Ratch Posted May 19, 2015 Share Posted May 19, 2015 Painted up as HMS Rodney Link to comment Share on other sites More sharing options...
Rael Posted January 21, 2016 Share Posted January 21, 2016 I picked up this set in new condition for £6 ata a charity shop. Its a great build. Link to comment Share on other sites More sharing options...
KiwiKev Posted December 21, 2021 Share Posted December 21, 2021 I must admit to having not being such a fan of the Rodney and Nelson due to their cut down appearance and slow speed, but now I have looked at the 1:600 model parts, and pictures of a 1:200 Trumpeter kit for comparison and detail, they're definitely growing on me.I will have to order the photo etch for Nelson, but in the meantime I've started removing and replacing the 1 mm thick breakwaters with thinner styrene sheet. This will probably be a slow burning project as I'd like to replace all the gun position and bridge bulwarks and shields for the same reason, 1 mm thick is way too clunky and equates to 2 feet thick walls in actual size.There is a ton more detail that can be added to the decks but for once I will try to build and paint these tiny parts mostly separately, and then glue them on once the decks are painted. This will reduce the amount of masking needed on a highly detailed deck, such as on the KGV model, so maybe the relatively sparse detail currently on the decks will end up being an advantage. Link to comment Share on other sites More sharing options...
Sailorman Posted December 22, 2021 Share Posted December 22, 2021 I'll be following this build. Nelson was always one of my favorites. This is my own build of the Airfix kit. It looks so good as a waterline! Link to comment Share on other sites More sharing options...
KiwiKev Posted December 22, 2021 Share Posted December 22, 2021 I'll be following this build. Nelson was always one of my favorites. This is my own build of the Airfix kit. It looks so good as a waterline! Link to comment Share on other sites More sharing options...
KiwiKev Posted December 22, 2021 Share Posted December 22, 2021 Beautiful work. I see you've added some pillars in the bridge openings which is nice. Interesting to see that you haven't included the bridge windows in the forward surface of the superstructure, which apparently the ship did have, and is depicted on the box art but not on the actual model. I suspect the forward flat surface might be a little too narrow, and I'm thinking of a 0.5 mm insert to give it slightly more width.As I mentioned, I'm looking at a 1:200 model featured in the 2018 modelwarships gallery made by one of the gun modelers. It's a really easy way of researching detail as the pictures are clear and from all the angles you could ask for. But I'd be happy with yours!! Maybe I should waterline too as then I won't have to add the yet again missing bilge keels. However all my other models are full hull, so will probably stick with that approach for now. Link to comment Share on other sites More sharing options...
Sailorman Posted December 22, 2021 Share Posted December 22, 2021 Beautiful work. I see you've added some pillars in the bridge openings which is nice. Interesting to see that you haven't included the bridge windows in the forward surface of the superstructure, which apparently the ship did have, and is depicted on the box art but not on the actual model. I suspect the forward flat surface might be a little too narrow, and I'm thinking of a 0.5 mm insert to give it slightly more width.As I mentioned, I'm looking at a 1:200 model featured in the 2018 modelwarships gallery made by one of the gun modelers. It's a really easy way of researching detail as the pictures are clear and from all the angles you could ask for. But I'd be happy with yours!! Maybe I should waterline too as then I won't have to add the yet again missing bilge keels. However all my other models are full hull, so will probably stick with that approach for now.Don't read too much into my build. I mostly used a four page colour foldout (Plan and Elevation) from a book called the Encyclopedia of the World's Warships. It was a very detailed large scale drawing ...circa 1:350 but I didn't delve deeply into the info available on-line. I'm sure yours is going to be better! Link to comment Share on other sites More sharing options...
KiwiKev Posted December 30, 2021 Share Posted December 30, 2021 A rough attempt at etching in some hull plating lines has been made. I think the tools will need upgrading for next time. Not sure how well it will show after painting but hopefully a light wash will accentuate the lines. I was going to paint the deck first and then add the extra detail, of which a lot is needed, but I may go back to the usual plan of gluing on all the small vents, cabinets etc.... then masking off or hand painting around them. There are at least 20 Carey floats needed. I'll have a go at scratch building as I can't see them on the PE advertisement and even if they were there they'd be pretty flat. I've built a template to bend some thin copper wire into shape for the buoyancy chamber, and either paper or thin styrene will be glued on to that as a base. I'm looking enviously at later models like KGV and Belfast that already have them.A slow and tedious mission is to attempt to get the first level superstructure deck perfectly flush with the superstructure wall, so that there is no hint of over-hang or recess. It's a common problem with these older models, and for a really good finish the full height of the superstructure walls should be as flush and flat as possible.Initial thoughts are that this isn't a bad model for one of the older ones, has lots of interesting features, and they will only be enhanced by PE and more scratch built detail. As always the superstructure walls are mostly devoid of detail and we'll fix that as we go. You'll note the bulwarks of the open bridge and on the walk ways at conning tower level have been replaced with thin styrene more in keeping with the scale. The shields around the aft AA positions have been removed, and once I'm finished sanding and filing the superstructure walls I'll fit their replacements too. Link to comment Share on other sites More sharing options...
Kenneth ONeill Posted December 30, 2021 Share Posted December 30, 2021 Er, it's Carley Float; Carley float - Wikipedia refers. Link to comment Share on other sites More sharing options...
Sailorman Posted December 31, 2021 Share Posted December 31, 2021 Er, it's Carley Float; Carley float - Wikipedia refers.Well it is Christmas ....... you know what the Angel said ......NOEL! Link to comment Share on other sites More sharing options...
Sailorman Posted December 31, 2021 Share Posted December 31, 2021 White Ensign Models used to make Carley Floats to 1:600. They may have stopped these but I think they also have them to 1:700 both large and small floats. They might be suitable ........ you could check. Link to comment Share on other sites More sharing options...
Ratch Posted January 3, 2022 Author Share Posted January 3, 2022 Re-posting lost images Link to comment Share on other sites More sharing options...
Ratch Posted January 3, 2022 Author Share Posted January 3, 2022 Link to comment Share on other sites More sharing options...
KiwiKev Posted January 12, 2022 Share Posted January 12, 2022 Work in progress. Funnel assembly has been detailed, hull is basically complete, including with bilge keels added, and the hull plating lines have been etched but a little hard to see in this photo, and since this photo was taken a start has been made on adding detail to the very plain superstructure walls, such as ducts, hatches, port holes, and Carley Floats. Rest of the main deck from C turret aft needs to be detailed. Awaiting the WEM PE set. All over-thick bulwarks have been replaced and a few weapon platforms without shields will need to have them fitted. Main turrets have had front faces replaced, range finder arms fitted, and 4.7 inch AA mounts have been improved. Link to comment Share on other sites More sharing options...
KiwiKev Posted January 13, 2022 Share Posted January 13, 2022 Some of the additional detail added to the superstructure walls. The key to doing this well is to ensure there is no sign of the 1 mm thick "deck" layer on top of the first level of superstructure, so lots of filling and sanding required, otherwise that very noticeable over-hang or recess is visible. All very rough at this stage, the paint job needs a tidy up, and more deck detail needs to be added, however the extra detail, while not hard to add, really improves the overall impression. With PE added, and a decent paint job, this should start looking quite good. Link to comment Share on other sites More sharing options...
KiwiKev Posted January 20, 2022 Share Posted January 20, 2022 A slightly messy shot due to starting the main deck coats without masking, with main deck detailing complete apart from open boats stowed behind the forward breakwater, and the large lattice deck crane to be completed once the PE set arrives. Rather unusual even for an older Airfix kit is the fact there were no bollards or fair-leads. It did mean they could be placed clear of the PE railing line though. I have cut the locating pins off the boats and will build some small cradles for them. Humbrol Matt 94 is the base coat for the deck. I will try dry brushing a light streaky top coat of Satin 71 along the plank lines, which is the colour they usually recommend for wooden decks. It tends to look a bit too clean, so I'll try this approach, with dry brushing Matt black across the line to highlight the raised caulking. Link to comment Share on other sites More sharing options...
KiwiKev Posted January 22, 2022 Share Posted January 22, 2022 The WEM PE for HMS Nelson/Rodney has arrived. Some of this is going to be very fiddly. The 8 Barrel Pompom is shown below along with the original. The 20 mm are absolutely tiny and if you want to knock yourself out there are over 50 that can be made and fitted. The WEM instruction sheets provide quite a good plan of their locations, but I'm not keen on doing that many. I suspect some of them at least will fall victim to the carpet monster as microscopic parts fly out of the tweezers. Link to comment Share on other sites More sharing options...
Torment30 Posted January 25, 2022 Share Posted January 25, 2022 Nice Camo one at the top and the new build is looking good Link to comment Share on other sites More sharing options...
KiwiKev Posted January 25, 2022 Share Posted January 25, 2022 Dry fit of parts so far including fore deck detail and some PE weapons. Just a few more weapon positions require shields fitted, such as mid-ship Pompoms. Mixed feelings on the PE Pompoms and Bofors as they don't look as accurate as they could be, however they still add that extra level of fine detail over the originals. Link to comment Share on other sites More sharing options...
Ratch Posted January 25, 2022 Author Share Posted January 25, 2022 Nice Camo one at the top Thanks Link to comment Share on other sites More sharing options...
KiwiKev Posted March 19, 2022 Share Posted March 19, 2022 Some progress after a bit of a delay. Still to finish and fit ship's boats, hand railing, a light AA gallery, and the large deck crane on the port side of the superstructure. Should be complete soon and I'll try and get some nice pics of the completed model in decent light. Link to comment Share on other sites More sharing options...
KiwiKev Posted March 22, 2022 Share Posted March 22, 2022 Basically complete apart from some tidying up of the paint. I'm pretty happy with the result but have seen some much better ones out there, so this old model can certainly be made to shine with a bit of work. Link to comment Share on other sites More sharing options...
Sailorman Posted March 22, 2022 Share Posted March 22, 2022 Very nice build KiwiKev. Sure looks the part! What's your next one going to be? Link to comment Share on other sites More sharing options...
Ratch Posted March 22, 2022 Author Share Posted March 22, 2022 this old model can certainly be made to shine with a bit of work.Indeed it cab, as you've shown. Link to comment Share on other sites More sharing options...
KiwiKev Posted March 22, 2022 Share Posted March 22, 2022 Very nice build KiwiKev. Sure looks the part! What's your next one going to be? I've got a half finished 1/600 Rommel being modeled as HMAS Perth, so really need to get back to that. Repulse is in the stash and looks quite good. Then there's KGV which even OOB looks more detailed than my finished Nelson, and in fact it seems to compare very well even to current models, so would be nice to do something that requires a little less scratch building for a change!!! Link to comment Share on other sites More sharing options...
