T2B Posted August 7, 2018 Author Share Posted August 7, 2018 Thanks John, mine was the inspiration but I had some help from a modelling friend who had the material he uses for steam from train engines and a wider selection of airbrush colours than I, to execute the flame effect from the engine 😀 Link to comment Share on other sites More sharing options...
Kenneth ONeill Posted August 8, 2018 Share Posted August 8, 2018 I don't know the manufacturer name, but I've remembered some kits a friend had back in the early 1970s (so Eaglewall is possible) which had conventional prop mouldings and optional discs of clear plasticard to fit between the spinner backplate and the engine front. Link to comment Share on other sites More sharing options...
John Symmons Posted August 8, 2018 Share Posted August 8, 2018 Hi Paw'sIf the kits were small, 1/96 scale, they probably were Eagle-Wall, I only made the one kit a Spitfire Mk IX more out of curiourity than anyting else but I was quite pleased with the clear disc propeller.Remember we do this for fun John the Pom Link to comment Share on other sites More sharing options...
Kenneth ONeill Posted August 9, 2018 Share Posted August 9, 2018 I honestly only ever saw them built and displayed (on the TV I think) and can't remember anything more than the description given and that one was a twin engined amphibian (probably a Grumann Duck, certainly not as big as a PBY). Anyway, the real point was that you can replicate that design of prop disc with some clear plastic sheet and a compass cutter. Link to comment Share on other sites More sharing options...
T2B Posted August 9, 2018 Author Share Posted August 9, 2018 @ P4T The Duck was a single engined biplane amphibian, are you not thinking of the Grumman Widgeon/Gosling? Link to comment Share on other sites More sharing options...
Kenneth ONeill Posted August 10, 2018 Share Posted August 10, 2018 @ P4T The Duck was a single engined biplane amphibian, are you not thinking of the Grumman Widgeon/Gosling?Yes I am! 😳 Link to comment Share on other sites More sharing options...
Peter s Posted August 18, 2018 Share Posted August 18, 2018 For spinning props try this producthttps://www.ebay.co.uk/itm/Alliance-Model-Works-Dynamic-Propeller-for-1-72-F3F-3-2-74m-Hamilton-STD/401475113512?hash=item5d79c81228:g:PxQAAOSw9vlaWG9- it's basically a wire spiral far better suited to radial kits than those with big prop spinners but can look ok if done well. In all honesty id give them 5/10 for effect. I put one on a swordfish and it looked great. On a hurricane it looked amateur. Link to comment Share on other sites More sharing options...
Dominic Thomas Posted August 19, 2018 Share Posted August 19, 2018 For what it’s worth, I remember one or two Frog kits in the late 60s, early 70s came with a solid clear plastic disc [per engine] to replace the conventional static propeller. On these were scribed a set of ‘blurred’ blades, supposedly to be painted or nowadays given a wash to simulate movement. I can’t say the finished article looked that great, back then. Link to comment Share on other sites More sharing options...
