Nicholas-362701 Posted August 8, 2023 Share Posted August 8, 2023 points burning out around the R8232 electric point clips - I am using a Elite controller - can anybody advise what I am doing wrong please? Link to comment Share on other sites More sharing options...
Fishmanoz Posted August 8, 2023 Share Posted August 8, 2023 Known problem Nîcholas when using circuits carrying a lot of current and the clip and points have become tarnished over time and so the joint between them has increased in resistance. You can try making both spotlessly clean and see how you go but you may need to install a power bus under the layout with soldered droppers from your track pieces to it. Link to comment Share on other sites More sharing options...
LTSR_NSE Posted August 8, 2023 Share Posted August 8, 2023 Could you post a photo or diagram of your layout? Taking particular note to indicate where the power feeds are.This issue with the point clips has been observed by others (especially if the whole layout is powered from a siding!)For power reliability several DCC users choose to electrically wire each track section together using a main pair of ‘bus’ wires. Link to comment Share on other sites More sharing options...
Yelrow Posted August 8, 2023 Share Posted August 8, 2023 Nicholas, nothing except using point clips. Mine got very hot and melted points. Much better with a bus and droppers. Link to comment Share on other sites More sharing options...
P-Henny Posted August 8, 2023 Share Posted August 8, 2023 See this previous post. One of a few also reporting this issue.https://uk.hornby.com/community/forum/track-turnout-clip-overheat-355939?ccm_paging_p=1 Link to comment Share on other sites More sharing options...
96RAF Posted August 8, 2023 Share Posted August 8, 2023 The clips are steel, not a good conductor, couple that with a single power feed and the clips sending that power round the rest of the track. Not a good scenario if you expect to run several trains through bits off bent wire.As a bare minimum use jumper wires to link loop to loop. See the sticky post in the general discussion forum relating to getting started with expansion packs, which deals with expanding tge wiring along with the tracks. Link to comment Share on other sites More sharing options...
