=I-RP-STM7REC-1Plughttps://uk.farnell.com/mcm/27-860/6-3mm-x-3-0mm-barrel-plug/dp/2784339?ICID=I-RP-STM7REC-2 Link to comment Share on other sites More sharing options...
Brew Man Posted November 21, 2021 Share Posted November 21, 2021 I found the plugs on Aliexpress, £5.22 for 10 plus £3.08 delivery, but no sign of matching sockets. Link to comment Share on other sites More sharing options...
Seacommander Posted November 21, 2021 Author Share Posted November 21, 2021 Thank you all very much for confirming the correct dimensions and suggesting suitable suppliers - much appreciated. Link to comment Share on other sites More sharing options...
