Idontwannaspendsolongonana Posted March 6, 2020 Share Posted March 6, 2020 Just got the Sunset Speedway set 2 days ago, one of the controllers didn't work just after one practice race and one pace car race. When the controller is turned on, the LED flashes and go off immediately and it is unable to connect to power base. Tried fitting new battery but still the same. Is there any hope to fix it? Link to comment Share on other sites More sharing options...
Andy P. Posted March 6, 2020 Share Posted March 6, 2020 Sounds like it may have gotten unpaired.Check the manual on pairing the controller again.There is also a great section here about the "rule of 3" that can cause controllers to appear to be not working:https://slotracer.online/community/showthread.php?tid=181&pid=6119#pid6119 Link to comment Share on other sites More sharing options...
woodcote Posted March 6, 2020 Share Posted March 6, 2020 Hi Idontwannaspendsolongonaname - welcome to the forum! Page 5 of the ARC Pro Quick Start Guide has an explanation of the various LED warnings on the powerbase and controller. A regular flashing LED on the controller suggests that the controller is in binding mode or the battery is low. An intermittent flashing LED on the controller suggests it is in 'sleep' mode. If in binding mode, there should be a corresponding flashing green LED on the powerbase. That should clear if you turn off the controller or powerbase, but following the 'Connect Controllers' instructions on pages 8 & 9 of the Quick Start Guide is worth doing. Most commonly, the reason is a low battery. Although most rechargable batteries should work, I use good-quality alkaline AA batteries. Sleep mode is best resolved by switching off the controller and then turning it on again. I do remember having an issue exactly like yours - a flashing LED and then nothing - but I can't remember what caused it or how I fixed it! Does this also happen when the ARC app is disconnected? Or only when the app is being used? If it happens in both cases, check that no other controller is connected to the same colour. A good solution would be to turn off your controllers and switch one on at a time. If you find two lighting up the same LED on the powerbase, go through the 'Connect Controller' steps for each of your three controllers to connect them to the three colours you want. If it only happens with the app in use, hard stop the app and then re-launch it. It is just possible that a glitch in the Pace Car feature has caused the problem. I hope something there helps. Link to comment Share on other sites More sharing options...
Idontwannaspendsolongonana Posted March 7, 2020 Author Share Posted March 7, 2020 Thanks guys, but I tried those ways and it still didn't work. The behavior of the controller LED is a bit odd and I don't think it's mentioned in the guidebook, when turned on, the LED on the controller blinks once and go off permanently. That happens even when the PB is turned off. I also tried pairing the controller again, but seems the PB can can't detect that controller, the green light on the PB keeps flashing and then goes off. The batteries I am using is a completely new set of alkaline AA batteries, that set of batteries works well in other two controllers Link to comment Share on other sites More sharing options...
Andy P. Posted April 7, 2020 Share Posted April 7, 2020 Does this happen with the app on as well as off? Link to comment Share on other sites More sharing options...
Alanwatson Posted December 26, 2020 Share Posted December 26, 2020 I am having a similar problem where:the car workscontroller is connected Bluetooth is connected Power is going from track to car as the Lights turn on and is making noise when I put a car on with no digital chip inbut still the car won't go. I am working with a VW Passat if that makes a difference. Link to comment Share on other sites More sharing options...
Andy P. Posted December 27, 2020 Share Posted December 27, 2020 Did you switch the ARC PRO to analog mode?That behavior is indicative of an analog car on a digital track... Link to comment Share on other sites More sharing options...
Alanwatson Posted December 28, 2020 Share Posted December 28, 2020 The car definitely has a digital chip in it Link to comment Share on other sites More sharing options...
Alanwatson Posted December 28, 2020 Share Posted December 28, 2020 Or is there a digital mode and an analog mode for arc pro? Link to comment Share on other sites More sharing options...
gorp Posted December 29, 2020 Share Posted December 29, 2020 Your original post says no chip in car.A solution is offered and then you say chip in car.Yes to 3rd posting question. Try posting at digital sub forum and READ the missing arc manual at slotracer.online. Link to comment Share on other sites More sharing options...
Andy P. Posted December 30, 2020 Share Posted December 30, 2020 Read the manual. It explains about analog and digital mode. Link to comment Share on other sites More sharing options...
