John-357061 Posted April 18 Share Posted April 18 I see a number of threads on the MK3 couplers. I have no problem connecting the coaches together. The difficulty is with the engines. With the other engines I have I can just reverse into a coach and they connect. Is there a trick to it? if I get magnetic couplers, would that help? Link to comment Share on other sites More sharing options...
Dave the Busker Posted April 18 Share Posted April 18 Personally I've found fitting magnetic couplers a huge help for the HST. Not had a single coupling issue with mine since I fitted them, coaches or locos. 2 Link to comment Share on other sites More sharing options...
John-357061 Posted April 19 Author Share Posted April 19 Thanks, the other issue is the coupler just got pulled out, while running. Link to comment Share on other sites More sharing options...
Rallymatt Posted April 19 Share Posted April 19 10 hours ago, John-357061 said: Thanks, the other issue is the coupler just got pulled out, while running. Is that the Hunt or Hornby coupling? Link to comment Share on other sites More sharing options...
BurwellMike Posted April 20 Share Posted April 20 I found the Hunt couplings to be a loose fit (and pulling out) in both power cars but fine in all the coaches which doesn't make a lot of sense as you would assume the sockets are the same. With the standard couplings, once connected, I had constant derailments. Definitely better running with the magnetic couplings (3 HST coaches + the 2 power cars) but still get the occasional derailment on R3 - especially when pushing. All ok on R4. The problem appears to be on the transition from the curve back to the straight. All Hornby track and all Mk1's and steam locos run absolutely fine with no hint of track issues. All kinetic coupling motions seem ok (although I did have to put a spring back - that was an eyesight test!). Close couplings now installed but it was the same with the longer ones. Anybody else have derailment issues with the HST coaches? Link to comment Share on other sites More sharing options...
RHB Posted April 20 Share Posted April 20 I am having the same problem with the Hunt couplings just sliding out of the slots on both the power and dummy cars. Does anyone have a fix for this problem? Link to comment Share on other sites More sharing options...
Rallymatt Posted April 20 Share Posted April 20 You can use a dab of Rocket Card Glue, it’s removable and won’t damage parts. Link to comment Share on other sites More sharing options...
RHB Posted April 20 Share Posted April 20 Thank you for that. I will give it a go. I was worried about warranty issues should items have to be returned to Hornby. 1 Link to comment Share on other sites More sharing options...
