gilbo2 Posted February 18 Share Posted February 18 (edited) In preparation for the imminent arrival of the Legacy Dongle, I've been trying to look for any manuals to get my homework done. I can see a "quick start" in the HM7000 DCC Guides area, but no more detail. I also cannot see much in the Reference Manual, unless I've missed it ! Specifically, the Quick Start says in section 6D, ensure your DCC loco is setup in the app, but doesn't give any more information on what that means. I'm sure its easy when you know, but until then, I've created a (DCC) loco in the engine shed, but how do you make it appear in the control screen, do you just assign the dongle to multiple DCC locos in the shed? Edited February 18 by gilbo2 Link to comment Share on other sites More sharing options...
Brew Man Posted February 18 Share Posted February 18 I've only had a quick scan of the quick start guide but I think you set the dongle up first, then you, (making sure the target loco is on the track) address the target loco by conventional DCC address from the app. More than that I cannot say until I get one in my hands. Link to comment Share on other sites More sharing options...
Moccasin Posted February 18 Share Posted February 18 (edited) The updated text based tutorial was posted by @96RAF in another thread. It provides a more comprehensive guide to setting things up. If you click on the image below it will take you there (click on image and then when it opens, click on the blue contents text bottom right) Edited February 18 by Moccasin Tip on opening tutorial added 1 Link to comment Share on other sites More sharing options...
gilbo2 Posted February 18 Author Share Posted February 18 Brilliant, thanks for that @Moccasin & @96RAF, you have given me the reading I needed Link to comment Share on other sites More sharing options...
SteveM6 Posted February 18 Share Posted February 18 Have a thought for the test team - no manual but fortunately it's reasonably intuitive. Plug the dongle into the Elite, power it on then scan and link to the app - same process as a loco decoder. Using the add new loco button in the engine shed, create a profile for your non TXS loco. Then assign that loco to the dongle and import a profile map from the profile list. The new loco can then be selected and controlled from the app. This can be done as many times as you like with different locos - I'm on around thirty. 2 Link to comment Share on other sites More sharing options...
gilbo2 Posted February 18 Author Share Posted February 18 Thanks for that @SteveM6, sounds like my original assumption on how to use the dongle was too not far off the mark. Sounds all quite straight forward . Next on my list, point control, but we'll leave that one for now Link to comment Share on other sites More sharing options...
96RAF Posted February 18 Share Posted February 18 2 hours ago, gilbo2 said: Thanks for that @SteveM6, sounds like my original assumption on how to use the dongle was too not far off the mark. Sounds all quite straight forward . Next on my list, point control, but we'll leave that one for now Point control is on the to-do list. They are working on consisting next. Consisting by dcc works already in TXS, but they need to generate a phantom MAC address in the app to consist from there. Then they need a more advanced UI for points/signal control to take advantage of the full potential of the HM6010 module. Once that is place then it will read across to control of legacy R8247 acc decoders, as these are essentially the same device apart from the bluetooth capability and box shape/colour. 1 Link to comment Share on other sites More sharing options...
gilbo2 Posted February 18 Author Share Posted February 18 1 minute ago, 96RAF said: Point control is on the to-do list...... Thanks @96RAF for the update, saves me looking for it Link to comment Share on other sites More sharing options...
96RAF Posted February 18 Share Posted February 18 3 hours ago, gilbo2 said: In preparation for the imminent arrival of the Legacy Dongle, I've been trying to look for any manuals to get my homework done. I can see a "quick start" in the HM7000 DCC Guides area, but no more detail. I also cannot see much in the Reference Manual, unless I've missed it ! Specifically, the Quick Start says in section 6D, ensure your DCC loco is setup in the app, but doesn't give any more information on what that means. I'm sure its easy when you know, but until then, I've created a (DCC) loco in the engine shed, but how do you make it appear in the control screen, do you just assign the dongle to multiple DCC locos in the shed? A loco of any persuasion only appears in the control screen ribbon if it has been assigned to a decoder (TXS or dongle if regular dcc) and is Active in the Engine Shed. 1 Link to comment Share on other sites More sharing options...
