Class 50 locomotives
Mulsanne88
I suggest that CCL Logistics need some different sized shipping boxes. Some “Fragile” stickers wouldn’t come amiss to stick on the outer package either. Seems pointless only having a Fragile label on the inner box, where it can’t be seen.
  • Like 2
Last time I had a couple of things delivered it was comical. One box was perfect size for the Hornby box so no space for any bubble wrap and the Stanier full brake coach was in a box I could almost get into! The fragile sticker on the inner box is not that helpful. Hopefully all these issues will soon be ironed out as Mike Ashley wields the corporate stick.
I feel somewhat embarrassed to ask this 😊 but which way round should my ZIMO MN180N decoder be fitted?  Been searching around and not clear to me which is "Pin1". If I fit one way then I get no Domino lights but a flickering high intensity light and tail lights. If I fit the other way round then the Domino lights work but no tail lights. Loco runs fine in both instances, and all was fine on DC. I suspect I need to set some of the lighting functions but can only address functions 1-10 on my control setup at present (an old Digitrax Zephyr). Any guidance appreciated. Thanks.
The large arrow on the pcb indicates which way the main part of the decoder should go. Basically opposite to how it’s shown in the photo, and other way up. Any reason why you don’t use a mm HM 7000 sound decoder and use free app to set up then switch to DC?
Thanks Matt, the orientation is what I thought but good to get confirmation. To answer your question, legacy and habit I suppose, and cost. I have had the Zephyr for many years and Digitrax  is our Club standard. I've used Zimos in my OO locomotives and so have followed suit in my TT120 endeavours (to a degree, I have RoS decoders in some locos). The Zimo/Lais combination is particularly effective in my two Class 08's. Haven't really "bought in" to the Hornby HM7000 yet.
  • Like 1
Posted (edited)
I drive via a traditional DCC system, currently Dynamis but limited function access is a pain. HM DCC decoders are full DCC decoders and the app is like falling off a log with setting up, so so easy. Then flip to DCC and away you go. I really recommend getting 1 decoder and trying it. I love my Zimo decoders too but HM DCC ones are so user friendly.
Edited by Rallymatt
  • Like 1
Posted (edited)
Hmm...food for thought 😉 ... I have a Class 66 on order so what you're suggesting is that I fit an HM decoder and set it up via an App via Bluetooth on my phone. I can then run it as normal using my Zephyr? The penny might just be dropping 🤪...feel I'm very late to the party.
Edited by Renoir
Additional comment
Yes exactly, try 1 decoder, if you don’t like it I will buy it off you for what you paid, I am that confident. They work as a regular DCC decoder but they can also work via Bluetooth. The magic is the App and Bluetooth together for tuning the settings. Drop any free sound file in you like. Change it as many times as you like. Calibrate the profile to the motor, it’s a powerful system .
  • Haha 1
I’d pop on in the 50 and see what you think. I run the 50 Profile on a BR130 (Ukrainian built soviet era loco) it’s awesome, check some of my videos of it. I love the cold  start sequence 😁
14 hours ago, Moccasin said:
Well the Class 50 is running in but seems rather slow and noisy at half speed on the HM7000 app. Sounds like it has an angry wasp trapped inside.
Mine was the same. I adjusted the vMid in the cv editor and that made a difference but not sure that’s right to do that. And of course that’s using the app for control. It also wobbles quite a lot on first pull away when it’s been sat for a while and after power has been off.
HM7K decoders can self calibrate if motor control is a tad awry. A simple procedure carried out on a clear track. Ensure F0 (lights) is off as this is the starting gun. Set CV149 to value 0 in the app. Press F0 and the loco will race off at max chat for about 1.5-2m then stop. Job done. CV149 will now show value 2 and the associated motor PID settings will have been adjusted. Your loco should run much better.
Edit to amend CV148 to CV149
  • Like 1
  • Thanks 1
My Edward ran fine on DC prior to fitting the chip
Then on DCC the sound worked, as did lights and horn but as soon as I tried to move off , all lights started flickering madly and I got an over current message
I assume that’s a back to Hornby job, or does anyone have any ideas
Chip is fitted correct way round
9 minutes ago, Postman On The Rails said:
Have you tried a different chip?
I thought of that but I am reluctant to mess about with locos that are currently running ok.
I will talk to Hornby tomorrow and suggest that I keep this chip fitted so that they can assess it
Posted (edited)
Before sending it back I would remove the chip and try it again on dc to make sure it's not something that's happen to the loco while installing the decoder
Edited by Rog RJ
It does run back on DC but…
When running in either direction the rear lights light up but also the front lights flicker on and off at the same time. At the other end front lights are fine
Well the wait and the excitement were well rewarded. What a beautiful model and can sit listening to it on tickover all day! Combination of easy set up on Bluetooth then seamless transfer to the prodigy WiFi set up I use on my layouts was so easy. Feel a second one for renumbering is now required!
  • Like 7
