RMRED Posted March 15 Share Posted March 15 I have a "London Olympics 1908" train pack, circa 2012, which includes a 4-4-0 County class loco "County of Radnor"., which is still in its DCC eady state. (Recently bought "used" however its pristine!) The instructions are a bit vague or this 73 year old, so could anyone help? First of all, what is the correct decoder for this model? (is it this one: https://uk.hornby.com/products/standard-8-pin-decoder-r8249 ) Secondly, the instructions state that all tender bodies are clip fit, and to remove, pull the body upwards. However I can't remove the body on mine - is there a knack to this e.g. pressing in on the side of the chassis somehow? Should I detach the tender from the loco, if so how? (If there's a video clip somewhere, that I haven't yet been able to find, a link would be appreciated) Thanks - Richard Link to comment Share on other sites More sharing options...
Going Spare Posted March 16 Share Posted March 16 The R8249 decoder will be fine. As to how to access the decoder socket in the tender, body/chassis separation may be being prevented by the two metal handrails at the front which, from previous posts, may have been glued in place at the factory. Without this complication, the body can often be removed by squeezing the front and rear panels thus springing the sides out from their retaining clips, or by inserting a thin flat screwdriver blade between the two at front centre. As you suggest, this is probably better done with the loco and tender separated. There probably is a 4-wire electrical connection between them, terminating in a white plastic plug which sits in a socket in the underside of the tender chassis. Hornby offer a tool to extract this plug, X6468, as it is very easy to cause damage to the plug and/or wires trying to prise or pull it out. When reconnecting, make sure the plug is the right way round. The drawbar may be screwed at both ends or may just slip over a pillar at the front of the tender for easy separation. 1 Link to comment Share on other sites More sharing options...
Brew Man Posted March 16 Share Posted March 16 (edited) What is the 'R' number of the loco, assuming it is a Hornby model? This will people to best advise. Edited March 16 by Brew Man Link to comment Share on other sites More sharing options...
Going Spare Posted March 16 Share Posted March 16 R2980 Link to comment Share on other sites More sharing options...
RMRED Posted March 16 Author Share Posted March 16 6 hours ago, Going Spare said: The R8249 decoder will be fine. As to how to access the decoder socket in the tender, body/chassis separation may be being prevented by the two metal handrails at the front which, from previous posts, may have been glued in place at the factory. Without this complication, the body can often be removed by squeezing the front and rear panels thus springing the sides out from their retaining clips, or by inserting a thin flat screwdriver blade between the two at front centre. As you suggest, this is probably better done with the loco and tender separated. There probably is a 4-wire electrical connection between them, terminating in a white plastic plug which sits in a socket in the underside of the tender chassis. Hornby offer a tool to extract this plug, X6468, as it is very easy to cause damage to the plug and/or wires trying to prise or pull it out. When reconnecting, make sure the plug is the right way round. The drawbar may be screwed at both ends or may just slip over a pillar at the front of the tender for easy separation. Thanks for that, Shame the tool isn't included with the train pack! Link to comment Share on other sites More sharing options...
RMRED Posted March 16 Author Share Posted March 16 5 hours ago, Going Spare said: R2980 Now I know - couldn't find the number on the box! Link to comment Share on other sites More sharing options...
Kristian-353752 Posted March 18 Share Posted March 18 I used a Hornby decoder in my County before swapping it for an HM7000 decoder. I did find it a pain to get the tender body off but managed it without any special tools. Link to comment Share on other sites More sharing options...
