Point motor or working from BUS
Hi all
first post, first credit and reference to Warwick’s. Post in 2019 in relation to my question
Side not first just bought latest Hornby Flying Scotsman 21 pin  with steam
love it
to question
peco 10 e point motor
works on table from a ancient Hornby Mecanno   The AC outputs 19.5   It also works pushing points on track when I wire directly to one individual point from under table
but the BUS accessory line will not even operate the point ( using powercab)
in fact if I wire the NCE powercab directly as a main power source to Point motor while holding point in my hand so no resistance on motor.  It won’t switch
So if I understand Warwick it is not going to and I should not try
problem then is the power cab does not provide a aux port
do I need to get a separate power supply
if so can I get advice on which one to purchase
the meccano one I have is very old and I don’t trust it to not catch alight eventually
For interest is a Hornby II power control unit
Pic attached for amusement purposes
anyone know how old this could be
Yes.
Hello Ian and Welcome Aboard.
The power controller appears under two names, Marshal II and Hornby II.  Identical case and configuration.  Late 1950s to 1960s.
Bee
Edited by What About The Bee
Clarity
I'm a bit confused by what you've written about the point motor?  Are you trying to operate the solenoid point motor  over DCC using an accessory decoder connected to the motor, or are you simply trying to use DCC power and push buttons or a toggle switch to fire the point motor?  For it to be switched using DCC it needs an accessory decoder.
I wouldn't waste the available DCC track power from the PowerCab to provide raw power for point motors.   If you're not operating the point motors via DCC  then use a separate power supply (preferably about 18V) and a Capacitor Discharge Unit (CDU) which will allow a strong but brief "thump" of power and then protect against burn-out if the power is on too long. Use momentary switches or push-buttons.
Edited by ntpntpntp
