Fishmanoz Posted September 26, 2014 Share Posted September 26, 2014 John and tony, let me be as direct as I can - the revisions contain many fixes to the standard 1.56, not just to ProPack. Download the latest revision now as per my previous instructions. You will not be putting anything into it that it doesn't use and you will definitely not change the way RM is set up to work now. And when v1.57 comes out, you will need to do it again. The process for revisions and v1.57 will be exactly the same. And will be the same as for all future updates of which there will be countless. You will be downloading new versions of rm_setup.exe regularly for the rest of your days. Start now. No further delaying acceptable. Do it! Link to comment Share on other sites More sharing options...
PJ_model_trains Posted September 26, 2014 Share Posted September 26, 2014 Hi TonyWhich bit are you hovering over to see Rev7?PJ Link to comment Share on other sites More sharing options...
sticksteer Posted September 26, 2014 Share Posted September 26, 2014 PJif you hover your curser over the tiny yellow box with 1.56 in it, at the bottom right of the screen you will see a label with the revision number it started showing with revision six and we are now at eight.Ken Link to comment Share on other sites More sharing options...
Yelrow Posted September 26, 2014 Share Posted September 26, 2014 When I hover where you say ,nothing happens. However, asi I have not updated , why would it john Link to comment Share on other sites More sharing options...
tony_forward Posted September 26, 2014 Share Posted September 26, 2014 pj,At the very bottom of the screen on the right hand side, there is a tiny yellow box. Hover the cursor over it and the version number comes up after a few seconds. beware though, it shows below the yellow box, possibly off your screen and not visible. If this is the case, you can use the normal windows trickery and resize the screen by clicking on the centre of the three boxes at the top right corner.... Fishy, I spent the last 20 years of my working life updating windows and living with the resulting MS screwups... I'll let you guys test the RM updates and do mine a few days later :) Link to comment Share on other sites More sharing options...
Yelrow Posted September 26, 2014 Share Posted September 26, 2014 Just a thought, do you have to be connected to the internet to see this update no, cos if you do, thats why i have none, john Link to comment Share on other sites More sharing options...
RDS Posted September 26, 2014 Share Posted September 26, 2014 JohnYes of course you need a connection to the Internet but even with a connection, RailMaster will not see the update automatically because it is still v1.56 and (at present) it only checks for updates that go to a new version number. HRMS have now introduced different Revisions to v1.56.When did you update to v1.56, because if you are not seeing anything when hovering over the yellow box, you must be on a much earlier Revision of v1.56 than is currently available. The hovering feature, was introduced at Revision 4 as far as I am aware and we are now on Revision 8. Having said all that, if your current version of v1.56 works for you, then why not just stick with it!However, if you do not have a permanent internet connection on your RailMaster Laptop, you will need to keep an eye on the forum to see when v1.57 is available. Link to comment Share on other sites More sharing options...
Fishmanoz Posted September 26, 2014 Share Posted September 26, 2014 No. See RDS's explanation above. And you could look at it this way - while you are still at v1.56, many of us are now are v1.64. Link to comment Share on other sites More sharing options...
PJ_model_trains Posted September 28, 2014 Share Posted September 28, 2014 I cannot see why Hornby cannot include the updates in the file referenceeg v1.56v1.56.5now v1.56.8Everyone could see at a glance which file they have downloaded and if they have that version they have no need to do anything at that time.Having said that, as discussed before using the version upgrade referrence Hornby can make the downloaded automated and everyone is guaranteed to have the latest version.PJ Link to comment Share on other sites More sharing options...
idlemarvel Posted September 28, 2014 Share Posted September 28, 2014 Agreed PJ, but let's be thankful there is at last an easy way to find out which revision you are on! Glass half full and and that... :-) Link to comment Share on other sites More sharing options...
96RAF Posted September 28, 2014 Share Posted September 28, 2014 My point exactly as previously pleaded - the proper way to do it. Link to comment Share on other sites More sharing options...
idlemarvel Posted October 2, 2014 Share Posted October 2, 2014 The touch screen icon (yellow hand) does not remember its position any more. It used to in 1.55 now whenever I start RM (propack rev 9) it is back at the top left of the layout area again, and I have to move it again. As it is meaningless if you don't have a touch screen, I would like to see a railmaster.ini setting to disable it, like the mouse setting, but in the meantime if it could remember its position like it did before that would be handy. Small thing but quite annoying. Link to comment Share on other sites More sharing options...
idlemarvel Posted October 2, 2014 Share Posted October 2, 2014 You cannot delete program buttons from a layout. You can move them and edit them, but once added they are there forever. They should be deletable like all other layout items. Link to comment Share on other sites More sharing options...
Fishmanoz Posted October 2, 2014 Share Posted October 2, 2014 These look like a couple of things for Desirable Features idle. Link to comment Share on other sites More sharing options...
idlemarvel Posted October 3, 2014 Share Posted October 3, 2014 Perhaps fishy but although these are indeed desirable they are really bugs. But I'll put them there anyway. Link to comment Share on other sites More sharing options...
