Help needed with fitting a decoder to R1271 iTraveller Train Set
Michael-370015
I am led to believe through my own Google research that the small cheap shunter type loco in this set is not 'DCC Ready' and does not have a socket. If true, then this loco would need to have a decoder diy fitted to it which would require the use of wiring skills and the use of a soldering iron.
Plus, if the 4 wheel loco type in this set was to be 'DCC Ready' it would normally be a 4 pin socket and not an 8 pin socket that you have suggested in your question.
If during your research you have seen the term "DCC Compatible" used rather than "DCC Ready". Then this confirms that no decoder socket is present. DCC Compatible just means that the loco is suitable for DIY conversion to DCC not that it has a decoder socket.
As stated above the HM | DC app driven iTraveller set is for analogue locos, no need for a decoder. The traditional controller is replaced by an HM6000 module which drives two loops of track like an analogue controller but via an app on a handheld device.
If you really want to install a decoder to run it under DCC control you need to refer to the Hornby guides, either hard wired or install a socket.
