Hurricane Boy Posted August 10, 2018 Share Posted August 10, 2018 I would like to see the 1/72 F-86 EM/F kit back dated with the short chord/short span/slatted wing to allow building F-86 A, E, Canadair Sabre 2, and as-built Sabre 4 aircraft. Slats should be separate for open or closed positionsI could get on board with this idea; The existing kit design means that all that's needed is new main planes, gun bay doors and maybe flat rather than dihedral elevators to produce any 6-gun F-86.Yes Paws you are absolutely corect about teh little bit of work to get some more mileage out of this kit.Sorry one correction on my earlier post... the F-86A had a slighly different rear fuselage profile compared with the E, F, Sbre 2 & 4 due to the later having the all-flying tail.Also, the early E's and all the Sabre 2's had the beveled centre windscreen like the F-86A. Link to comment Share on other sites More sharing options...
StuartN Posted August 10, 2018 Share Posted August 10, 2018 I would like to see the 1/72 F-86 EM/F kit back dated with the short chord/short span/slatted wing to allow building F-86 A, E, Canadair Sabre 2, and as-built Sabre 4 aircraft. Slats should be separate for open or closed positionsI could get on board with this idea; The existing kit design means that all that's needed is new main planes, gun bay doors and maybe flat rather than dihedral elevators to produce any 6-gun F-86.Yes Paws you are absolutely corect about teh little bit of work to get some more mileage out of this kit.Sorry one correction on my earlier post... the F-86A had a slighly different rear fuselage profile compared with the E, F, Sbre 2 & 4 due to the later having the all-flying tail.Also, the early E's and all the Sabre 2's had the beveled centre windscreen like the F-86A. I could also get onboard with this idea. However it would also be good if it included parts for an avon engine, 30 mm aden cannon, plus a reconfigured cockpit, different wings and the option to widen the air intakes to make a CA-27 Sabre. Link to comment Share on other sites More sharing options...
Kenneth ONeill Posted August 10, 2018 Share Posted August 10, 2018 I would like to see the 1/72 F-86 EM/F kit back dated with the short chord/short span/slatted wing to allow building F-86 A, E, Canadair Sabre 2, and as-built Sabre 4 aircraft. Slats should be separate for open or closed positionsI could get on board with this idea; The existing kit design means that all that's needed is new main planes, gun bay doors and maybe flat rather than dihedral elevators to produce any 6-gun F-86.Yes Paws you are absolutely corect about teh little bit of work to get some more mileage out of this kit.Sorry one correction on my earlier post... the F-86A had a slighly different rear fuselage profile compared with the E, F, Sbre 2 & 4 due to the later having the all-flying tail.Also, the early E's and all the Sabre 2's had the beveled centre windscreen like the F-86A. I could also get onboard with this idea. However it would also be good if it included parts for an avon engine, 30 mm aden cannon, plus a reconfigured cockpit, different wings and the option to widen the air intakes to make a CA-27 Sabre.Which would be nice, but is a bit "raise ejector seat, insert new aircraft, lower ejector seat" compared with the other discussion about work (not) needed for aircraft prior to the 6-3 wing. Link to comment Share on other sites More sharing options...
Buildit Posted August 11, 2018 Share Posted August 11, 2018 Still hoping for a new tool Vulcan 1/72 new tool Buccaneer 1/48 new tool Phantom 1/48 Link to comment Share on other sites More sharing options...
Hawkerhurricaneguy Posted August 12, 2018 Share Posted August 12, 2018 1/48 Hawker Hurricane mark I - Fabric Wing - could use current tropical kit with changed out wings1/48 Hawker Hurricane mark IIa, b and c 1/48 Bristol Blenheim mark IV1/48 Bristol Beaufort 1/48 Vickers Wellington 1/48 Fairey Battle mark I 1/48 Vickers Vilderbeestand a 1/48 Blackburn B.26 Botha Link to comment Share on other sites More sharing options...
littoralcombat Posted August 12, 2018 Share Posted August 12, 2018 Westland Wasp in 1/72nd would be my request. Never produced before, other than in 1/48th. An iconic British Aircraft, brought into UK lounge-rooms via the TV series, Warship. Link to comment Share on other sites More sharing options...
David Jones1707820337 Posted August 12, 2018 Share Posted August 12, 2018 Amen to Hawkerhurricaneguy's listAnd how about:Auster Antarctic (lots of scope for variations on that airframe) plus a Sno-cat and some figures for the 1956 CTAE (in 1/48 scale)In 1/72 scale, the HP42 airlinerAnd, just in time for the 50th anniversary, reissue the Lunar Module kit, or better still, do a proper one in 1/48 (unlike another manufacturer I could name). Again, lots of variations on the basic structure. (well, I can dream, can't I....) Link to comment Share on other sites More sharing options...
EHT 1418 Posted August 13, 2018 Share Posted August 13, 2018 1/72 F-111E with white UH tail codes and aircrew figures1/72 modern aircrew figures Link to comment Share on other sites More sharing options...
Hurricane Boy Posted August 13, 2018 Share Posted August 13, 2018 1/48 Hawker Hurricane mark I - Fabric Wing - could use current tropical kit with changed out wings1/48 Hawker Hurricane mark IIa, b and c 1/48 Bristol Blenheim mark IV1/48 Bristol Beaufort 1/48 Vickers Wellington 1/48 Fairey Battle mark I 1/48 Vickers Vilderbeestand a 1/48 Blackburn B.26 BothaI like the Hurricanes but the Blenheim IV could be even more interesting. I've got an idea for a markings for a local dfc chap's aircraft. Link to comment Share on other sites More sharing options...
MightyMichael Posted August 14, 2018 Share Posted August 14, 2018 I would love a set which includes a lancaser bomber with a German night fighter of some sort (109 g6 would be good). Another set would be a p40e kittyhawk with RAAF Australian decals. These are my ideas i thought up myself. I think the first set of the lancaster and German plane would be an epic kit to make and would make an awesome diorama.These are just my ideas i hope you enjoyed them and thanks for reading this. Link to comment Share on other sites More sharing options...
MightyMichael Posted August 15, 2018 Share Posted August 15, 2018 another cool item could be a quick build lancaster although that would be a bit... complicated for the type of model (quick buid) Link to comment Share on other sites More sharing options...
John Pitt1707820082 Posted August 15, 2018 Share Posted August 15, 2018 a new tool of the vulcan the options would be huge B1 , B2 with 201/202 or 301 jet pipes , tankers , blue steel and 558 in 1/72 Link to comment Share on other sites More sharing options...
paganpete Posted August 18, 2018 Share Posted August 18, 2018 Personally, I would love some obscure ones. Preferably in 1/48 or up as 1/72 is too small for my capabilities these days.1/48 P-26a Peashooter would be lovely (or even larger scale), one of my fave planes.1/48 Army Lynx and Gazelle would also be very much appreciated.Finally...so as not to seem greedy, how about a 1/48 De Havilland Hornet Moth...and if you can wrap them for me too I would appreciate it :-)Pete Link to comment Share on other sites More sharing options...
Dark Earth Posted August 19, 2018 Share Posted August 19, 2018 Just a 1/72 Dauntless. Other kits of this bird are either poor quality or incredibly rare / hard to find. I'd even settle for a re-pop of the old Airfix kit - but it would be nice to see a new one. ; )Chris Link to comment Share on other sites More sharing options...
Kenneth ONeill Posted August 20, 2018 Share Posted August 20, 2018 Personally, I would love some obscure ones. Preferably in 1/48 or up as 1/72 is too small for my capabilities these days.1/48 P-26a Peashooter would be lovely (or even larger scale), one of my fave planes.1/48 Army Lynx and Gazelle would also be very much appreciated.Finally...so as not to seem greedy, how about a 1/48 De Havilland Hornet Moth...and if you can wrap them for me too I would appreciate it :-)Pete Airfix have already done a 1/48 scale "Army Lynx". Try looking on a large South American river or the bay of fleas. Link to comment Share on other sites More sharing options...
Maximus60 Posted August 20, 2018 Share Posted August 20, 2018 I think definitely more British subjects especially aircraft in 1/48 (my field, but generally too);Chopper Wirlwind (an 1800's Revell product only one around...maybe not 1800's but you get the drift!) Puma (Never any 1/48 kits that I know of) AW Wildcat Naval Merlin (surely easily converted from the RAF one) Scimitar Chipmunk Venom/Vampire (This could be a money spinner if engineered right, get single seaters/trainers/Navy/night fighters from one mould then mix & match) Hunter Trainer Updated Hawk New Vulcan in 1/72 VC-10 in 1/72 DH Comet in 1/72 Lincoln in 1/72 (or 1/48 would be brilliant, but I'll be realistic) BA 146 in 1/72 (Could be a dodgy one though) Voyager in 1/72 (If Kittyhawk can do a C-17?) AW Argosy in 1/72 So, not many I want, but definitely more British gear. Link to comment Share on other sites More sharing options...
Maximus60 Posted August 20, 2018 Share Posted August 20, 2018 Sorry about the last post, ain't got a clue what happened.Here's the more readable version."I definitely think we need more British subjects especially aircraft in 1/48 (my field, but generally too). Here’s what I would like;Chopper Whirlwind (An 1800's Revell product only one around...maybe not 1800's but you get the drift!) Puma (Never any 1/48 kits that I know of)AW Wildcat Naval Merlin (surely easily converted from the RAF one)ScimitarChipmunkVenom/Vampire (This could be a money spinner if engineered right, get single seaters/trainers/Navy/night fighters from one mould then mix & match.Hunter TrainerUpdated HawkNew Vulcan in 1/72VC-10 in 1/72DH Comet in 1/72Lincoln in 1/72 (or 1/48 would be brilliant, but I'll be realistic)BA 146 in 1/72 (Could be a dodgy one though)Voyager in 1/72 (If Kittyhawk can do a C-17?)AW Argosy in 1/72So, not many I want, but definitely more British gear." Link to comment Share on other sites More sharing options...
Bucknodd Posted August 20, 2018 Share Posted August 20, 2018 I agree with a lot of folk in :- 1/48 and 1/72 Buccaneer S2BAVRO Manchester in 1/72Fairey Swordfish in 1/48Any prototype aircraft that can still be made from plans ie Seafang, MB5, Spiteful etcC.E.T (Combat Engineer Tractor) in something bigger than 1/35HMS Gambia would be good to see too. Father in law served on her during the war (he's 97 next month) Link to comment Share on other sites More sharing options...
Kenneth ONeill Posted August 21, 2018 Share Posted August 21, 2018 If we're thinking about an RN Merlin, how about a UK Coastguard one as well? It's not like SAR cabs are ever unpopular subjects.Oh yes, and maybe a UK Coastguard S-61 (modification of Sea King tool)? Link to comment Share on other sites More sharing options...
Gary Beck1707820000 Posted August 21, 2018 Share Posted August 21, 2018 Was looking for the Super Fortress today - yes please! Link to comment Share on other sites More sharing options...
Ze FAP Posted August 21, 2018 Share Posted August 21, 2018 Boa noiteSugiro o SA330 PUMA...aeronave mitica ao servico da Forca Aerea Portuguesa, onde voei muitas horas.Cordiais cumprimentos Link to comment Share on other sites More sharing options...
159 Posted August 22, 2018 Share Posted August 22, 2018 I like the extra detail that 1/48 brings. Would love to see the Tiger Moth upgraded to the larger scale and maybe a Dragon Rapide as there are so many of these two aircraft flying and with such a wide variety of colour schemes. Military wise I agree with those asking for a new Hampden and Fairy Battle, 1/48th again. Both much under represented in the model world. Could we also consider upscaling the old airfield vehicle sets to go with the currant range. Keep up the good work - loving what has come out so far. Link to comment Share on other sites More sharing options...
modeler 123 Posted August 22, 2018 Share Posted August 22, 2018 panzer 1 c 18.01 please 1/72 Link to comment Share on other sites More sharing options...
Ratch Posted August 22, 2018 Author Share Posted August 22, 2018 Time we had aLuftwaffe ground support set (in 1/72 of course) Link to comment Share on other sites More sharing options...
StuartN Posted August 23, 2018 Share Posted August 23, 2018 I agree a luftwaffe ground crew set is long overdue. It would be good if it included something other than an Opel Blitz and Pak 40, such as a Fiat 1100. And it would be good to see some RAAF ground crew and vehicles. Link to comment Share on other sites More sharing options...
