Jay 1707822856 Posted May 6, 2022 Share Posted May 6, 2022 Good Evening All Hope you are all well.I've returned to the hobby after a 20 years or so break. Currently working on a Victory starter set to test how much I can remember and do some valuable practice. Before moving onto something a little bit more demandingI was wondering if anyone could give me some advice on the following Is there any of the following -water basedsolvent free low ouder poly cement/superglue on the market that is airfix friendly as currently when I'm doing construction I would like to avoid the fumes from the poly cement I currently use.I do have a window open and currently wear a vapour/fume filter mask But I can say it's not the most comfortable when wearing for a period of time especially as the weather gets warmer Any advice or tips would be greatly appreciatedThanks Jay Link to comment Share on other sites More sharing options...
Ratch Posted May 7, 2022 Share Posted May 7, 2022 The only glue I can think of that comes near to your spec is PVA. It will not work as well as poly cement/precision poly because the poly glues weld the plastic of the kit together. The PVA joint will not be permanent. I often use PVA on canopies because it will not fog the clear plastic. I also use it as a temporary fix - to hold something in place while I paint, but want to remove later. Link to comment Share on other sites More sharing options...
Kenneth ONeill Posted May 7, 2022 Share Posted May 7, 2022 Er, you actually need a solvent glue to get a good bond on styrene. On that basis, your best bet for a "solvent free environment" will be a Fume hood - Wikipedia so that you can work in it, and blow the solvent fumes out of the building.With the note that I've never tried it, Gorilla Glue PVA gets a good reputation in some circles. Link to comment Share on other sites More sharing options...
peebeep Posted May 7, 2022 Share Posted May 7, 2022 The only option I can think of other than PVA is Tamiya Limonene. It's neither water based nor solvent free, but it is made from natural (extracted from citrus fruit) products.https://www.tamiya.com/english/products/87113limonene_cement/index.htmhttps://www.amazon.co.uk/Tamiya-40ml-Limonene-Cement-87113/dp/B002TZ6K4Y Link to comment Share on other sites More sharing options...
Jay 1707822856 Posted May 7, 2022 Author Share Posted May 7, 2022 Thank you for your replies greatly appreciated. I have seen a mini airbrush hood which may be good solution/aid as it has mechanical ventilation. Does anyone have any first hand experience of what these are like? Just remember when I last did airfix I never had a issue with the fumes from the poly cement or other glues Thank you Jay Link to comment Share on other sites More sharing options...
Kenneth ONeill Posted May 8, 2022 Share Posted May 8, 2022 I wouldn’t recommend ova in any form with polystyrene. Liquid polystyrene is least smelly especially if you keep putting top back on. A long time ago I used in a professional capacity another solvent for styrene but that was industrial use and had other health issues if used incorrectly so won’t even name it as you seem very against such materials.Good luck trying modelling in polystyrene without some odours though.I can guess - Alpha Bravo Sierra cement? Link to comment Share on other sites More sharing options...
Ratch Posted May 8, 2022 Share Posted May 8, 2022 Sounds like Methyl Ethyl Keytone (MEK) Link to comment Share on other sites More sharing options...
Frederick Kullas Posted May 9, 2022 Share Posted May 9, 2022 you can buy odour free superglue Link to comment Share on other sites More sharing options...
Jay 1707822856 Posted May 9, 2022 Author Share Posted May 9, 2022 You don’t say if it is for health reasons or you just don’t like the smell of the glue. Hi Yes it's due to the glue fumes can give me headache.I do understand where you are coming from regarding the hobby When I was younger I never had an issue at all but as we get older things can change I only paint in acrylic paint via hand painting as I find this very relaxing and rewarding. I may post a photo of my latest model Thank you to you all for the replies it's greatly appreciated for your advice and time I will take a look at the Tamiya limonene glue Kind Regards Jay Link to comment Share on other sites More sharing options...
Ratch Posted May 10, 2022 Share Posted May 10, 2022 Simple things like keeping the cap on will minimise the time you're exposed to the fumes. Also, try a needle applicator - Precision poly - if you haven't already. Link to comment Share on other sites More sharing options...
Jay 1707822856 Posted May 22, 2022 Author Share Posted May 22, 2022 Simple things like keeping the cap on will minimise the time you're exposed to the fumes. Also, try a needle applicator - Precision poly - if you haven't already. Hi Ratch I think I've found a solution with the use of a mask, would it be okay for me to post here what it is and a photo. Is there anything i should be aware of before posting / maybe including a photo Kind Regards Jay Link to comment Share on other sites More sharing options...
Ratch Posted May 22, 2022 Share Posted May 22, 2022 Hi Jay, you can post pictures, but they will be held until approved by a Mod (so only click the submit button once please), Link to comment Share on other sites More sharing options...
Jay 1707822856 Posted May 28, 2022 Author Share Posted May 28, 2022 Hi All please see a solution that has worked for me due to the fumes for the glue when building my airfix modelsI have been using this for a few weeks now and haven't experienced any issues since using this I have taped over the brand names as I was unsure if you can display them in photos on the forum unless a moderator can confirm as I can mentioned that in another reply please note the mask is a larger mask (excluding the filters) as most are sold as medium size as standard I know some may go that's a good idea or wow that a bit much but do hope it may help someone but obviously please do your own research and decide on what works for you the filters are not standard filters, the ones fitted are designed to filter out organic and in organic fumes/vapours to a certain level Cheers Jay Link to comment Share on other sites More sharing options...
Jay 1707822856 Posted May 29, 2022 Author Share Posted May 29, 2022 Hi JayGood luck to you in your hobby. Your dedication commendable. I think it would put me off pastime. Right now I am having problems with my drive with hobby. I know I would be bored senseless if I didn’t have this past time and that is what keeps me going, that and having a stash that my stingyness keeps me going, hate to have wasted the money. This coming year the stash will be what I will be relying on, only buying glue etc when needed.Anyway, good luck and hope you continue to enjoy yourself.Rod I found having a few hobbies over the years keeps me busy. In late spring, summer and early autumn I usually like to go fishing and if the weather's bad as a typical British summer can be I drop back onto my airfix Have you ever tried or seen flying tying for a hobby? You can copy well know or unknown patterns or make your own and see what works Cheers Jay Link to comment Share on other sites More sharing options...
Jay 1707822856 Posted May 29, 2022 Author Share Posted May 29, 2022 Thanks Jay, can you believe I have never fished in my life and wouldn’t know where to start. Working on my fitness recently. As for modelling just need some incentive for new ideas for the models in my stash. Not reading enough. That and a good kick up the rear to get me going. I can’t fly so aircraft models my only connection now.Thanks for suggestions though. Can always give it a whirl, visit your local tackle shop or watch a few videos online for beginners guides. I recommend start with small fish (silvers) down the canal, stream or river or what evers local to you and see how you go from there its how I started a long time ago First ever fish was roach on the canal or cut as they are called that in my local area. Favourite species is a perch or tench. Believe me catching all day or catching absolutely nothing is so enjoyable just being outside watching the nature or the world go by Just a tip remember to buy a fishing licence as if your caught without one it can result in a trip to court and/or a hefty fine happy to give advice Cheers Jay Link to comment Share on other sites More sharing options...
