Weymatt Posted February 21, 2023 Share Posted February 21, 2023 Link to comment Share on other sites More sharing options...
Weymatt Posted February 21, 2023 Share Posted February 21, 2023 Hi All,Here here is my sample level. I use markers around the tracks to indicate + and - using red and black indicator's and an isolated section where + meets - to create the protected area for the RLM to do it's work. Hope this makes sense !! Link to comment Share on other sites More sharing options...
Weymatt Posted February 21, 2023 Share Posted February 21, 2023 Hi AllThis is my latest effort showing route indicators and polarity the green track is my RLM protected track with isolated breaks. Hope it makes sense!!CheersMatthewRDS Moderator Note: I have spent some time editing your images which hopefully makes them easier to view. Link to comment Share on other sites More sharing options...
What About The Bee Posted February 22, 2023 Share Posted February 22, 2023 Hi WeyMatt 👋. Before I begin, I will point out that I suffer from CDO. This is the same illness as OCD, but in my case, the letters are arranged properly! A joke obviously. I do not have this affliction. But it serves to highlight what follows.I've carefully studied this portion of the plan. I include the reference image so you can understand what I am talking aboutFirstly, yes, you need that isolating section. You do understand that the length of any train you run MUST be less than this isolated section. How long is it, in inches? There are a few track difficulties.Right at your curved point cross over, I see this gap. My CDO demands that you close it.There are these two 6.8" flex tracks that overlap. Neither completes the circuit. My CDO is twitching.In this area, R8072 does not properly connect to R8073. In this area, you've selected Marklin double slip 24624 and connected it to Hornby R8073 point. R8073 doesn't connect properly after that. Have you considered the track code? The relative heights of the tops of the rails? Whilst they can be made to join, they will not simply clip together. Different systems, different attachments. There is lots to consider here. Now my CDO is making me nervous! And finally we come to this. You have R8072 and R8073 laid directly on top of each other, and have created a three way point. My CDO has the best of me now!! YikesPlease go over your entire plan. Make sure every bit of track connects without overlap or gaps. Use the track planning tool to generate a plan that can actually be built. How will you know? The tracks join. While you can "force it" when confronted by actual track, the best approach is to eliminate these dilemmas before you pick up a single piece of track.Bee Link to comment Share on other sites More sharing options...
Weymatt Posted February 22, 2023 Share Posted February 22, 2023 Hi BeeI have gone through your observations and sorted the bad junctions.I have only used the Markin double slip as my program, Railmaster Pro, does not Have a double slip icon in the Hornby track library. It also does not have a 3 way junction. hence my solution. I do have some 3 way turnouts in may stock that I can substitute in the real layout.Hope this gives you a little more confidence that I am not as hopeless as you think!!Cheers Matthew. Link to comment Share on other sites More sharing options...
Brew Man Posted February 22, 2023 Share Posted February 22, 2023 Is there not a Peco library in your software? They do single and double slips and three way points. Link to comment Share on other sites More sharing options...
Weymatt Posted February 22, 2023 Share Posted February 22, 2023 Hi Brew ManNo apparently Peco would not play ball.I do use Peco 3 Way turnouts, I have not got any double slips, I will go for Peco.CheersMatthew Link to comment Share on other sites More sharing options...
Weymatt Posted February 22, 2023 Share Posted February 22, 2023 Hi BeePs my isolated track measures 87"Cheers Matthew Link to comment Share on other sites More sharing options...
96RAF Posted February 22, 2023 Share Posted February 22, 2023 I have been using RM-pro for donkeys years and didn’t realise it had actual PN track pieces only simplistic track piece icons that assemble into a rough schematic of the track.Nor does it do inclines.Your plan looks more like it was done in Any-rail or Scarm. Link to comment Share on other sites More sharing options...
Weymatt Posted February 22, 2023 Share Posted February 22, 2023 Hi 96RAFRM does do inclines.You select connected track (Must be connected) on the RH side bar choose elevation. this will open a window where you choose start and end highs and it will tell what the incline % is.If you use the 3D view, "top bar" you can see a representation of the incline you have produced. "Good gracious" I think I may have helped someone.CheersMatthew Link to comment Share on other sites More sharing options...
P-Henny Posted February 22, 2023 Share Posted February 22, 2023 Could you possibly be confusing Railmaster with Trackmaster.Trackmaster is layout planning, whereas Railmaster is layout control. A screen shot of the application you are using will nail it.I have seen quite a few posts where posters have mixed up the application names, so there is forum history for this. Link to comment Share on other sites More sharing options...
Weymatt Posted February 22, 2023 Share Posted February 22, 2023 Hi P-HennySilly me folks I also use Hornby Railmaster Pro, hence mixup.My planning program is RAILMODELER PRO.Not so helpful after all, never mind at least I tried to help. CheersMatthew Link to comment Share on other sites More sharing options...
P-Henny Posted February 22, 2023 Share Posted February 22, 2023 Understandable given the name similarities. But it does kinda confuse readers that take what you write as being gospel.But now suitably clarified.innocent Link to comment Share on other sites More sharing options...
What About The Bee Posted February 22, 2023 Share Posted February 22, 2023 Weymatt, you wrote:Hope this gives you a little more confidence that I am not as hopeless as you think!! I don't think you hopeless. Not at all. I presented you with some areas of concern for resolution. Please do not read too much into that.Your goal is the same as mine. A wonderful layout that provides great enjoyment. My current layout is small. I have fun, but I want "the more". The next step is a bigger layout, of course. In planning, I've used SCARM to insure that every physical connection is as perfect as can be. That each curve has a specified radius. Every join has a perfect angle. I've mentally traversed the layout literally thousands of times, considering how it will function. I've used quite a bit of trigonometry to get there. I then considered the entire electrical schematic. I know every wire routing, bus voltage, polarity, etc. I know where each circuit breaker will be, to protect me. Each and every component, all the wires.I know exactly how much my proposed layout will cost, the complete BOM (bill of materials).What I am trying to say is that: Prior Planning Prevents Poor Performance. The 5 P's of Engineering. And now that the thought exercise is complete, will I build it? NO! Ha! I discovered, through mental play, that there were some deficiencies. The entire cycle will be repeated, with those deficiencies corrected. The schematics redrawn. Had I built it, those deficiencies would have caused disappointment. Better to discover them now, instead of later, after the layout is constructed. As mentioned earlier, a monumental layout can prove very challenging. Particularly so if you are going to overlook small problems, which have a tendency to snowball and accumulate. Slow down a bit lad! Turn on your inner CDO.Bee Link to comment Share on other sites More sharing options...
