Brake Van illumination & Tail Lamp
Everything is better with sparkly lights and brake vans are no exception! After illuminating coaches with magic lights I found a really inexpensive way to create a system for the Brake Vans and have an illuminating tail lamp. A few tweaks if I can to reduce light bleed on the lamp, itโ€™s a WHWW 3D print and quite brittle to drill. Light is fed by a Fibre Optic Filament, the light unit is a natty item from TramFabrique, combined battery, holder, battery, subface mount latching switch and single led. Really compact and neat and of course works with my super dooper uncoupling, load lifter, lighting wand ๐Ÿ˜
ย
IMG_5507.thumb.jpeg.b39bb3e9cea6ca41e414f6fdac8fbc46.jpegIMG_5511.thumb.jpeg.baab7aff3fac415ccd26a3877909cc7b.jpeg
  • Like 13
Fibre optic cable is dirt cheap and can easily be attached to an led using heat shrink tube. By selectively cutting back the external sheath you can also port light to other areas such as lighting the 'cabin' in Matt's image.
  • Like 1
I used side looking twin leds for my Hornby buffers. These are 00.
The led will fit in the buffer beam slot and the resistor will hide in the leg especially if painted black. As the leds are back to back they can be wired direct to a DCC track (both leds light) as here, or a DC track, in which case only one led will light according to selected direction.
ย
Posted (edited)
Iโ€™m looking into some better lamps. WWHW are hard to drill out and not shatter and offen most of mine come with the top miss-printed. The front ones they have just launched are way better quality.ย
ย
When I have time I will pop a video up on how I did this and hopefully some other projects using the same components. The ultra small LEDs work really well where the bend in finer optic is just too tight, like the buffer. The the brake van you can just see I drilled a tiny hole through back board of van and the cabin and the FOF is straight through into the lamp. I let some light leak into the cabin of brake van to illuminate it. These tiny light units are very useful ๐Ÿ˜
Edited by Rallymatt
  • Like 3
5 hours ago, DJBDoug said:
Thatโ€™s an 0603 and led in a peco buffer.ย
with a resistor I hope, as it's connected to a 9V battery ๐Ÿ™‚ย
I use mostly 0402 LEDs for N gauge vehicle lights etc. Yes I did try soldering to them my self but the easy available of pre-wired items is a no-brainer tbh ๐Ÿ™‚ย
I added the lighting and built the controller board for these N scale heavy haulage units originally made by a friend some 20 years ago.ย ย
ย
  • Like 4
ย
Yes a 15k in heat shrink that will connect through a small rectifier chip to the DCC power eventuallyย
I have put together a short video on the early version of the Brake Van lights and also using the TramFabriek lighting units in Stanier Full Brakes. I have also included some details on how to get the bodies off these and what they are like inside for anyone curious but not going in ๐Ÿ˜
ย
  • Like 6
  • Thanks 1
I look forward to seeing what you come up with ๐Ÿ˜ these are really useful little lighting modules, they would work well in buildings too for those not confident with soldering .ย
The MagnoLEDs are an interesting solution but there is a warning on the website that the batteries do drain over time and will need replacing after a few weeks. I do not know what "few" means here - can anyone enlighten us? There are some interesting lighting products so thank you for the link.ย
The ones from TramFabriek have a suggested life of 40 hours continuous use, thatโ€™s longer than the motors last in TT:120 locos! ๐Ÿคฃ
The lighting units I made for the MK1s that have many more LEDs but two larger 1.5v cells have been in 12months plus. I did leave one on just to see and it went about 48 hours before being visibly depleted. Swapping batteries is a really simple job though.ย
On the brightness of the oil lamps, itโ€™s one of the areas where in modelling a compromise helps, light doesnโ€™t scale well, like water. I still have a bit of work to do on the tail lamp idea and using the fibre optic filament ๐Ÿ˜‰
  • Like 1
I saw the 40hr figure but I think the point that the website makes is that there is a small but constant drain on the battery. Even if you do not use the wand to switch the lighting on, the battery will drain over a "few" weeks. If "few" is, say, 52 then I don't see it as a problem, but more a matter of awareness.
I presume the unit remains on standby, waiting for the magnetic signal. A hard switch would not drain the battery. You would instead be left with typical shelf life.
Edited by dBerriff
An easy solution for brightness is to paint over the exterior 'bulb' with a translucent colour in sufficient layers to suit ones taste- this works for both led sources and the ends of optical fibres. Such colours can range from dedicated modelling paints to handy bottles of nail varnish.
  • Like 2
Posted (edited)
I see what you mean @dBerriff, I canโ€™t imagine the draw is very much compared to a watch for example. I will keep one with battery in but not working as a light and see how it fares. ๐Ÿ‘
Edited by Rallymatt
The comment was also aimed at newcomers so they do not make battery access difficult, for example by super-gluing the top back on. I have heard tales of that being done to locomotives!
  • Like 1
In the video I show how I black tac to fix the unit in and I donโ€™t even bother with the screws on the brake van, it clips together sufficiently without. On the coaches they clip back but once the bodies have been off a couple of times they are easier but still secure when refitted. Itโ€™s a good point that at some time that battery will need replacing! ๐Ÿ˜
Is black tack similar or equivalent to tacky wax??
ร—
