kbjb Posted December 3, 2017 Share Posted December 3, 2017 Hi there - brand new to Scalextric, although as a kid I had Faller AMS and my kids had Aurora AFX, diving straight into digital with Arc Pro. So a dumb newby question ... why are there 2 power sockets on the powerbase? cheers kbjb Link to comment Share on other sites More sharing options...
Blagard-01 Posted December 3, 2017 Share Posted December 3, 2017 Because you need two when running more than 3 cars Link to comment Share on other sites More sharing options...
eMongoose Posted December 4, 2017 Share Posted December 4, 2017 Part number on the power supply that came with the upgrade kit is P9303. Searching on this site's shopping section it says they are out of stock, and don't expect to get any more. Yes, I can search online and find some retails that still show to have the standalone power supply, but are we to assume that Scalextric is planning to add a new power supply to their parts list? Link to comment Share on other sites More sharing options...
Blagard-01 Posted December 4, 2017 Share Posted December 4, 2017 Scalextric will always have power supplies but may be out of stock from time to time. There are a number of 15V 4A power supplies by Hornby incl P9300 , P9301, C7024. I have no idea how different they are but they have have the same connectors and they all have been used with C7042 Digital APB. So if ARC Pro requires a specific transformer it should say so as those earlier ones are going to get used by people upgrading to ARC Pro unless told they shouldn't! Link to comment Share on other sites More sharing options...
gorp Posted December 4, 2017 Share Posted December 4, 2017 currently 9300 has brit connectioncurrently 9303 is usa plugwithout looking through more of brit and usa scaly catalogs on this sitefigure 7024 was original pack for each Link to comment Share on other sites More sharing options...
kbjb Posted December 6, 2017 Author Share Posted December 6, 2017 Because you need two when running more than 3 carsThanks Blagard-01. I did in the end manage to find this out on the forum. Currently just getting into Arc Pro and at this stage only have the Powerbase (upgrade), 2 controllers and 2 cars with chips, however my proposed track will be close to 25m when complete (even longer if I make the pits larger). Will I likely also need a second controller due to the length of my layout or is it really based on the number of cars you're running at any time? cheers kbjb Link to comment Share on other sites More sharing options...
gorp Posted December 6, 2017 Share Posted December 6, 2017 yes , since the dawn of the slot age, it is really based on number of cars running , analog or digital1 controller controls any 1 car on the track Link to comment Share on other sites More sharing options...
kbjb Posted December 6, 2017 Author Share Posted December 6, 2017 yes , since the dawn of the slot age, it is really based on number of cars running , analog or digital1 controller controls any 1 car on the trackSorry gorp - knew the 1 car = 1 controller ... was meaning power controlerl ... given I will have over 25m of track am I likely to need another power (transformer) due to track lenght or will that only be needed if I increase cars/controllers past 2? cheers kbjb Link to comment Share on other sites More sharing options...
Blagard-01 Posted December 6, 2017 Share Posted December 6, 2017 The two transformers for more than 3 cars will be fine. What you will need is booster cables to put the power into the track directly at some distance away from the base. This helps overcome the drop in voltage due to the track to track connections not always being perfect and keeping the voltage up all the way around. Very simple to do as you connect one end of a cable to the track by the powerbase and the other end to the same lane further around the track. Repeat for lane 2. If necessary do even more cables so you could have say 2 pairs with each a third of the way around the circuite.g.http://www.jadlamracingmodels.com/scalextric-c8248-sport-track-power-booster-cable-2xhttps://www.scalextric.com/uk-en/track-power-booster-cables.html Link to comment Share on other sites More sharing options...
kbjb Posted December 6, 2017 Author Share Posted December 6, 2017 Thanks Blagard-01 for the reply and the info. cheers kbjb Link to comment Share on other sites More sharing options...
Wbweisss Posted December 19, 2018 Share Posted December 19, 2018 I’be been unable to find - on this Scalextric site, the Hornby site, or any other site! - a 15v 4 amp power supply for sale (for use as a second power supply for ARC Pro).Any suggestions? Link to comment Share on other sites More sharing options...
woodcote Posted December 19, 2018 Share Posted December 19, 2018 Hi wbweisss - welcome to the forum. This is what you’re looking for: https://www.scalextric.com/uk-en/shop/power-controllers/powerbase/digital-15v-4-amp-transformer.html It’s out of stock on the UK Scalextric site, but should be in stock with retailers, such as this one: https://www.jadlamracingmodels.com/scalextric-hornby-digital-c7024-p9300-power-supply-for-r8213-c7042/ If you’re based outside the UK, it is a good idea to contact your regional Scalextric / Hornby distributor who will be able to point you in the right direction. Link to comment Share on other sites More sharing options...
Wbweisss Posted December 20, 2018 Share Posted December 20, 2018 Thanks, woodcote I’m in the US and have reached out to the regional Hornby distributor.related: do you know of there being any consequences from using a 15v 1.2a power supply - such as that provided with arc air - as the 2nd power supply? Link to comment Share on other sites More sharing options...
woodcote Posted December 20, 2018 Share Posted December 20, 2018 I wouldn’t recommend it. To run a decent sized track with more than 3 cars, plus lane changers, pit entry pieces and the powerbase, ARC Pro is designed to take two 4 amp power supplies. In North America, you are looking for a C7033 power supply. That’s the same as the UK C7024 but with a plug for an American mains outlet. I notice they are in stock here: http://www.132slotcar.us/store/product_info.php?products_id=2185 I’m sure they will also be in stock at other Scalextric and Hornby retailers. It is the same powner supply that is used with Hornby model railroad digital command control systems. Link to comment Share on other sites More sharing options...
Andy P. Posted December 20, 2018 Share Posted December 20, 2018 It really has to be 4 amp. On the SloCar Illustrated and SlotForum (ad Facebook) the US rep is Dave Kennedy. You can contact him directly. Link to comment Share on other sites More sharing options...
KESM Posted December 27, 2018 Share Posted December 27, 2018 Updated part # for the power supply is P9303. I picked one up @ Professormotor.com. P9303 Scalextric High Performance Digital Transformer - 15V 4 amp DC Link to comment Share on other sites More sharing options...
sgtada Posted February 5, 2019 Share Posted February 5, 2019 scalextric.com has their "stocklist" which shows all the stores, dealers in the US. You have to b like the rest of us and write to them all to find the one piece you need! Then pay for it. . . Link to comment Share on other sites More sharing options...
Nevadazielmeister Posted February 6, 2019 Share Posted February 6, 2019 scalextric.com has their "stocklist" which shows all the stores, dealers in the US. You have to b like the rest of us and write to them all to find the one piece you need! Then pay for it. . . That's a waste of time. I found them for $14.99 plus shipping (https://www.ebay.com/p/Scalextric-Switching-Mode-Power-Supply-Track-Transformer-P9303w/1748011620?_trkparms=aid%3D666006%26algo%3DPRP.MBE%26ao%3D1%26asc%3D20161103085654%26meid%3Dc45fe02f166045adbc62ab0dcf2154c2%26pid%3D100697%26rk%3D1%26rkt%3D1%26&_trksid=p2047675.c100697.m4697)I received mine yesterday and it works perfectly. Link to comment Share on other sites More sharing options...
AlanMather Posted April 11, 2019 Share Posted April 11, 2019 I'm new to Scalextrics too. I have an expanded Arc_Pro circuit with 4 cars and wondering which power unit I need to get for 6 cars. There is no info on the part number required or anything on YouTube showing how to do this. I don't want to get the wrong power supply. The user manual has no info either! Jadlam shows a whole host of items listed and part numbers, very confusing. Link to comment Share on other sites More sharing options...
Andy P. Posted April 12, 2019 Share Posted April 12, 2019 The part number is different depending on the country you are in because plugs are different around the world.Whatever part number is on the power supply you have should be the correct one for your country. Link to comment Share on other sites More sharing options...
Eric_8 Posted March 11, 2020 Share Posted March 11, 2020 Hi, I have a brand new ARC Pro with the P9300.I can get another power base for a good price, but it would be the older C7042. Could there be any issue for mixing them? Or are they basically the same? Link to comment Share on other sites More sharing options...
woodcote Posted March 12, 2020 Share Posted March 12, 2020 Hi Eric - if you mean the C7024 power supply, then yes - it is the same as the P9300 and will safely plug into the second power socket on your ARC Pro. If the power supply is second hand, it is worth having the unit checked over by an electrician. The C7042 is the Advanced Six-car powerbase and shouldn't be used in the same circuit as an ARC Pro unit. The two codes being so similar is ripe for confusion! I hope that helps. Link to comment Share on other sites More sharing options...
Eric_8 Posted March 13, 2020 Share Posted March 13, 2020 Hi Eric - if you mean the C7024 power supply, then yes - it is the same as the P9300 and will safely plug into the second power socket on your ARC Pro. If the power supply is second hand, it is worth having the unit checked over by an electrician. The C7042 is the Advanced Six-car powerbase and shouldn't be used in the same circuit as an ARC Pro unit. The two codes being so similar is ripe for confusion! I hope that helps.It does! Thanks.What about having other transformers connected to analog powerbases? I got an older set with plenty of tracks and there are 2 analog power bases (the ones with 2 transformers). Is it safe to space them throughout the tracks in order to keep the tension up? I guess not, but why not ask? 😛 Link to comment Share on other sites More sharing options...
woodcote Posted March 13, 2020 Share Posted March 13, 2020 Hi Eric. If you put an analogue powerbase into a circuit it will only deliver power when you pull the throttle on a controller plugged into that powerbase. So any second or third powerbases around the track will not deliver any extra power to the track. If you were to do that on a digital layout, it would be the same - no extra power. And you really wouldn't want to mix the AC power from the digital powerbase with the DC power from the analogue powerbase. It might be a very expensive disaster. The way to avoid power drops as you move away from the powerbase is to: keep the track cleankeep the track connections in good orderinstall power taps or 'jumpers' That's the same for analogue or digital tracks and there is more here: www.scalextric.com/uk-en/support/track-maintenance At my local Scalextric digital club, we build temporary tracks every month for an evening or day of racing. The circuits are 100 to 150-foot long and built in just over an hour. The track is given a good clean once a year and all the track tabs tightened. During construction, if the connection between two track pieces feels particularly loose, we will tighten the tabs. Each race track is built with two or three power taps running from a track piece next to the powerbase to 1/4, 1/2 and 3/4 of the way round the circuit (or 1/3 and 2/3 for shorter tracks, or one 1/2 way round for tracks of 30-50 feet). A power tap is simply a length of wire that runs from the rail of one track piece to exactly the same rail on another track piece. Scalextric produced their own C8248 Track Power Bosster Cables, but these are hard to get hold of. Jadlam Racing Models have their own version: www.jadlamracingmodels.com/scalextric-c8248-sport-track-power-booster-cable-2x/ The first cars to be run after the track is built have one drop of INOX MX3 put on each braid and the cars are run round the track, over the lane changers and through the pit lanes. INOX MX3 seems to work perfectly to clean and condition digital track rails, limiting electrical arcing and keeping the digital signals as good as they possibly can be. I would say it is a must-have for all digital racers - if used in small amounts. Pendle Slot Racing sell INOX MX3 in the UK and have two products. I would recommend decanting the pump spray into small dropper bottles. www.pendleslotracing.co.uk/brand/inox After the racing, the disassembled track pieces are stored in covered, dust-proof cardboard boxes without being cleaned - the INOX stays on the rails to protect them between races. The next month we build again... And we experience very few power issues during the year. I hope that helps. Link to comment Share on other sites More sharing options...
Eric_8 Posted March 13, 2020 Share Posted March 13, 2020 Awesome explanation! Thanks!! Link to comment Share on other sites More sharing options...
