kered43 Posted May 2, 2013 Share Posted May 2, 2013 Hi i have one of these chips in one of my locos it responds brilliant forward nice and slow and even all the way up to top speed but when it is put in revese it shoots off like a 100mtr sprinter and will not respond to the throttle. I have reset it back to hornbys manufactures settings still the same do not understand why its fine forward but not reverse .Has anybody had this problem? Link to comment Share on other sites More sharing options...
poliss Posted May 2, 2013 Share Posted May 2, 2013 Try resetting the controller. Link to comment Share on other sites More sharing options...
RDS Posted May 2, 2013 Share Posted May 2, 2013 @kered43 Do you have other Loco's that work correctly? If you do, I would have thought it is more likely to be this particular decoder that is at fault. Link to comment Share on other sites More sharing options...
Augustus Caesar Posted May 2, 2013 Share Posted May 2, 2013 If it's the decoder try rewiring and then reprogramming... you never know. More likely it may be faulty. Link to comment Share on other sites More sharing options...
kered43 Posted May 2, 2013 Author Share Posted May 2, 2013 AugustusCaesar said: If it's the decoder try rewiring and then reprogramming... you never know. More likely it may be faulty. Link to comment Share on other sites More sharing options...
kered43 Posted May 2, 2013 Author Share Posted May 2, 2013 AugustusCaesar said: If it's the decoder try rewiring and then reprogramming... you never know. More likely it may be faulty. hi i have taken it out of one loco and put it in another still the same.i have had a number of problems with these decoders to be honest. Link to comment Share on other sites More sharing options...
kered43 Posted May 2, 2013 Author Share Posted May 2, 2013 RDS said: @kered43 Do you have other Loco's that work correctly? If you do, I would have thought it is more likely to be this particular decoder that is at fault. yes i have others that are working at the moment but this is my 4th hornby chip to go wrong. Link to comment Share on other sites More sharing options...
walkingthedog Posted May 2, 2013 Share Posted May 2, 2013 If the fault moves with the decoder it's the decoder. Standard fault finding procedure. Take the item you think is faulty, put it in something that works ok. If that then has the same fault you've found the problem. Link to comment Share on other sites More sharing options...
Fishmanoz Posted May 2, 2013 Share Posted May 2, 2013 It must be one of the new hybrid decoders - runs DCC forwards and analog in reverse. So each time you put it in reverse, just change the controller to a DC job and it will be fine. Link to comment Share on other sites More sharing options...
Fishmanoz Posted May 2, 2013 Share Posted May 2, 2013 Or maybe everyone is right - it's faulty. Link to comment Share on other sites More sharing options...
Gregd99 Posted May 3, 2013 Share Posted May 3, 2013 I think I have found the problem. the 8247 is an accessory decoder! how did you get it in your loco? 1. if it is an 8245/8249 have a look at the leaflet and try disabling the dc operation bit in the decoder. I have heard that this sometimes causes some unexpected behaviour. Just an idea... 2. Did you rest the controller? Perhaps it is transmitting rubbish when in reverse? 3. Do you have any locos that work OK in forward and reverse? do they have the same type of decoder as in the high speed revers loco? Link to comment Share on other sites More sharing options...
