Dav2 Posted April 11, 2020 Share Posted April 11, 2020 Ok still new to all this and just wondering does the retro-fit chip work on other makes of slot car to enable them to work with the Scalextric Arc Pro unti? I've also read somewhere about the lights on some of these analog cars needs changed out too Link to comment Share on other sites More sharing options...
gorp Posted April 12, 2020 Share Posted April 12, 2020 You are probable using motors that the only used on all brands scaly chip ,7005, will not handle.The H dpr chip (white package) probably would but needs to be cut up.The best solution is using a slotit chip. Go to slot forum, digital, scaly for examples. Link to comment Share on other sites More sharing options...
Dav2 Posted April 12, 2020 Author Share Posted April 12, 2020 Ah so you don't need to use the scalextric digital chip. I can use others as in the slot.it chip to run with scalextric arc pro Link to comment Share on other sites More sharing options...
gorp Posted April 12, 2020 Share Posted April 12, 2020 Yes , you can use the slotit chip made for scaly use on the arc pro.Believe this site sells it too. Link to comment Share on other sites More sharing options...
Andy P. Posted April 15, 2020 Share Posted April 15, 2020 Yes the Slot IT chip can handle the higher voltages. Link to comment Share on other sites More sharing options...
