Scalextric Micro analogue - more than 1 power supply?
C-1225770
I have three sets of Scalextric Micro which are the analogue systems. I have joined them all together into a great long track. I obviously have 3 power supplies I can use and just wndered if I can connect them all together to boost the power around the circuit?
NO !!!
DO NOT CONNECT THEM ALL TOGETHER
For 1 pack per lane, use 2 power bases, and disconnect the 2 wires from the rails on lane1 from one powerbase and then do the same with lane 2 from the other. power base.
Then plug controllers into each powered up lane.
Connect power packs and go race.
If the track is in good condition and the connections are tight you should not need to boost the power.
Sets can easily get to over 10 meters before power is a problem...
I actually disconnect the power from the rails and use the powerbase sections as standard track...
