George-351466 Posted April 9, 2023 Share Posted April 9, 2023 I am converting my extensive loft layout from 4 analogue cab control power to HM 7000. Disconnecting wiring and connecting all track to live status is well advanced, but I do not want to cut a section of track out to fit the clunky R 8241 “digital power track”, to connect my new Hornby transformer. Is there a suitable (femail) socket available to plug into the two pin HM7020 psu harness, or do I simply cut off the 2 pin plug and solder onto my existing track connection? Link to comment Share on other sites More sharing options...
P-Henny Posted April 9, 2023 Share Posted April 9, 2023 If you really need an additional track connection with sockets for a Hornby power lead plug, use the R8242 that clips into Hornby track, thus no track lifting and replacement is necessary.Another alternative is to use standard electrical screwdown nylon terminal strip connectors to join the HM7000 power lead 2 pin plug to bare wires i.e. your existing track wires. Link to comment Share on other sites More sharing options...
96RAF Posted April 9, 2023 Share Posted April 9, 2023 I plug my PSU adapter cable 2-pin plug into a suitably sized terminal block, which then feeds 2-wires into one side of a DPDT switch, The other side of the switch feeds DCC from my controller to the layout as required for testing.You could do the same with your existing analogue controller and direct PSU feeds to the layout. Link to comment Share on other sites More sharing options...
Fishmanoz Posted April 9, 2023 Share Posted April 9, 2023 Digital power track (or clip) - for exclusive HM7000 operation, you don’t need to use digital varieties, analog/DC are fine. Link to comment Share on other sites More sharing options...
Goathland Posted April 9, 2023 Share Posted April 9, 2023 A search of the internet will find the correct femail 5.5/2.1mm power barrel jack plug which you would need to solder to the existing wires that connect to your track. This should take the male power plug from your hornby transformer. Ignore the HM7020 psu harness. Link to comment Share on other sites More sharing options...
P-Henny Posted April 9, 2023 Share Posted April 9, 2023 @Goathland.George stated "new Hornby transformer". Hornby digital power packs recommended for HM7000 have 6.3mm/3.0mm plugs not 5.5mm/2.1mm ones.Inline 6.3mm female sockets are literally as rare as hens teeth. Your suggested 5.5mm inline female socket is too small.This size information is also documented on page 16 of the HM7000 decoder manual. Link to comment Share on other sites More sharing options...
Goathland Posted April 11, 2023 Share Posted April 11, 2023 @Goathland.George stated "new Hornby transformer". Hornby digital power packs recommended for HM7000 have 6.3mm/3.0mm plugs not 5.5mm/2.1mm ones. Thank you for the correction. Sorry to put up misleading information. Link to comment Share on other sites More sharing options...
P-Henny Posted April 11, 2023 Share Posted April 11, 2023 Not a problem, you are not the first to not realise the size difference. Particularly as the 5.5/2.1mm is such a common size. It wasn't a case of correcting you, it was more to do with not leading other readers down a costly blind alley. Link to comment Share on other sites More sharing options...
96RAF Posted April 11, 2023 Share Posted April 11, 2023 Hornby are looking at an additional adapter cable with a 5.5mm socket to match the P9000 PSU although these are readily available on the internet as CCTV accessories. Link to comment Share on other sites More sharing options...
Daedalus Posted April 11, 2023 Share Posted April 11, 2023 The P9000W has a 5.5 mm / 2.5 mm plug. Link to comment Share on other sites More sharing options...
96RAF Posted April 11, 2023 Share Posted April 11, 2023 The P9000W has a 5.5 mm / 2.5 mm plug. As you can see this one has a split power pin that allows it to fit 21/2.2mm receptacle. Link to comment Share on other sites More sharing options...
Daedalus Posted April 11, 2023 Share Posted April 11, 2023 Have you tried measuring it?CCTV uses 5.5 mm/ 2.1mm and 5.5 mm/2.5mm! Most vendors stock both. Link to comment Share on other sites More sharing options...
