Fitting DCC clip to Hornby track
Lynrob
Good afternoon I have purchased two Hornby accessory decoders to ooerate the five turnouts I have on the layout and am having trouble fitting the DCC power from track clip to Hornby rails without cutting the black plastic sleepers, any one fitted one of these. On the website it said fit into the two slots on rails, there aren't any slots in the Hornby rails I have, would appreciate any help anyone can give Regards Robin
I don't think Hornby points have the slots, but as far as I know all but the very shortest standard curves and straights do.
If you look at the R600 standard length (168mm long) straight track R600, then the slots are about 2" (50mm) from each end (measured against the plastic 'sleeper' base).
You have to look at the track side on to actually see them though, as the slots are between the metal of the rails and a narrower section of the plastic base (between pairs of sleepers)
As an aside you don't have to wire back to the rails using those connectors, you can connect to your DCC bus (if you have one), or back to the controller itself (by splitting the output from the controller
Thank you all very much I was looking at R603 rails and couldn't work it out. Have a R600 track and found tge slots, easy when you know how pitty it's not explained in the instructions on line. Never mind problem solved thanks everyone Regards Robin
@Robin
Moderator Note:
It is in your own interest to have a unique user name.
Could you please select ‘My Account’ towards the top right hand corner of your screen, then Community and choose a nickname in the ‘My Profile' tab, rather than your First name that has been automatically allocated by the system. We had hoped a Forum change was coming to prevent this automatic allocation but a manual change is required at the moment and there will be more than one member with your name. This request together with some other information for new posters is contained in a thread at the top of the General Discussion section called ‘Information for new members registering for the Forum’
