Paul Derbyshire Posted December 11, 2023 Share Posted December 11, 2023 I have two locos fitted with HM7000 modules. One runs in the right direction as fitted the other is in a Hornby doc ready class 67 and that runs in reverse (lights also) as fitted. I’ve tried changing cv29 bits 1 and 2 but they make no difference when under Bluetooth control. However, if I switch to dcc and use my hornby elite, the loco performs correctly. I’ve tried both modules in both locos and the same thing happens in all cases. Change CV29, no effect when in Bluetooth mode but works correctly when in DCC. Any ideas? Link to comment Share on other sites More sharing options...
96RAF Posted December 11, 2023 Share Posted December 11, 2023 It’s a known glitch in that using the app to change CV29 doesn’t stick. It is being fettled, but in the meantime ensure you are using the latest profile version. Link to comment Share on other sites More sharing options...
Pendragon Sailing Posted December 12, 2023 Share Posted December 12, 2023 Paul, if you switch the loco to DCC (rather than Bluetooth), you can then change CV29 Bit 1 on your programming track (or in POM mode) using your normal DCC controller. The change then ‘sticks’ when you switch back to Bluetooth running. Link to comment Share on other sites More sharing options...
96RAF Posted December 12, 2023 Share Posted December 12, 2023 If having done as Dragon suggests you look in the Advanced CV editor the CVs are likely to be out of synch and need updating in the app to match the decoder. Link to comment Share on other sites More sharing options...
John-375749 Posted December 22, 2023 Share Posted December 22, 2023 Has anyone managed to resolve this issue?I have just purchased the Hornby Turbomotive sound loco (R30131TXS) fitted with the HM7000TXS-21 Decoder but the direction is reversed under both Bluetooth and DCC controller.I managed to change CV29 using Decoder Pro in DCC mode from 2 to 3 (Bit 0) and the DCC controller direction is now correct but Bluetooth is still reversed and I am not able to change the value of CV29 using the app but it does show the updated value.When I look at CV29 in the app I cannot change any of the sliders for the different 'bits'.Any help in resolving this matter wil be gartefully apprfeciated.John BicknellLancashire Link to comment Share on other sites More sharing options...
Pendragon Sailing Posted December 22, 2023 Share Posted December 22, 2023 Hi John,Rather than using Decoder Pro can I suggest you try changing CV29 Bit 0 using your usual DCC controller and the POM method. I find that the change then sticks in both DCC and Bluetooth. Link to comment Share on other sites More sharing options...
96RAF Posted December 22, 2023 Share Posted December 22, 2023 Update the sound profile as the factory load is now likely to be out of date.See latest version listing noting v1.4.0 fixed the CV29 glitch.https://uk.hornby.com/community/forum/latest-sound-profile-status-367898?ccm_paging_p=1#end-of-replies Link to comment Share on other sites More sharing options...
John-375749 Posted April 11 Share Posted April 11 This direction changing still seems to be a problem as I have just fitted a Next 18 HM decoder to a Model Rail Class 11 diesel model and it is behaving the same as for the turbomotive loco fitted with a 21 pin decoder in that: In Bluetooth mode using the app the direction is correct with cv29 = 2 but changing to DCC mode the directions are reversed using my DCC controller. Changing CV 29 = 3 using mmy DCC controller in program mode sorts out the DCC direction but then it is reveresed when switching to Bluetooth mode using the app! I have downloaded and installed the latest version of ther profiles for both the Class 11 and the turbomotive. How many members of this forum have expereieced this issue? Link to comment Share on other sites More sharing options...
LTSR_NSE Posted April 11 Share Posted April 11 @John-375749 - what DCC controller are you using? From your description, that is not the issue that this thread is about. Original issue was that the app failed to read/respond to CV29 changes & therefore direction within app couldn’t be changed! What you are describing is that the app & your DCC controller are setup to use opposite directions. Link to comment Share on other sites More sharing options...
