DCC converted R410 turntable
Nick-376669
No ... use a locomotive decoder R8249. Firstly a loco decoder allows you to drive a TT in both directions. Secondly, a loco decoder allows you to control the rotation speed. Neither of these desirable features are available to you if using a R8247.
I suggest you read the FAQ 3 TT DCC Conversion instructions in the 'DCC FAQ Index' pinned sticky thread. Although written for a R070 TT, the same principles will apply to the R410 TT. Which describes in detail, the best method for connecting a Hornby TT to a DCC Powered layout track.
The R8247 is not really suitable to control the rotation of a Hornby TT as each port output is only around 150mA and driving a TT motor both ways would likely require diodes fitted in the circuit.
The HM6010 module however has a dedicated 500mA output port, but the output is a set speed and in one direction only, so not that versatile.
My R070 TT is converted to DCC use per the guide linked to earlier and a simple basic decoder allows the table to be driven in either direction at a variable speed of choice. Such a set up is ideal for use with train operating software such as RM or TGG, etc.
........and driving a TT motor both ways would likely require diodes fitted in the circuit.
I did wonder myself it that was feasible, and before posting my earlier reply sketched out a number of different diode connection configurations, using just diodes on their own. In every case, the diode circuits resulted in one of the diodes creating a path between the common C and one or other of the switched negative outputs .... result ... a 'short circuit'.
However add a couple of transistors and bias resistors to the diode circuit to control switching and a feasible motor polarity reversing circuit can be built to work with a 3 wire Accessory Decoder.
See circuit schematic link below:
Datei:Motorweichenadapter.png - Digital Modellbahn
But this should be treated as just an academic exercise because it is just simpler, cheaper and more effective & efficient to use a loco decoder.
The circuit above is actually sold as a ready made product by 'DCC Concepts' to convert 3 wire Solenoid point motors to 2 wire reversing motors.
DCC Decoder Converter 3 Wire to 2 Wire (3 Pack)
EDIT: The R8247 Accessory Decoder would also have to be configured with a defined pulse length as using 'Always On' would be continuously driving the TT in one direction or the other and never stop. The need for a pulse length configuration then gives the issue of how long do you make it. Again a loco decoder overcomes this issue, as it is a simple matter to stop and start the TT motor at any time that is necessary for the number of track inputs that have to be traversed.
