Sailorman Posted April 11, 2021 Share Posted April 11, 2021 Chris that's a generic email and probably sent because a number of duplicate posts were deleted, not cos you mentioned another retailer. It had me wondering last week too!Correct, there were about 4 of each post. It was a bit tricky because there were some replies which quoted the previous comment complete with picture. I think I sorted them correctly. That's why I put the note about submitting once and waiting for a good bit for it to load rather than keep pressing submit. Link to comment Share on other sites More sharing options...
dogsbody Posted April 13, 2021 Share Posted April 13, 2021 Hannants finally got some Beauforts in and I've ordered mine, along with a set of Kits World decals. But, of course, they are all out of the Eduard mask sets!Hopefully, by the time I get to that stage, I'll be able to find a set.ChrisIs there any need to quote the picture Chris? Sorry! Forgot to delete the photo. Sometimes this particular forum works a bit different from what I'm more used to. Chris Link to comment Share on other sites More sharing options...
T2B Posted April 13, 2021 Author Share Posted April 13, 2021 A little more progress being a couple of wing decals, the horizontal tail surfaces secured in place and the exhaust collector rings sprayed. The engines were stained a little before final fitting. Link to comment Share on other sites More sharing options...
T2B Posted April 13, 2021 Author Share Posted April 13, 2021 The 1 piece bomb bay doors were removed ready for disecting, and a the retracted under-carriage parts were assembled and fitted. Well designed with dedicated parts for the retracted option! Link to comment Share on other sites More sharing options...
dogsbody Posted April 17, 2021 Share Posted April 17, 2021 Mine arrived yesterday! Link to comment Share on other sites More sharing options...
Ratch Posted April 18, 2021 Share Posted April 18, 2021 There, no need to panic. Link to comment Share on other sites More sharing options...
Pretty Mediocre Modeller Posted April 18, 2021 Share Posted April 18, 2021 Hi T2B,I've also been making this kit, and am at the stage of being ready to apply decals. The only issues I've had have been removing the small turret fairing for the larger fairing, I took a bit to much off, and had to use filler to repair. Did you notice that the exhaust outlet on each engine was at a different position, one higher than the other? I wonder if that's prototypical, or if it's just me getting it wrong? Link to comment Share on other sites More sharing options...
Kenneth ONeill Posted April 18, 2021 Share Posted April 18, 2021 Well, I read through the instructions (steps 48 to 59 inclusive), looked at sprues C and E, and the rear cylinder blocks C3 and C4, cowlings C7 to C10 and collector rings C5 and C6 are all handed, as are the exhaust stubs E32 and E33, so I'd not be surprised to find a built-in asymmetry. Link to comment Share on other sites More sharing options...
Dominic Thomas Posted April 18, 2021 Share Posted April 18, 2021 I wanted to post a reply to PMM about the exhausts. My first attempt with pictures was rejected, so here goes with the second.I had a problem understanding the exhaust stack location, as a problem with a much earlier release of the model by another well known manufacturer. I then checked numerous, freely available, internet pictures of the real aircraft.Based on a position reference with respect to the top of the undercarriage doors and the upper/lower camouflage demarcation, I concluded that the starboard exhaust was set lower than the port. This is also suggested by a well known 3/4 front view of a 217 Sqn aircraft.I will try to post some pictures which illustrate my suggestions.Hope this helps.Dominic Link to comment Share on other sites More sharing options...
Dominic Thomas Posted April 18, 2021 Share Posted April 18, 2021 Following a send rejection, I will try to post a picture at a time. Let’s see if this works....Starboard side - low exhaust position. Link to comment Share on other sites More sharing options...
Kenneth ONeill Posted April 19, 2021 Share Posted April 19, 2021 Thanks Dominic. That agrees with my thoughts, based on having an unbuilt kit and destruction leaflet literally beside me. Link to comment Share on other sites More sharing options...
T2B Posted April 20, 2021 Author Share Posted April 20, 2021 Hi all, sorry but I've been away for a few days and missed this thread and my modelling but yes the engines are probably slightly over engineered and each part is handed so care must be taken not to mix up parts. And yes PMM I found that the port exhaust stub is slightly higher than the starboard side, and I also noted that the cowling torsion bars are also offset, so no it's not you getting things wrong (unless we both are)! And I too was over enthusiastic with my sanding of the original turret fairing. I am just finishing off my decals tonight .............. Link to comment Share on other sites More sharing options...
dogsbody Posted April 20, 2021 Share Posted April 20, 2021 The port ( left ) side exhaust pipe is at the 3 o'clock position, on the outboard side of the cowling.The starboard ( right ) side exhaust pipe is at about the 8 o'clock position, on the outboard side. As soon as the Mods okay the photo I posted earlier, you'll see what I mean.T2B, those are not torsion bars holding the exhaust collector ring in place. The are just straight solid struts, near as I can tell or have ever read about.Chris Link to comment Share on other sites More sharing options...
T2B Posted April 21, 2021 Author Share Posted April 21, 2021 Torsion bars, struts but thanks Chris, you knew what I meant.But the build continues. Scratched and weathered bomb bay doors added. Link to comment Share on other sites More sharing options...
T2B Posted April 21, 2021 Author Share Posted April 21, 2021 Looks like the website is only accepting single images again so here goes 😕.I should of completed the turret and MG blister earlier but working on them now. Bit of a vague fitting for the blister/MG so will add a brass rod to assist. Torpedo and props done, waiting for final assembly. Link to comment Share on other sites More sharing options...
T2B Posted April 21, 2021 Author Share Posted April 21, 2021 And my last installment for today is the airframe with all decals applied, sealed with a coat of Klear. Weather and assembly on the next update. Link to comment Share on other sites More sharing options...
Ratch Posted April 21, 2021 Share Posted April 21, 2021 As soon as the Mods okay the photo I posted earlier, I have rejected it because it is clearly copyright protected.Post a link. Link to comment Share on other sites More sharing options...
dogsbody Posted April 21, 2021 Share Posted April 21, 2021 Okay! Let's try this photo: Link to comment Share on other sites More sharing options...
dogsbody Posted April 21, 2021 Share Posted April 21, 2021 T2B, that's really looking great. One minor point: perhaps tone down that bright copper colour on the exhaust collector rings. It should look like heat-stained steel instead of a newly minted penny.Chris Link to comment Share on other sites More sharing options...
T2B Posted April 21, 2021 Author Share Posted April 21, 2021 Thanks Chris, and you mean heat tainted stainless steel, and neither is it bright copper. But until the medium I use produce the exact colour, my mix works for me ...... Link to comment Share on other sites More sharing options...
T2B Posted April 24, 2021 Author Share Posted April 24, 2021 The airframe is almost complete. A clay wash has been added then some additional staining followed by a Matt Cote. Link to comment Share on other sites More sharing options...
T2B Posted April 24, 2021 Author Share Posted April 24, 2021 That was the underside, now for a topside view. As can be seen the turret is to be added and an ariel wire. Link to comment Share on other sites More sharing options...
T2B Posted April 24, 2021 Author Share Posted April 24, 2021 The camera is very good at showing up minor imperfections, but not so good at showing the cockpit detail. But take my word for it, the cockpit glasing is very clear so the details can be seen so I'm pleased I spent time painting the interior! Link to comment Share on other sites More sharing options...
T2B Posted April 24, 2021 Author Share Posted April 24, 2021 A further topside view of the airframe. Link to comment Share on other sites More sharing options...
T2B Posted April 24, 2021 Author Share Posted April 24, 2021 Final image for now, of the lower surfaces and staining. It will be my final display images shortly when I can get it finished! Link to comment Share on other sites More sharing options...
