Fishmanoz Posted November 19, 2022 Share Posted November 19, 2022 Does it include the mysterious “extended straight” in the library? Anyrail yet to. I’ve used a lot of Tillig flex track in my design to get over spacing issues and because it’s better in practice anyway. Solves the lack of extended straight too. Link to comment Share on other sites More sharing options...
RB51 Posted November 19, 2022 Share Posted November 19, 2022 Yes Fishy TT8037 is there. R- Link to comment Share on other sites More sharing options...
96RAF Posted November 19, 2022 Share Posted November 19, 2022 @FishyHornby state the length of TT8037 as 92mm and its intended use is to gain width at a point curve to accommodate a platform. The 166 ID is a standard straight track length. Link to comment Share on other sites More sharing options...
Fishmanoz Posted November 20, 2022 Share Posted November 20, 2022 Thanks Rob, had all of that. And the track spacing it produces is about 67mm leaving the gap between tracks to accommodate the 48mm wide platform. I’ve used a different configuration - I’ve used a flex straight 170.76mm long instead of the 8037 and placed that between crossover points. If you use that as the hypotenuse of a right angle triangle with angles 30/60 degrees, you get: a horizontal run of 166mm or a standard straighta vertical run of 40mm which, when added to the standard 43mm spacing produced by the points gives you a track spacing of 83mm or a half straightThat means all of your runs and gaps are standard length/height and you can connect up a loop running around the top of the platform in your diagram using standard track pieces for the remainder of the loop. I think Hornby should consider adding this 170.76 straight to their range. Link to comment Share on other sites More sharing options...
StuLarge Posted April 12 Share Posted April 12 Not meaning to reignite TT8037 discussion (just happy I found this thread using the new forum search!) Not got either the track pieces or Anyrail to hand at the moment but wondering how the above geometry matches the below. Link to comment Share on other sites More sharing options...
Herbie Posted April 14 Share Posted April 14 They leave a different size gap, but I don't have any platform pieces to see how they compare or look in real life. 1 Link to comment Share on other sites More sharing options...
Moccasin Posted April 14 Share Posted April 14 Just idly playing in rail modeller express and using that 1st radius curve at both ends, a loop is pretty much ok (some minor gaps required in the loop but they do line up) if you use an extended half straight in the mainline and a half straight and quarter straight in the loop. Obviously, a 6th radius curve would work instead of either point,. or you could use an opposing sided point to create a stub/headshunt. 1 Link to comment Share on other sites More sharing options...
StuLarge Posted April 14 Share Posted April 14 Thank you both, greatly appreciated 👍🏼 1 Link to comment Share on other sites More sharing options...
Moccasin Posted April 14 Share Posted April 14 Incidentally, the 2024 catalogue suggests similar 1/4 curves are coming for other radii. One of those might close the gap and align better, as well as being less tight. Presumably the 1/4 R1 is so short that it’s less of an issue for models nominally unable to cope with R1. 1 Link to comment Share on other sites More sharing options...
Fishmanoz Posted April 14 Share Posted April 14 One thing to note here: TT:120 points are “streamline” points with a radius of R6 (compare with OO points which have a radius of R2). However, by adding the 1/4 R1 on the end of them, you are reducing the effective radius to less than R6. Consequently, you may have a little more difficulty traversing this composite than the point on its own. Link to comment Share on other sites More sharing options...
