Christopher-344761 Posted March 4 Share Posted March 4 I’ve added several locos using legacy dongle on my DCC layout. (Simple 8 pin decoders4 function) used. It works well, however, The app states they are all unregistered, Does this matter? They all have the same decoder setup code for Bluetooth, Is this the type of decoder installed? Yes, I know nothing 🤓 Link to comment Share on other sites More sharing options...
96RAF Posted March 4 Share Posted March 4 56 minutes ago, Christopher-344761 said: I’ve added several locos using legacy dongle on my DCC layout. (Simple 8 pin decoders4 function) used. It works well, however, The app states they are all unregistered, Does this matter? They all have the same decoder setup code for Bluetooth, Is this the type of decoder installed? Yes, I know nothing 🤓 Not a single one of your questions makes sense, The app does not register your existing decoders. Screen shot that dialogue and post here. If by decoder setup code you mean the decoder DCC address then you need to program each of them from your DCC controller with unique addresses. If you mean they are all assigned to the same dongle that is correct. If I have misunderstood your problems then please clarify as I also know nothing not being able to look over your shoulder as you try to do this. Link to comment Share on other sites More sharing options...
gilbo2 Posted March 4 Share Posted March 4 Where are you seeing 'unregistered', I'm not seeing it on mine. Can you post a screen shot? Link to comment Share on other sites More sharing options...
96RAF Posted March 4 Share Posted March 4 20 minutes ago, gilbo2 said: Where are you seeing 'unregistered', I'm not seeing it on mine. Can you post a screen shot? I already asked for that. Link to comment Share on other sites More sharing options...
Brew Man Posted March 5 Share Posted March 5 Shouldn't this thread be in the HM DCC forum? Link to comment Share on other sites More sharing options...
Christopher-344761 Posted March 5 Author Share Posted March 5 Sorry if in wrong forum and it shows unassigned not unregistered and again realised the code I refer to is the dongle so they are all using the same dongle. presume you can only use profiles if using sound DCC chips like TTS etc thank you all for comments Link to comment Share on other sites More sharing options...
Brew Man Posted March 5 Share Posted March 5 No, you can assign non-sound decoders to the dongle too. Note there are no sound profiles for TTS decoders, only function maps. Link to comment Share on other sites More sharing options...
gilbo2 Posted March 5 Share Posted March 5 The "Unassign" is merely a button to press if you want to remove that loco (unassign) it from the Dongle is this case. It will then drop down into the "Assign Another Vehicle" section and the red text there would disappear. Similarly, if you create a new loco in the Engine Shed which is unassigned, it replaces that red text. The TTS profiles are only a function map for a particular TTS loco. Have a look at this post which provides a work around for using them: https://community.hornbyhobbies.com/topic/35286-hm7000-dongle-nice-piece-of-kit/#comment-376146 Link to comment Share on other sites More sharing options...
