gilbo2 Posted December 4, 2013 Share Posted December 4, 2013 Anyone else had this problem?; Since 1.54 update I am having problems writing CV's. It goes through ....writing....confirming....reading and then an error window appears that it cannot read CV's. I 'tick' the error window and the system now is stuck in the ....writing....confirming....reading loop. If I restart Railmaster and then just try to read the same CV, it has actually changed but the confirming process seems to get in a mess when initially writing. I re-installed 1.53 and it works fine. Went back to 1.54 and the CV write problem above was present. Any ideas? (Have also contacted support) Link to comment Share on other sites More sharing options...
RDS Posted December 5, 2013 Share Posted December 5, 2013 @dgilbert2 I think Hornby Support will need to answer this one for you because if it is OK with 1.53 but not 1.54, it does appear to be caused by the update. Link to comment Share on other sites More sharing options...
96RAF Posted December 5, 2013 Share Posted December 5, 2013 dgilbert2 said: Anyone else had this problem?; Since 1.54 update I am having problems writing CV's. It goes through ....writing....confirming....reading and then an error window appears that it cannot read CV's. I 'tick' the error window and the system now is stuck in the ....writing....confirming....reading loop. If I restart Railmaster and then just try to read the same CV, it has actually changed but the confirming process seems to get in a mess when initially writing. I re-installed 1.53 and it works fine. Went back to 1.54 and the CV write problem above was present. Any ideas? (Have also contacted support) I can confirm the problem. It reads all CVs I ask for, but if I change one (eg CV146 - Sapphire fuel sim on/off) it goes through the writing, confirming bit then flags up an error. Tick the box and it repeats the process until I X the box, then when I reopen it and read that CV again it is as I changed it. Link to comment Share on other sites More sharing options...
96RAF Posted December 5, 2013 Share Posted December 5, 2013 I have Elte as Controller A connected to the Prog track and ELink as Controller B not connected to any prog as it is for points and they are all sorted, but I am sure I can hear both controller relays clicking. Could RMCS confirm that any programming action is sent to both controllers and if so how does the one know not to confuse the other, etc. Link to comment Share on other sites More sharing options...
Fishmanoz Posted December 8, 2013 Share Posted December 8, 2013 Please do email RM Support about this from within the RM Help window before you revert to 1.53. This clearly needs their attention. Link to comment Share on other sites More sharing options...
Fishmanoz Posted December 8, 2013 Share Posted December 8, 2013 RAFHAAA96th said: I have Elte as Controller A connected to the Prog track and ELink as Controller B not connected to any prog as it is for points and they are all sorted, but I am sure I can hear both controller relays clicking. Could RMCS confirm that any programming action is sent to both controllers and if so how does the one know not to confuse the other, etc. There should be no confusion here. The only decoder to respond will be the one addressed, no matter which controller it is connected to. I will give you there is a possibility of confusion with a loco decoder, or an accessory decoder, connected to each controller. Both will respond. So the rule of only one thing on the programming track at a time would seem to be necessary for both controllers. Link to comment Share on other sites More sharing options...
Fishmanoz Posted December 8, 2013 Share Posted December 8, 2013 That should read at the end of the first sentence ...... each controller's programming track. Link to comment Share on other sites More sharing options...
Fishmanoz Posted December 8, 2013 Share Posted December 8, 2013 First sentence of last para that is. Sorry for the confusion. Link to comment Share on other sites More sharing options...
gilbo2 Posted December 8, 2013 Author Share Posted December 8, 2013 This is another bug that HRM support cannot replicate. I would be grateful therefore if everyone with Railmaster and an Elite or eLink could try writing to a CV and reporting what they find. I have now even tried doing this on a completely different computer running windows 8.1 but that has the same problem :-( It makes no sense that I cannot get version 1.54 to work and yet 1.53 and earlier work fine! Link to comment Share on other sites More sharing options...
St1ngr4y Posted December 8, 2013 Share Posted December 8, 2013 dgilbert2 said: I would be grateful therefore if everyone with Railmaster and an Elite or eLink could try writing to a CV and reporting what they find. I can confirm your findings. I have replicated using an Elite + Windows 7. When it loops around and does the Write again, you can press the X button to close that window. The Elite goes on clicking away in the background and you then get the "An error occurred writing..." message, but this time when you click the Tick, it has exited the loop. You can then go back into the Loco Info window and read the CV you were trying to change, and you will find that it has changed. At least this saves having to reload RM!! Ray Link to comment Share on other sites More sharing options...
gilbo2 Posted December 9, 2013 Author Share Posted December 9, 2013 St1ngr4y said: I can confirm your findings. I have replicated using an Elite + Windows 7. When it loops around and does the Write again, you can press the X button to close that window. The Elite goes on clicking away in the background and you then get the "An error occurred writing..." message, but this time when you click the Tick, it has exited the loop. You can then go back into the Loco Info window and read the CV you were trying to change, and you will find that it has changed. At least this saves having to reload RM!! Ray Thanks, I hope they fix this soon. You would not want new RailMaster customers having this problem on Christmas morning! :-( Link to comment Share on other sites More sharing options...
HornbyRailMasterSupport Posted December 9, 2013 Share Posted December 9, 2013 We have identified a small problem in the timing system in relation to confirming CVs when writing. Although the CV does in fact write the correct value, the confirmation can fail on some systems. You can download the setup program from www.powerpos.com/rail-master/rm_setup.exe, install that and see if it resolves the issue on your PCs. Link to comment Share on other sites More sharing options...
gilbo2 Posted December 9, 2013 Author Share Posted December 9, 2013 HornbyRailMasterSupport said: We have identified a small problem in the timing system in relation to confirming CVs when writing. Although the CV does in fact write the correct value, the confirmation can fail on some systems. You can download the setup program from www.powerpos.com/rail-master/rm_setup.exe, install that and see if it resolves the issue on your PCs. Have now tried the above file and it has certainly changed what's happening when writing cv's. I find now though that it seems to get stuck on the red 'confirming' text and does not seem to finish the routine. The cv though, if I close and go back in again, has changed. Link to comment Share on other sites More sharing options...
Fatdaddy Posted December 12, 2013 Share Posted December 12, 2013 dgilbert2 said: Anyone else had this problem?; Since 1.54 update I am having problems writing CV's. It goes through ....writing....confirming....reading and then an error window appears that it cannot read CV's. I 'tick' the error window and the system now is stuck in the ....writing....confirming....reading loop. If I restart Railmaster and then just try to read the same CV, it has actually changed but the confirming process seems to get in a mess when initially writing. I re-installed 1.53 and it works fine. Went back to 1.54 and the CV write problem above was present. Any ideas? (Have also contacted support) Link to comment Share on other sites More sharing options...
Fatdaddy Posted December 12, 2013 Share Posted December 12, 2013 I have exactly the same problem ( windows 7)hornby support are working on an update to resolve this issue Link to comment Share on other sites More sharing options...
Fatdaddy Posted December 12, 2013 Share Posted December 12, 2013 dgilbert2 said: This is another bug that HRM support cannot replicate. I would be grateful therefore if everyone with Railmaster and an Elite or eLink could try writing to a CV and reporting what they find. I have now even tried doing this on a completely different computer running windows 8.1 but that has the same problem :-( It makes no sense that I cannot get version 1.54 to work and yet 1.53 and earlier work fine! Link to comment Share on other sites More sharing options...
Michael_A Posted December 12, 2013 Share Posted December 12, 2013 So thanks Hornby for releasing a SW upgradfe with bugs. Don't you thoroughly test these updates, or would you rather we wasted hours trying to make things work rather than enjoying our railways? Link to comment Share on other sites More sharing options...
Fishmanoz Posted December 12, 2013 Share Posted December 12, 2013 Nobody's perfect Michael, not even HRMS. On the whole though, I think they are doing a great job and, as you can see in this instance, have been very responsive when problems have been identified. Link to comment Share on other sites More sharing options...
PJ_model_trains Posted December 12, 2013 Share Posted December 12, 2013 Fishmanoz said: Nobody's perfect Michael, not even HRMS. On the whole though, I think they are doing a great job and, as you can see in this instance, have been very responsive when problems have been identified. With my experience with computers from a green screen Tandy, the first BBC micro, MS-Dos and PC-Dos, through every version of windows, plus my wife's electronic die cutting machines and more, from time to time with all of them there have been problems with downloading and installing upgrades. It is frustrating when it happens but I am sure Hornby will sort the problems for you, sometimes it may be a conflict or need a patch, there are so many computers on the market and in our homes all with different operating systems and other companies software in them. Link to comment Share on other sites More sharing options...
RDS Posted December 12, 2013 Share Posted December 12, 2013 Michael_A said: So thanks Hornby .... upgradfe .....with bugs. Don't you thoroughly test these updates? Classic! Link to comment Share on other sites More sharing options...
BigNoj Posted December 12, 2013 Share Posted December 12, 2013 Fishmanoz, any relation to LMS Tim? Link to comment Share on other sites More sharing options...
Graskie Posted December 12, 2013 Share Posted December 12, 2013 Funny but I've sometimes wondered whether Fishy is the Australian rep for Hornby. Link to comment Share on other sites More sharing options...
Fishmanoz Posted December 12, 2013 Share Posted December 12, 2013 Oops, I'm going to have to watch myself. First, no relation, and if you look back to when he and DCCTinker were posting, which was last quite some time ago, I was their biggest critic. This was because they were unashamedly pro all Hornby, whether justified or not. And to the extent that they annoyed me intensely. If you remember, I referred to them as the explosive pair of TnT, being of cause Tim n' Tinker and always going off if one word against Hornby was said. In fact, I reported them to the administrator on one occasion when they were completely over the top in their criticism and that thread content was removed. And no I'm not the local Hornby rep. I'll be more circumspect in my praise of them in future, even if I think it is due. I wondered whether to make that last post in support or not for this reason, and you've confirmed to me I shouldn't have. Then again, blanket criticism rather than sticking to the specific shortcoming, is not helpful either. Link to comment Share on other sites More sharing options...
Graskie Posted December 12, 2013 Share Posted December 12, 2013 And we all know what sticks to blankets best, don't we, Fishy? (lol) Link to comment Share on other sites More sharing options...
HornbyRailMasterSupport Posted December 13, 2013 Share Posted December 13, 2013 We have noticed that some users have been experiencing difficulty programming CVs through the CVs window, where although the CV would write successfully, the confirmation process did not always complete. We have uploaded an update to www.powerpos.com/rail-master/rm_setup155.exe which you can download and install to see if it resolves the issue for you. This update has not yet been made automatically available to everybody else so that those of you who have experienced the problem with writing CVs can test it and let us know if it doesn't work for you. We hope to make the update available for automatic download early next week. Link to comment Share on other sites More sharing options...
