Postman On The Rails Posted July 16, 2023 Share Posted July 16, 2023 East Mallingford has started well the baseboard at least, other than buy things since March hadn’t made much progress waiting for my Digital Easterner Set, but have Track Packs, Buildings, plank wagons, digital scotsman, Class 08 DB (won’t be running til next year when the 6 pin decoder is released), plus lots of items from West Hill Wagon Works. Next job is the primer coats and the fabric skirt to hide all my boxes. Then some marking out and figuring out where the flyover section will go. Not bad for a first attempt on the base board some slight wonks but I am sure I can easily disguise them. (Photo awaiting approval) Link to comment Share on other sites More sharing options...
Rallymatt Posted July 16, 2023 Share Posted July 16, 2023 Great start Postie… looking forwards to the next updates, a few wonky bits shouldn’t make too much difference as long as track is well laid and flat, after that remember, nature is a bit wonky too 😁 Link to comment Share on other sites More sharing options...
Postman On The Rails Posted July 22, 2023 Author Share Posted July 22, 2023 Top painted and skirt fitted to hide all my toot, will be relocated to a better space. Link to comment Share on other sites More sharing options...
Postman On The Rails Posted August 29, 2023 Author Share Posted August 29, 2023 Main section track now fixed into place, test completed yesterday and had a little play today with Flying Scotsman with MK1 coaches and William Whitelaw with so,è 7 plank wagons. Tried being a cameraman need to improve my skills a bit. Video available on youtube Hornby TT:120 Flying Scotsman & William Whitelaw - Link to comment Share on other sites More sharing options...
taunmarc88 Posted August 29, 2023 Share Posted August 29, 2023 Just watched, looks good. It’s funny how this scale seems normal now once you’ve been exposed for so long. You need a few more wagons, hopefully peco will come through soon. Link to comment Share on other sites More sharing options...
Postman On The Rails Posted August 29, 2023 Author Share Posted August 29, 2023 Just watched, looks good. It’s funny how this scale seems normal now once you’ve been exposed for so long. You need a few more wagons, hopefully peco will come through soon. I know what you mean when my orders started coming through I was like that can’t be it all and yes got TTA Tankers and Coal Wagons on order too. Link to comment Share on other sites More sharing options...
Postman On The Rails Posted September 10, 2023 Author Share Posted September 10, 2023 Redesigned the outer loop, removed 6th Radii curves for 2nd Radii looks a lot cleaner created more space and longer straights. https://postmanontherails.weebly.com/model_railway.html#Sept23Update Link to comment Share on other sites More sharing options...
Postman On The Rails Posted September 13, 2023 Author Share Posted September 13, 2023 Mallard turned up today, luckily on my day off. She is now run in, slight problem with derailment on points in reverse so something to look into. Short video now up on Youtube, the £19 tripod from Amazon was worth the money. Link to comment Share on other sites More sharing options...
ntpntpntp Posted September 13, 2023 Share Posted September 13, 2023 @POSTMAN in that video it looks like the loco has derailed on the curve before it reaches the points. It's a shame the chuff rate is far too slow for the speed the model is running at, as is so often the case with DCC steam sound decoders "out of the box". Hopefully that can be adjusted? Link to comment Share on other sites More sharing options...
Postman On The Rails Posted September 13, 2023 Author Share Posted September 13, 2023 @POSTMAN in that video it looks like the loco has derailed on the curve before it reaches the points.It's a shame the chuff rate is far too slow for the speed the model is running at, as is so often the case with DCC steam sound decoders "out of the box". Hopefully that can be adjusted? Yeah something I will need to look at and another thing to tinker with :o) Link to comment Share on other sites More sharing options...
Fishmanoz Posted September 13, 2023 Share Posted September 13, 2023 By using a complex speed curve. Link to comment Share on other sites More sharing options...
Postman On The Rails Posted September 17, 2023 Author Share Posted September 17, 2023 So we decided to try a laser cut bridge from In The Green Wood for £20. Today we put it together and are very impressed was easy to construct. Just needs a paint job. Only issue is the pieces on the deck are slightly too close together so will need to some engineering fixes to run the track through.https://www.inthegreenwoodlaser.co.uk/tt-br014-single-track-mid-length-bowstring-rail-bridge-tt120-gauge-model-laser-cut-kit Link to comment Share on other sites More sharing options...
Postman On The Rails Posted March 1 Author Share Posted March 1 Wiring now completed after a couple of head scratching days. Slowly coming along with one day a week available. 1 Link to comment Share on other sites More sharing options...
96RAF Posted March 1 Share Posted March 1 I have twin tracks running over the 00 bridge at standard spacing without any problems. Link to comment Share on other sites More sharing options...
Postman On The Rails Posted March 1 Author Share Posted March 1 I was trying to push it in, but later found out you can slide it in without too much issues. 1 Link to comment Share on other sites More sharing options...
96RAF Posted March 1 Share Posted March 1 40 minutes ago, Postman On The Rails said: I was trying to push it in, but later found out you can slide it in without too much issues. I can see the retention lugs in the image. A pity the 00 twin track version doesn't have them to hold the track. Link to comment Share on other sites More sharing options...
Postman On The Rails Posted March 1 Author Share Posted March 1 15 minutes ago, 96RAF said: I can see the retention lugs in the image. A pity the 00 twin track version doesn't have them to hold the track. I am not too sure it serves a structural purpose tbh 1 Link to comment Share on other sites More sharing options...
Postman On The Rails Posted March 8 Author Share Posted March 8 Baseboard now right way up and backboards fitted, more for keeping things on the top than anything else. Time for some testing. 2 Link to comment Share on other sites More sharing options...
ateshci Posted March 8 Share Posted March 8 Yep, especially test how to reach into the far corners when a point becomes balky or a wagon derails at the bufferstop. Link to comment Share on other sites More sharing options...
Postman On The Rails Posted March 8 Author Share Posted March 8 7 minutes ago, ateshci said: Yep, especially test how to reach into the far corners when a point becomes balky or a wagon derails at the bufferstop. Litter pick up stick on hand lol Link to comment Share on other sites More sharing options...
Postman On The Rails Posted March 27 Author Share Posted March 27 Been trying out Rail Modeller Express after watching @GMD video modelled the goods sidings and the freight loop, couldn’t get the gradient element to work how I wanted but will keep trying to get it right. On to modelling the main lines and branches 1 Link to comment Share on other sites More sharing options...
Postman On The Rails Posted March 29 Author Share Posted March 29 (edited) So managed to resolve the last two point motor issues, decided to give Mallard the privilege of completing a good friday track test, some tweaking required and a good clean, but here is a glimpse of the run, also tried out @GMD coal loads which look great. Edited March 29 by Postman On The Rails 3 Link to comment Share on other sites More sharing options...
GMD Posted March 29 Share Posted March 29 Delighted the coal loads work for you. Nice to see the loco getting the beans! What are you using to operate the signal? Link to comment Share on other sites More sharing options...
Postman On The Rails Posted March 29 Author Share Posted March 29 27 minutes ago, GMD said: Delighted the coal loads work for you. Nice to see the loco getting the beans! What are you using to operate the signal? Not fixed them in place but they are fit great and look good. 😊 . The signals are Dapol, they come with a switch already attached and a motor, but I have attached them to peco PL-26 passing contact switches to match the points. They are great as they raise slowly and drop quicker to be prototypical. They need raising slightly as the locos brush them when at danger lol. Link to comment Share on other sites More sharing options...
Postman On The Rails Posted April 21 Author Share Posted April 21 East Mallingford was on holiday last week, MK3 coaches due tomorrow thanks to Hornby CS holding dispatch until we were back. Got some nice pics of European locos on a trip from Salzburg over the border to Berchestgaden in Germany. I think Arnold do a shunter similar to the ÖBB one. 3 Link to comment Share on other sites More sharing options...
