Graskie Posted December 4, 2014 Share Posted December 4, 2014 @PJYou said, "For a person to remove the power takes seconds, it reduces any chance of a problem."I don't feel I have those seconds to spare. Link to comment Share on other sites More sharing options...
CornishJim Posted December 4, 2014 Author Share Posted December 4, 2014 If the DPDT is a break before make type then this would not happen, I think i'll pop into maplins tomorrow while I am in civilisation and buy an over priced rotary switch and put the 2 outputs at either end of the dial, that way there will be a pause in the swich over, I might even buy a key switch too just to be safe!!! LOL I watched a video just now showing a bachman controller that has this switch built into the software, I would be more wary of a software switch than a physical one. Link to comment Share on other sites More sharing options...
dynax Posted December 5, 2014 Share Posted December 5, 2014 if you use a siding why not have two switches and have an illuminated buffer stop, when the said track is in normal use the light on the buffer is on use a switch to isolate power then use another switch for the programming track Link to comment Share on other sites More sharing options...
PJ_model_trains Posted December 5, 2014 Share Posted December 5, 2014 @PJYou said, "For a person to remove the power takes seconds, it reduces any chance of a problem."I don't feel I have those seconds to spare. You will be with us a long time yet Graskie.Waiting for the comments! Link to comment Share on other sites More sharing options...
PJ_model_trains Posted December 5, 2014 Share Posted December 5, 2014 @PJYou said, "For a person to remove the power takes seconds, it reduces any chance of a problem."I don't feel I have those seconds to spare.Stop admiring or counting your gold bars and you will have lots of time to spare ;o) Link to comment Share on other sites More sharing options...
PJ_model_trains Posted December 5, 2014 Share Posted December 5, 2014 if you use a siding why not have two switches and have an illuminated buffer stop, when the said track is in normal use the light on the buffer is on use a switch to isolate power then use another switch for the programming track That seems a good idea dynax Train-Tech do some great sidings buffer stop lights, no wiring just simple slot between the rails. I have these on all my sidings, I never forget to power down anymore, lights on I know to switch off. Should a program track not have any additional items on it though? PJ Link to comment Share on other sites More sharing options...
RB51 Posted December 5, 2014 Share Posted December 5, 2014 This is my programming track - a bit long, but I made it when I didn't really know what I was doing - yesterday! There is an LED at the far buffer stop - which pulses light as RM looks at the chip. If it is on all the time, I know I have this track plugged into the wrong power outlet. Simples. I used this track to practice ballasting, seemed a good idea but I got worse from here. Ho hum. R-/media/tinymce_upload/IMG_1284.jpg Link to comment Share on other sites More sharing options...
PJ_model_trains Posted December 5, 2014 Share Posted December 5, 2014 Hi RogerB The buffer light is a good idea Your example also confirms it will work on a program track. I like the idea and that you can see the light pulse as the CV's are read/written. PJ Link to comment Share on other sites More sharing options...
CornishJim Posted December 5, 2014 Author Share Posted December 5, 2014 Having 2 switches means that they both could be switched to the on position which as many of the posts have said would be bad! So a single DPDT or rotary switch would be better, no chance then of joining both feeds together. As space is at a premium in my layout room and there is not a spare cm of board Un utilised, I don't want a separate track nor could I take it downstairs as the e link is attached to the base board. Link to comment Share on other sites More sharing options...
Tee1707818014 Posted December 5, 2014 Share Posted December 5, 2014 This is from the Brian Lambert site it's what I used for my siding it has a light when the program is on & off when in track mode. It also has an isolation section so you can't make a mistake with the programming .However mine is connected to my elite controller & when I use my programming my digitrain sound decoders locos would start up & run away so I had to change cv29 to 2 so the dc was off to stop the motors. The sound still come on while programming but they don't run away now. Looking at the wiring diagram I can't see why this was happening as all looks ok unless there is a feed from the programming contacts in the elite which must be for low current to program the loco or accessory. /media/tinymce_upload/image22.jpg Link to comment Share on other sites More sharing options...
St1ngr4y Posted December 5, 2014 Share Posted December 5, 2014 As I said earlier, I cannot possibly see how a programming output can interfere with anything on the main track if you have totally separate feeds to each. If it happens, there must be a fault with the Elite, eLink or RM, surely? Can anyone give an example of this having actually happened?I think I've mentioned this elsewhere. On a couple of occasions I have been accessing the cv's of one loco on the programming track via RM & Elite, when suddenly another loco and my turntable start off at full speed in reverse on the main layout.Ray Link to comment Share on other sites More sharing options...
Tee1707818014 Posted December 5, 2014 Share Posted December 5, 2014 In the final Programming track drawing above, an Isolating section of track has been placed between the main line and the programming track section. The idea here is to prevent accidental entry onto the programming section should the selection switch be left in the Programming position. Some DCC console could be damaged by such a move! You can only pass over the isolated section and onto the programming section rails if the switch is set for 'Normal DCC power' operation. As soon as the switch is flipped over to the 'Programming' position the isolating track is disconnected from all power and the programming rails section is connected to the programming output of the DCC console. The Programming LED is also illuminated. Once programming is completed the switch is turned back to 'Normal' and the loco driven out under normal DCC power. Link to comment Share on other sites More sharing options...
2e0dtoeric Posted December 5, 2014 Share Posted December 5, 2014 Working on the premis - if it ain't broke, don't fix it - I've never had a problem with my Elite, so I've not had a look inside.Perhaps one of the feeds to the main out, and programming out, are commoned inside the box? This could explain the random 'runaways' for those who have not physically disconnected the main track whilst programming.Regarding the LED warning/buffer light not affecting the programming, well - it wouldn't! Some of the loco's have LED lights in them, especially the diesel outline ones. Link to comment Share on other sites More sharing options...
jimmydick Posted December 5, 2014 Share Posted December 5, 2014 I have had an idea that some of you might of done already. Instead of having a seperate piece of track for programing, I thought about isolating a siding with the plastic fishplates and wiring up 2 feeds to it via a switch, one for normal track power and one for the programing feed , I cant see any reason why it wouldn't work but I thought i'd ask the question anyway. Link to comment Share on other sites More sharing options...
Graskie Posted December 5, 2014 Share Posted December 5, 2014 As I said earlier, I cannot possibly see how a programming output can interfere with anything on the main track if you have totally separate feeds to each. If it happens, there must be a fault with the Elite, eLink or RM, surely? Can anyone give an example of this having actually happened?I think I've mentioned this elsewhere. On a couple of occasions I have been accessing the cv's of one loco on the programming track via RM & Elite, when suddenly another loco and my turntable start off at full speed in reverse on the main layout.RayI assume you're talking about reading CVs on RM via your Elite, Ray. If so, I am still programming direct from my Elite and haven't got round to using the RM facility for that yet. Could there be something in that? Sounds to me more of a glitch in RM, because I've not had that trouble. Link to comment Share on other sites More sharing options...
96RAF Posted December 5, 2014 Share Posted December 5, 2014 I have a on-off-on dpdt switch wired thus:power from elite track terminals to one pair of switch outer terminals, power from elite prog terminals to the other pair of outer terminals, and the switch middle pair wired to my rolling road. Switch one way is programming, the other way is the equivalent of main track and middle is isolated. Link to comment Share on other sites More sharing options...
CornishJim Posted December 5, 2014 Author Share Posted December 5, 2014 Well i've been shopping in Maplin today and bought the bits I need to wire this up, I will let you all know what goes on over the next few days! Now where did I put all my physics school books with resister values and colour codes etc in them? Link to comment Share on other sites More sharing options...
Howbi Posted December 10, 2014 Share Posted December 10, 2014 I use the Hornby Rolling Road for testing and running in new locos prior to fitting decoders. Use address "000" for DC testing first. Then, after fitting a decoder, you can allocate the required new address to the loco in Programming Mode then test run in DCC. Adjust the CV's for acceleration, deceleration, sound volume etc then transfer to layout and open the throttle. Simples!!! Link to comment Share on other sites More sharing options...
96RAF Posted December 10, 2014 Share Posted December 10, 2014 I use the Hornby Rolling Road for testing and running in new locos prior to fitting decoders. Use address "000" for DC testing first. Then, after fitting a decoder, you can allocate the required new address to the loco in Programming Mode then test run in DCC. Adjust the CV's for acceleration, deceleration, sound volume etc then transfer to layout and open the throttle. Simples!!!My rolling road doubles as a programming track and test track via a DPDT switch wired to my elite.with a second switch I could slave in a dc controller. Link to comment Share on other sites More sharing options...
CornishJim Posted December 16, 2014 Author Share Posted December 16, 2014 Well the switch is now wired in and it works!! No problems with it interfering with any of the other locos either, I have added some LED's, green for normal track power and yellow for progamming, now I don't have to take any locos off the layout to mess around with the CV programming. Link to comment Share on other sites More sharing options...
CornishJim Posted December 16, 2014 Author Share Posted December 16, 2014 Hmmmm had to take the LED's off, they were interfering with the programming. Link to comment Share on other sites More sharing options...
choralc Posted December 17, 2014 Share Posted December 17, 2014 Hmmmm had to take the LED's off, they were interfering with the programming.Was about to say wow then saw the above. Could you leave one LED for track on and when in programming it would be off? Pics with notes are always more beneficial to me :) Link to comment Share on other sites More sharing options...
CornishJim Posted December 17, 2014 Author Share Posted December 17, 2014 I tried leaving one on, but It still interferes , I noticed when I had 2 LEDs on that it sends a pulse of power with the pulse of 'data'. Shame as it looked great on my sub switch panel!! I might try it with a bigger resister but I doubt it will work. Link to comment Share on other sites More sharing options...
Rog RJ Posted December 17, 2014 Share Posted December 17, 2014 I have an LED on my programming track and it works without any problems. I think I used a 5k resistor, still bright enough to be seen easily. Link to comment Share on other sites More sharing options...
CornishJim Posted December 19, 2014 Author Share Posted December 19, 2014 Ah cool I'll try a 5k and see what happens then, cheers rog Link to comment Share on other sites More sharing options...
