Pendragon Sailing Posted August 13, 2023 Share Posted August 13, 2023 Here’s a curious thing.I loaded up the Class 31 Sound Profile through an 8-pin decoder into a new Heljan Class 33 loco.All was well until I ran the “Flange Squeal” function. After doing so I couldn’t get rid of it ! I turned the Function button on/off, I turned the AFC on/off, I tried other sounds over it so that there were four sound running simultaneously, but still it ran on. I then reloaded the Class 31 profile….and still it was there and running ! I even loaded a Class 56 profile and it was still there !!!It was as if it was stuck/burned into the decoder’s memory and wouldn’t go away!After much experimentation, my solution in the end was to:Shut down my iPad (Pro)Reload the AppDelete the decoder and re-link itRun-through Class 31 Profile download process (again).Success !A strange one, for sure. Have any others encountered this phenomenon? Link to comment Share on other sites More sharing options...
Britannia Builder Posted August 13, 2023 Share Posted August 13, 2023 Yes, I had something similar a couple of weeks ago. I think it was the flange squeal or perhaps the brake - certainly something very annoying. It was the Black 5 profile on a Bachmann 3MT Tank. I think I might have triggered it by using the sound test buttons in Railmaster's loco function button setup.I couldn't get rid of it, but after powering everything down it had stopped when I next ran.Regards, John Link to comment Share on other sites More sharing options...
Ighten 1707822464 Posted August 22, 2023 Share Posted August 22, 2023 It sounds like you must have accidentally changed how that sound works.. think one of the combinations of those three buttons (in the function test) just puts it in a loop.. you can try them by going to test function, just remember where it was in the first place or reload a saved profile 😉No idea re the OP though why it happened when you changed from 31 to 56 though. That doesn't make sense. The chip doesn't care what the sound is it's just sees numbers and data so that's baffling.I did once mess everything up trying to get a 1 page profile for the engine in an order that made sense.Primer, cold start, start, thrash, notch up, notch down, etcBut I ended up messing everything up quickly but just resetting the profile fixed it instantly. Link to comment Share on other sites More sharing options...
5Dublo2 Posted August 22, 2023 Share Posted August 22, 2023 I had something similar happen to me - I eventually found (by trial and error) that enabling and disabling a completely different function stopped the continuous sound and then I couldn't make the issue happen again. Link to comment Share on other sites More sharing options...
Ighten 1707822464 Posted August 22, 2023 Share Posted August 22, 2023 Sometimes the automated feature can also cause some weirdness to happen.. I have had cases where I couldn't shut an engine down because I forgot this was on Link to comment Share on other sites More sharing options...
