Rallymatt Posted August 13, 2023 Share Posted August 13, 2023 @Dave, I was very surprised at how much crud had built up on my Mk1 coach wheels. I cleaned them about 2 weeks ago. Wagons and locos seem generally to be less prone. Link to comment Share on other sites More sharing options...
Dave the Busker Posted August 18, 2023 Share Posted August 18, 2023 That classic real life problem of a points failure hit my layout today, with the train losing power after the frog. I'm not sure exactly what went wrong, but I'd never been particularly happy with that section anyway. I'd not laid the track very well and you'd sometimes see trains bounce going through it like it was uneven. I'd not found I was even using the junction between tracks there that much. So, bit the bullet, lifted the ballast, cleaned the board and replaced a junction and several straights with some Peco flexi. Failed and unused junction removed and along with it several sections of track joins. So far everything seems to be working again. Link to comment Share on other sites More sharing options...
Chris98 Posted August 18, 2023 Share Posted August 18, 2023 With the lack of buildings etc fully made I thought I would have a go with one of the downloadable card kits.I went wrong in a few places but if I did it again it would no doubt be better. Link to comment Share on other sites More sharing options...
South Coast Flyer Posted August 18, 2023 Author Share Posted August 18, 2023 Very productive day, cleaned all the building dust off the layout and whilst I was at it, gave the track a good clean with a piece of hardboard. I noticed that whilst rubbing the board round the track there were a couple of instances where the board ‘caught’ on the track - this happened where set track curves met flex track straights, on inspection there was a small lip on the join where one track was a fraction of a millimetre higher than the other side and I suspect is the cause of occasional stalling of locos at that point, running in the opposite direction is fine (going from higher side to lower) - happy to have solved that particular irritation!Also had chance to run and check Falcon after being returned from the paramedics in Margate, and again she is running very well - great customer support at HornbythumbsupAlso managed to run an auto calibration on all 4 of my locos and for the first time get all of them running on the layout at the same timegrinning Link to comment Share on other sites More sharing options...
moawkwrd Posted August 18, 2023 Share Posted August 18, 2023 Testing my track plan. Works well even with the included controller thankfully. Had to make a couple alterations but otherwise ready to be made permanent tomorrow. Link to comment Share on other sites More sharing options...
taunmarc88 Posted August 20, 2023 Share Posted August 20, 2023 That looks good moawkward, is it going to be a shelf layout or a modular loop? It seems as though having a box gives so much more realism as opposed to seeing a whole table at once. Looking forward to see what you do! Link to comment Share on other sites More sharing options...
taunmarc88 Posted August 20, 2023 Share Posted August 20, 2023 I’m still in the planning stages of my layout but today I was playing around to see how many locos could sit on the track with the PSU from the DCC set and it couldn’t handle my four locos at once. So I’m thinking I may well go for something similar to the track pack layout for now as you can only accommodate a few locos at once. I’m not really getting going with my layout due to indecision but I’d like to be doing something even if it is considered a bit basic so the track pack layout seems a good option (I may add straights to make it longer though). Link to comment Share on other sites More sharing options...
Skelton Junction Posted August 20, 2023 Share Posted August 20, 2023 Considering where to place the blue illumination over the Afon Conwy section. PS. This is the only section that’s greater than 50% done. Link to comment Share on other sites More sharing options...
moawkwrd Posted August 20, 2023 Share Posted August 20, 2023 That looks good moawkward, is it going to be a shelf layout or a modular loop? It seems as though having a box gives so much more realism as opposed to seeing a whole table at once. Looking forward to see what you do! A bit of both I think. I'm constrained for space (hence TT!) so it'll mostly be a shelf layout back and forth with two portable fiddle yards but I was thinking today that it would be relatively easy to get a piece of MDF, reinforce with some timber to make it the same height, with a cut out in so that the shelf can be dropped in to connect to a twin track loop so the trains can go round and round occasionally and it can otherwise live under a bed or wherever. If I had a longer wall the fiddleyards could be permanently connected but this will do for now since I don't have much time for modelling as it is. I got a lot done in my week off though. Today I built the Peco bufferstops and started on the Signal Box. It's not the same as the real life example but it'll do for now until I have time/patience to customise it. Need to get some paints ordered to finish it off. I also just managed to win an eBay auction for a Hornby Select DCC unit. I know they're not the best but I think for my uses (1-2 locos at a time, turning Function 28 on and then basically using it the same way as an analogue controller) it'll do fine. Just need to see what firmware it has and whether it needs sending to Hornby or not. If it does the job it'll at least have saved me spending £200 on a Digitrax Zephr and I'll be able to spend some of that on getting a YouChoos sound decoder for the class 08 now that they've published their guide showing it needs relatively little modification to fit. Link to comment Share on other sites More sharing options...
taunmarc88 Posted August 20, 2023 Share Posted August 20, 2023 It’s nice doing it the way you are that you’ll have the choice of adding either a portable loop or a fiddle yard as appropriate. I’m still looking at what space can be obtained in the spare bedroom, I might be able to have a small loop with a shelf station on the end that could float above a desk. Link to comment Share on other sites More sharing options...
Too Tall Posted August 21, 2023 Share Posted August 21, 2023 I'll be able to spend some of that on getting a YouChoos sound decoder for the class 08 now that they've published their guide showing it needs relatively little modification to fit. I have just looked at that, a very neat install all in the body, but ouch at £154 !That is more than the cost of the loco. Link to comment Share on other sites More sharing options...
moawkwrd Posted August 21, 2023 Share Posted August 21, 2023 I'll be able to spend some of that on getting a YouChoos sound decoder for the class 08 now that they've published their guide showing it needs relatively little modification to fit.I have just looked at that, a very neat install all in the body, but ouch at £154 !That is more than the cost of the loco. Is that including the stay alive? I spec’d the MS500N and speaker for £130 as I’ve found Peco unifrogs make a stay alive unnecessary on my layout. Considering a 6 pin HM7000 with sound would be around £60-70 (And a sound fitted version at least £200) if Hornby where to make one, I don’t think it’s unreasonable and means all my locos get the sound they deserve. Hopefully Hornby’s pricing is putting some downward pressure on other manufacturers. Link to comment Share on other sites More sharing options...
Too Tall Posted August 21, 2023 Share Posted August 21, 2023 Yes that included the stay alive ... if Hornby made a 6 pin sound HM decoder I imagine it would be the same price as the others around £60-70, then their stay alive is £15, but would need to go in the cab on the Class 08.Yes hopefully Hornby will lead a price cut in the industry, Hornby decoders are great VFM when compared to other sound decoders and they have BT as well. The downside is currently they are larger than spec. Link to comment Share on other sites More sharing options...
Trevor-353714 Posted August 21, 2023 Share Posted August 21, 2023 I have made a tunnel, to go by my cliffs. Ground work to follow. Link to comment Share on other sites More sharing options...
GMD Posted August 22, 2023 Share Posted August 22, 2023 Evening allA bit more footering (great word!) with 3d printing, signs, a truck, and pallets. All great fun but really should have been pressing on with ballasting and scenics. Hopefully another day! Link to comment Share on other sites More sharing options...
Too Tall Posted August 24, 2023 Share Posted August 24, 2023 Maybe a stretch but for the layout ...A multi gauge (N/TT/HO) DCC set-up/tester/PC programming board has been assembled. Link to comment Share on other sites More sharing options...
Baz657 Posted August 24, 2023 Share Posted August 24, 2023 Finalising the layout before gluing/drilling/wiring etc. Still keep making changes so need to make a final decision. Link to comment Share on other sites More sharing options...
Skelton Junction Posted August 25, 2023 Share Posted August 25, 2023 Weathering the old forestry commission timber yard buildings which have now been integrated into the miniature railway theme park at Betws y Coed. Link to comment Share on other sites More sharing options...
Postman On The Rails Posted August 28, 2023 Share Posted August 28, 2023 Screwing down my main track sections, outer loop left as it’s going to elevated which was a faff but glad it’s done Link to comment Share on other sites More sharing options...
Skelton Junction Posted August 29, 2023 Share Posted August 29, 2023 Postie, Baz, TT, et al, thanks for posting your progress updates: It’s great to see all the layouts at different stages of build. Link to comment Share on other sites More sharing options...
Skelton Junction Posted August 31, 2023 Share Posted August 31, 2023 Some Noch little people from msl and a nxt18 decoder in preparation for the class 50s and 66s arrival in 6 months (in case they either go up in price and/or go out of stock). I’ve two 50s and three 66s on order so I’ll buy a decoder a month. Link to comment Share on other sites More sharing options...
Dave the Busker Posted August 31, 2023 Share Posted August 31, 2023 A lot of ballasting, in the freight yard for the first time and in the section of track I had to take up to change a junction design. I was putting that bit off, but I want it done for the diorama competition photos and the deadline's coming up. Link to comment Share on other sites More sharing options...
happy tt Posted September 1, 2023 Share Posted September 1, 2023 hi @ skelton junction which little noch people did you get they had some nice ones on saleyum Link to comment Share on other sites More sharing options...
Skelton Junction Posted September 1, 2023 Share Posted September 1, 2023 hi @ skelton junction which little noch people did you get they had some nice ones on saleyum Some platform folks and a bbq ensemble Link to comment Share on other sites More sharing options...
Yelrow Posted September 1, 2023 Share Posted September 1, 2023 i am very jealous of all these people finding the time during the summer to work on their layouts. I last saw mine, in March, before Grass and garden came to life. Still cutting grass, so will be October, before i can find time to venture upstairs. Link to comment Share on other sites More sharing options...
