Steve-353799 Posted October 17, 2023 Share Posted October 17, 2023 Hi I'm going to use the Roco Z21 controller and the iTrain programme. If I want to make the loops a block so that means there's 2, (top and bottom) Does that mean I need to use insulated rail joiners on the inner rails? ( 4 insulated rail joiners )I will be fitting them to the inner rails of the points as indicated by the red arrows.ThanksSteve Link to comment Share on other sites More sharing options...
Rallymatt Posted October 18, 2023 Share Posted October 18, 2023 This thread is more suited to probably the DCC section of the forum, it’s not especially TT:120 scale related and over there you are more likely to get a range of experienced feedback. Link to comment Share on other sites More sharing options...
96RAF Posted October 18, 2023 Share Posted October 18, 2023 There is a guy on RM Web forum (DCC - Computer Control section) who is into iTrain and who may be better placed to answer your question Link to comment Share on other sites More sharing options...
LTSR_NSE Posted October 18, 2023 Share Posted October 18, 2023 @steve - I cannot comment on iTrain, however your diagram suggests that you haven’t completely understood what is meant by ‘inner rails’ in the context of points (particularly in preventing frogs causing short circuits.)In the context of points the ‘inner rails’ (internal rails) are the rails that intersect in a V where the point diverges, otherwise known as the frog.(i.e. inside rail of straight & outside rail of curve.) Link to comment Share on other sites More sharing options...
Steve-353799 Posted October 18, 2023 Author Share Posted October 18, 2023 Thanks guys! Link to comment Share on other sites More sharing options...
