DCC 8 pin issues with Hornby Large Prairie
Warren-368364
I have a DCC Hornby Large Prairie which has run fine for 12months using a Hornby Select controller. The Prairie is now not working properly. All of my other DCC locos work fine,but the Prairie starts and runs for up to about 2 meters and then stops. If I switch of mains power then back on again it again runs for a small distance before stopping. I have re coded it several times but again no difference.when the loco stops there is a slight buzzing noise from the engine. If I put a 9v battery on the wheels the motor runs fine. Has anyone any ideas on how to solve the problem?
According to this SS449B
https://support.hornby.com/hc/article_attachments/360016355420/hss_449b_51-61xx_large_prairie.pdf
The socket is part X7507.
Track this part down, I suggest trying Hornby Customer Services first, then it is a case of unsoldering the old one and soldering in the replacement. The SS shows the socket held in place by 2 screws.
If still under warranty (unlikely as you mention 12 months use in your post), then send the loco to Hornby to do it.
Looking around it is a standard 8 pin DCC socket, now looking at Peters Spares the X7507 is incredibly expensive and out of stock. Hornby for some unknown reason gives them all different part numbers but X9084 part is virtually the same. If you go to New Modellers web site it looks like you want the "L" variant. Looking at the X7507 it looks like it is a 8 pin socket on top of the normal circuit board which usually are very reliable, so check the soldering underneath it. Where they solder the socket to a PCB with large holes you can get issues. It could also be the decoder, that is not unheard of, I normally find another one to substitute. There again you may fix the fault by just taking out the decoder from the socket and pushing it back (it cleans the pins by this action).
Colin's suggestion is a good first step, swap decoders first. If no improvement revert the loco to DC with a blanking plate. These are widely available from the likes of New Modellers, Peters Spares etc. If that doesn't work, go for the decoder socket replacement re P Henny's advice. You will need to be able to use a soldering iron. This is all assuming your track, wheels and pickups are all clean. good luck.
Thanks for the suggestions.I’ve tried using another decoder that runs fine in another loco butI still have the same problem. I’ve tried the other suggestions and the Prairie runs smoothly for about half of a large oval then slows down and stops. Whennstationery there is a slight buzzing noise from the motor. If I remove the power wire from the select then put it back in the loco sets off for half an oval then slows and stops. My other dcc locos work fine.
Does the motor feel particularly hot to the touch. The symptoms you describe could possibly fit with this scenario if it is hot to the touch.
  1. Motor cold, loco runs normally for a lap or two.
  2. Motor heats up and some physical expansion takes place, possibly in the bearings.
  3. Expansion causes drag that slows the motor down.
  4. Drag increases heat, thus a positive feedback loop (heat, expansion, drag) is created.
  5. Motor finally stops, but buzzes because an electrical circuit path still exists.
  6. Power removed, motor starts to cool.
  7. Power reapplied, heat, expansion, drag cycle begines again.
Just a thought.
Excess motor heat could be an indicator that motor windings are starting to break down with a loss of winding turns due to compromised winding insulation bypassing a number of turns, with less turns in a winding then current would also increase further exacerbating the heat creation.
If windings are all sound, dry bearings & drive train (gears etc) could be the culprit.
  • 3 weeks later...
