Pendragon Sailing Posted September 3, 2023 Share Posted September 3, 2023 Following on from my recent post about decoder programming issues, I’ve been doing some further research.I’ve seen that Soundtrax produce a Programming Track Booster (PTB100).Has anyone had any experience of using this (or similar) bit of kit, and are they worth the effort/cost?It’s noteworthy that only Soundtrax seem to make one of these (?), so perhaps they’re not as helpful as one might think.Thoughts and observations welcome. Link to comment Share on other sites More sharing options...
96RAF Posted September 3, 2023 Share Posted September 3, 2023 The late Chrissaf used a programming booster, so his musings will be on the forum somewhere. Finding them may be a challenge, try googling the subject and see if any of the hits push you back to the forum. Google being a better search engine than the in-house one.Their use stems from some sound decoders needing a tad more oomph to program them than the NMRA regs permit. Link to comment Share on other sites More sharing options...
Yelrow Posted September 3, 2023 Share Posted September 3, 2023 you need to hope Fishy reads this post. He seems to have no problem digging out these old posts. Link to comment Share on other sites More sharing options...
P-Henny Posted September 3, 2023 Share Posted September 3, 2023 Research a product called "PowerPax", but note that there are other non DCC products out there with the same name.This Google advanced search found these PowePax links on the Hornby forum."PowerPax" site:hornby.com - Google Search Link to comment Share on other sites More sharing options...
Pendragon Sailing Posted September 3, 2023 Author Share Posted September 3, 2023 Thanks Chaps….I’ll take a further look Link to comment Share on other sites More sharing options...
Fishmanoz Posted September 3, 2023 Share Posted September 3, 2023 Paul beat me to it John, and my memory was the same as Rob’s as I read the OP. Link to comment Share on other sites More sharing options...
Bulleidboy Posted September 4, 2023 Share Posted September 4, 2023 Has anyone ever had problems with their programming track? Mine is permanently wired to my Elite and works every time. I may place my hand on the loco so that there is a good contact between rails and wheels. Like the rest of your layout, make sure the programming track is clean. Link to comment Share on other sites More sharing options...
Yelrow Posted September 4, 2023 Share Posted September 4, 2023 Mine also, wired same way. Seems bullet proof. Link to comment Share on other sites More sharing options...
96RAF Posted September 4, 2023 Share Posted September 4, 2023 I have had the Prog output fail on 2x Elites but mine tend to get abused in testing. Link to comment Share on other sites More sharing options...
Pendragon Sailing Posted September 4, 2023 Author Share Posted September 4, 2023 I have absolutely no problems with most of my locos, because they’re fitted with HMDCC decoders and both reading and writing CVs (as we know) is all very straightforward.I’d have to say however, that my experience of using a programming track is mixed. I have a small number of locos using non-sound decoders of various makes and have had a number of issues particularly when READING CVs. Writing CVs seems to be ok (albeit using the POM mode), but reading CVs on the programming track often doesn’t work at all.For running my non-HMDCC locos I use a Digitrax DCS210+ Command Station, which had very good reviews before I bought it and works very well on the whole, but Reading CVs of the following make decoders, simply doesn’t work:LaisDCCDapol Imperium (possibly Lais too?)ESU Loksound v3.5 (factory fitted in a Hornby Class 08).It seems that these cheaper (?) or older decoders can be very temperamental. 😳On the other hand, I have no problems Reading Cvs for decoders made by DCC Concepts/Rails, nor Guagemaster. Link to comment Share on other sites More sharing options...
