Rallymatt Posted January 29 Author Share Posted January 29 It happens Link to comment Share on other sites More sharing options...
ateshci Posted January 29 Share Posted January 29 Holding me back from finally building that 'Minories' project in TT -One FX4 front wheel suspension replacement.One badly timed injection pump on another, have to get rid of that smoke!One broken sliding window spring on the last one.A 9 1/2" gauge permanent way that needs to be cleared of debris for springtime operations:-)) Link to comment Share on other sites More sharing options...
Gregory-374918 Posted January 31 Share Posted January 31 The A1 keeps derailing all the time ! Still waiting for other locos to be available, it had such promise but is turning out not to be as easy as I had hoped. Link to comment Share on other sites More sharing options...
david_watts1 Posted January 31 Share Posted January 31 A bone problem... I'm bone idle and haven't got round to clearing the room so I can make my pre-made 6x4 plywood baseboard.joy Link to comment Share on other sites More sharing options...
John-L Posted February 3 Share Posted February 3 The A1 keeps derailing all the time ! Have you tried contacting Hornby customer service? I’ve always found them to give excellent after sales support. They might be able to help solve your problem. Link to comment Share on other sites More sharing options...
Rallymatt Posted February 3 Author Share Posted February 3 Gregory, the derailing issue is 100% fixable. You can contact Hornby Customer Service directly (irrespective of who supplied the model) and they can make adjustments to get things running smoothly. orLook through the sticky at top here to find a hints and tips list collated by Peachy that covers all the tweaks you can do at home yourself. You won’t need any exotic tools, all pretty straightforward. Either option is perfectly fine and your choice however if I was to give a little advice, this is a home fettling project worth trying and gaining some experience with. Model railways are miniature mechanical engineering marvels but will need servicing and adjusting over time. If you develop further into the hobby you will find things that require these skills and you will just get better and better and more confident. This is an easy and rewarding one to start with. Link to comment Share on other sites More sharing options...
LTSR_NSE Posted February 3 Share Posted February 3 @John-L & @Rallymatt - please be aware @gregory has a specific post about his loco issue:https://uk.hornby.com/community/forum/a1-and-tender-derailing-on-points-i-cant-see-what-is-causing-it-380165?ccm_paging_p=1#end-of-replies Link to comment Share on other sites More sharing options...
Moccasin Posted February 4 Share Posted February 4 Having bought a Scale Model Scenery modular baseboard in a box (1100mm x 220mm) last year, I got it out of the cupboard yesterday and played around with some track options. Even for a small shunting/depot layout it’s very tight (5 tracks can just about be crammed in, but with sidings/headshunt little more than a double straight in length) so at least one more module (550mm x 220mm) is likely needed to allow any layout to breathe. Doubling in length to 2200mm x 220mm is possible without too much overhang on the table.My other alternative is something to allow either a U-shaped track layout or a full oval (or a hybrid), but storage of the baseboard would be tricky. While end to end layouts interest me most, letting a model train stretch its wheels for a bit is strangely satisfying.Having set up the shunting track layout, it would have been rude not to shunt a few coaches around with my 08 to research interest levels. Wagons would have been better and a small wagon repair works with a small locomotive stabling point remains an option for a small urban-set layout. In which case, setting up an oval on the kitchen table for operating “proper trains” would be an occasional thing.PS Hild the cat was watching warily almost throughout the operating session and did get closer to investigate at one point. My 08 would not have lasted long against a paw swipe! Link to comment Share on other sites More sharing options...
