Ptolemy -376250 Posted December 28, 2023 Share Posted December 28, 2023 i have a base bord in my mom and dads attic and have prepered it for a layout, however not really sure how i should arrage the track and fit the scenary around it. im going for an idustrialvillage look with back to back houses and maybe a bit of a factory in 00 gauge. i am not planning on taking this to any events and really use it as a hobby inbetween school. i really hope someone can help as no progress has been made this year. im happy to answer any questions as wellPtolemy. Link to comment Share on other sites More sharing options...
atom3624 Posted December 28, 2023 Share Posted December 28, 2023 Maximums of 6' x 3' I see - adequate, but confined.Industrial is a great selection.Check out YT videos of similar - there'll be many, of differing levels of quality and detail, but all should give you a few ideas.Smaller, short wheelbase locomotives will be the mainstay - 0-4-0, 0-6-0 mainly.You'll need to consider:What type of 'industry' you wish to depict.Where this industry would be / what the landscape typical of the area would be.What era - 19th century / Victorian; early / middle, late 20th; modern day.Vehicles - typical of the era.Control is also important - if just starting, I recommend to start with digital / DCC - it gives many more control options.Al. Link to comment Share on other sites More sharing options...
Simmo009 Posted December 28, 2023 Share Posted December 28, 2023 Hello Ptolemy. The bad news is you do not have room for a complete circuit, your boards are too narrow. But you have a nice space for a shunting layout that can be made to look very nice, and means you have to drive the trains from A to B, C or how many sidings you create. There are some good books on layout planning and design on the Peco website, plus the sticky notes at the top of this forum. If you want to use your computer, try SCARM which allows you to use 50 pieces of track for free. Link to comment Share on other sites More sharing options...
P-Henny Posted December 28, 2023 Share Posted December 28, 2023 The 76cm width is too small for an OO layout 180 degree curve.The smallest Hornby Radius 1 requires at least 77cm, whilst Radius 2 requires nearer 91cm. Radius 3 & 4, bigger still - see the Track Geometry link below, noting that the documented radius is measured to the centre of the track, therefore you need to add about 30mm for each width calculation.It is now generally accepted that anything other than short wheelbase modern rolling stock should consider Radius 2 as the minimum radius to incorporate in any OO layout design.The OO Geometry can be reviewed here:https://d63oxfkn1m8sf.cloudfront.net/9216/0086/9107/Track-Geometry-PDF.pdfIf you want to have a layout based on a loop (roundy roundy tail chasing) then you either need to increase the baseboard 76cm width to about 120cm or consider the new Hornby TT120 (TT = Table Top) range of products. This of course assumes that you have not yet purchased any OO products yet. If you are comitted to OO without increasing the baseboard size, then it will have to be an 'end to end' shunting puzzle yard, perhaps with a Turntable for interest.Note: If you do increase the width to 120cm then as there is no rear access, 120cm is too far to reach and a lift out access hole should be included in the middle.P.S. I think member Atom made a slight mathmatical mental calculation error. Your board is 76cm x 174cm (excluding the left hand front extension) this is 2ft 6" x 5 ft 8" not 3ft x 6ft. At these small baseboard dimensions every inch counts.Forum members, so far, have provided fairly long replies. It would be appreciated if any replies that you make are done using the 'Reply Text Box' at the bottom of the page and not via the 3 dot 'Quoted Reply' menu option. Link to comment Share on other sites More sharing options...
Simmo009 Posted December 28, 2023 Share Posted December 28, 2023 Here is a picture of my shunting layout, Nudge Nudge. It is just under 180cm / 6ft. I use a Class 25 locomotive with it. It is DCC controlled, and uncoupling is with magnets so it is hands free. It is a puzzle, where you have cards to make an order to manoeuvre the wagons into to win. There are several thousand combinations. Link to comment Share on other sites More sharing options...
Tony57 Posted December 28, 2023 Share Posted December 28, 2023 HiOut of interest what is your board made out of? is it on a frame with cross bracing?What type of railway are you planning, is it end to end (Terminus to fiddle yard) or a tail chaser?Is the village at the side of the railway or does the railway go through it or does the railway terminate in or by the village?The factory does it have a feed from the railway, raw materials in, finished goods out.Once clear in your mind what type of layout you would like to make dry lay the track first, try pushing a few trucks or a coach around on the track to see if the track layout works.Once happy with the track layout, think where the building will sit and plan where the roads go also where and how they cross the railway tracks (if they do) Only then start to think of the integration of the landscaping work. Link to comment Share on other sites More sharing options...
ModelerXYZ Posted December 28, 2023 Share Posted December 28, 2023 Hi Ptolomey. Welcome to the forum.As stated, the board is too small for a complete circuit, however if you want to do industrial scenes, that may not be a problem. Unfortunately tight curves are the order of the day. It is possible to do an end to end layout. Tight but possible is a short branch with a run around loop each end, you wouldn't need much rolling stock. Don't forget keep it fun. XYZ Link to comment Share on other sites More sharing options...
Ptolemy -376250 Posted December 28, 2023 Author Share Posted December 28, 2023 @atom3624 I am looking at maybe a coal or steel industry like the ones in the midlands UK so maybe a coal pit or a factory with an obvious steel works design around it.i think I will be looking at 19th century and so between 1850-1900 ish. Link to comment Share on other sites More sharing options...
ellocoloco Posted December 28, 2023 Share Posted December 28, 2023 Ptolemy - when your folks aren't looking, could you not sneak another 8' by 2' board behind the trusses on the right hand side of picture three? This would give you space for a decent circuit. Use it for storage tracks and have industry/stations etc on the boards shown.Look forward to seeing your progress. I started a layout in my parents attic and managed to get the first circuit down before we moved house and country. 30yrs later, I'm about to start again!Have fun.(If you haven't already, build yourself a cover for the loft access hatch to put in place once you are in the attic. It can prevent any unplanned trips to the main house!) Link to comment Share on other sites More sharing options...
atom3624 Posted December 28, 2023 Share Posted December 28, 2023 The main thing, we're just giving you suggestions / ideas.Just like that classic quiz show Blankety Blank (!!!) you can do completely your own thing - it's your layout.Think a little of what you want from it. Do you want complete 'hands on' whilst it's in operation, or perhaps a bit of continuous movement? If the latter, as mentioned, space is too confined for the curve geometry / chassis design so see if a little more room could be made .... or .... (sorry Hornby) consider another scale.Not certain what's available in 'TT', but N-scale could serve you pretty nicely!Al. Link to comment Share on other sites More sharing options...
ModelerXYZ Posted December 28, 2023 Share Posted December 28, 2023 This would be the sort of thing I would do.XYZ Link to comment Share on other sites More sharing options...
Ptolemy -376250 Posted December 29, 2023 Author Share Posted December 29, 2023 I have been able to convince my dad to add a tiny bit on to the one side so it now will look like this sorry it’s a bad drawing but you should get the intentions. The blue dashed line is the area he is going to allow me to add.ptolemy. Link to comment Share on other sites More sharing options...
What About The Bee Posted December 30, 2023 Share Posted December 30, 2023 Hi PtolemyAs Ellocoloco mentioned, adding to your board, as shown here in pink, permits room for a Radius 2 180° turn, yellow arrow. It expands into a dead space so your Dad may be more amenable to the idea.Bee Link to comment Share on other sites More sharing options...
M. Matthews Posted December 30, 2023 Share Posted December 30, 2023 If you haven’t already invested money in 00, I think I’d suggest going down the TT:120 or N scale route. Even 009 might suit what you’re looking for. Link to comment Share on other sites More sharing options...
Ptolemy -376250 Posted December 30, 2023 Author Share Posted December 30, 2023 Thank you everyone for the great ideas and advice and this forum has really helped me with my layout I have now taken the advice on board (no pun intended) and I have come up with a layout plan and I will be posting it once the new board is in place at the closest edge and I have played the track down. These ideas have been really useful to me as it as been over a year since I got my first train and I am just now working out the perfect layout for me at the moment. I'm sure if we all carry on working together on this slightly challenging project as some of you have phrased it as it will come out in a way that pleases myself and I hope that you will cary on helping me with my model train adventure.Ptolemy. Link to comment Share on other sites More sharing options...
Simmo009 Posted December 30, 2023 Share Posted December 30, 2023 Ptolemy, one more thing to remember. Make sure you put track where you can reach anything that might derail. Seems obvious but is often overlooked. Post pictures as you progress. Link to comment Share on other sites More sharing options...
Ptolemy -376250 Posted December 30, 2023 Author Share Posted December 30, 2023 No I don't think it is obvious I spent the first year fetching trains from the most awquard of spaces so its lucky you said this and I will make sure to keep all you posted on any progress that I make. Link to comment Share on other sites More sharing options...
LTSR_NSE Posted December 31, 2023 Share Posted December 31, 2023 @ptolemy - in case it is helpful, the first lesson I learned from running a loco on a layout raised off the floor, is the need for barrier edges.Derailments (and incorrectly adjusted controllers) can otherwise lead to sudden unintended downward trips! Link to comment Share on other sites More sharing options...
Ptolemy -376250 Posted January 1 Author Share Posted January 1 Happy new year to all of you. I was wondering what balas you would suggest using for my track now I have sorted the laout i will be posting pictures but haven't got round to taking taking them yet due to family commitments. Ptolemy. Link to comment Share on other sites More sharing options...
What About The Bee Posted January 1 Share Posted January 1 PtolemyBefore you run off and ballast your track, may I suggest you have a play with the new layout?Find out what parts of the layout you like. Determine what parts you do not. Change the track to be more to your liking.Of course, if you haven't laid the track, do that first. If you have the track laid, but it isn't wired, do that as well, even if only temporarily (wires exposed). Ballasting your track will change the way the layout looks, but does not change the way the layout works. The layout should work to your preferences before you ballast.Bee Link to comment Share on other sites More sharing options...
