Tweezers Posted September 5, 2020 Share Posted September 5, 2020 Hi all,Please what is the best preparation for painting 1/76 figures? ?Just about to purchase modern Airfix figures for first time. While I'm here:Arabs (Bedouin) & German Mountain Troops please Aiirfix Link to comment Share on other sites More sharing options...
peebeep Posted September 5, 2020 Share Posted September 5, 2020 If you're referring to the polyethylene moulded figures, rather than rigid polystyrene, coat them with thinned white glue before applying any paint. Link to comment Share on other sites More sharing options...
Tweezers Posted September 5, 2020 Author Share Posted September 5, 2020 If you're referring to the polyethylene moulded figures, rather than rigid polystyrene, coat them with thinned white glue before applying any paint.Thanks PaulLinks to a brand & thinners? Link to comment Share on other sites More sharing options...
peebeep Posted September 5, 2020 Share Posted September 5, 2020 Crikey, there's more brands of PVA glue than you can shake a stick at. Go for the ones that are marketed as wood glue, craft PVA tends to be watered down, although you could argue it saves thinning. Thin with water. Link to comment Share on other sites More sharing options...
Frederick Kullas Posted September 5, 2020 Share Posted September 5, 2020 I tried the PVA coating but that just made the paints peel off. For many years now I just brush on Humbrol enamel matt black 33 or matt white 34 as a primer. I've had very little problem with paint peeling off. Link to comment Share on other sites More sharing options...
Ratch Posted September 6, 2020 Share Posted September 6, 2020 I rarely use a primer, but if I have a set of figures that seem to repel paint when its brushed on, I spray with Vallejo Acrylic 74660 Gloss Black Polyurethane Surface Primer. Usually, I use Vallejo and Humbrol acrylics and handle the figures as little as possible. Link to comment Share on other sites More sharing options...
Tweezers Posted September 6, 2020 Author Share Posted September 6, 2020 Thaks eyeryone!humbrol used to do a matt whte enamel in a sprey can. Just checked but nothing popped up.I have an airbrush. Link to comment Share on other sites More sharing options...
Peter s Posted September 8, 2020 Share Posted September 8, 2020 I use "croc-clips" for electronics to hold base/feet but the "avoid touching" is good advice. That soft plastic is quite paint repellant but also you don't have a huge amount of detail so you can't afford too many coats of paint. I airbrush tamiya flesh as a combination face colour / primer for everywhere else then give it at least 24 hours to dry hard. Even then you can scratch paint off but its good enough. Link to comment Share on other sites More sharing options...
Tweezers Posted September 8, 2020 Author Share Posted September 8, 2020 I use "croc-clips" for electronics to hold base/feet but the "avoid touching" is good advice. That soft plastic is quite paint repellant but also you don't have a huge amount of detail so you can't afford too many coats of paint. I airbrush tamiya flesh as a combination face colour / primer for everywhere else then give it at least 24 hours to dry hard. Even then you can scratch paint off but its good enough.Peter, is this Tamiya enamel or acrylic? Agree undercoat has to be spreyed on Link to comment Share on other sites More sharing options...
Ratch Posted September 8, 2020 Share Posted September 8, 2020 Tamiya paints are spirit based acrylics IIRC, that is they don't mix with water Link to comment Share on other sites More sharing options...
peebeep Posted September 8, 2020 Share Posted September 8, 2020 Tamiya paints are spirit based acrylics IIRC, that is they don't mix with waterTamiya acrylics are spirit based, but they are also miscible with water. Tamiya also do a range of enamel paints that are not generally available in the UK. Confusingly they also do a range of acrylic paints that are lacquer based and as I understand it not miscible with water, that are fairly readily obtainable in the UK. Link to comment Share on other sites More sharing options...
Tweezers Posted September 9, 2020 Author Share Posted September 9, 2020 Is this the solution?/media/tinymce_upload/b62e8de1975667ae9d32e9e78e4ce24d.jpg Link to comment Share on other sites More sharing options...
Tweezers Posted September 9, 2020 Author Share Posted September 9, 2020 So are any of their rattle cans suitable for a primer coat before painting with enamel on hairy stick? Link to comment Share on other sites More sharing options...
Kenneth ONeill Posted September 10, 2020 Share Posted September 10, 2020 If you can get them in the "right colours" then polycarbonate (and/or) Lexan paints might be good for PCV figures, but test on one figure before doing a whole batch. Link to comment Share on other sites More sharing options...
Peter s Posted September 11, 2020 Share Posted September 11, 2020 Yeah... i've been beaten to it. Tamiya is acrylic but uses alcohol as a solvent not water (Tamiya thinner is a mix of isopropyl alcohol -ie surgical spirit-, water and glycerol). You CAN thin with a small quantity of water but that sort of defeats its one advantage. I use it as a primer coat and for fine detail work (like canopy lines when brush painted) because it sticks harder and quicker than true water based acrylics but you don't get the problems of mixing enamel/acrylic with it. It sprays easily. I prefer model air for "proper" painting but an airbrush initial coat of Tamiya gives you a good primer in most cases thats ready for model air in 10-30 mins. I've bought a few model air own brand primers recently and they're also pretty good. Link to comment Share on other sites More sharing options...
BillMC Posted November 7, 2020 Share Posted November 7, 2020 I have a big problem WRT painting 1/72 or 1/76 Airfix figures (and I expect so will many other people). This is becuase unlike the 1/32 firgures there is no recommended list of Humbrol paints and instructions for painting each part of the figure. I managed to do a good job of my WWII British and Germany infantries and my 8th Army, because I have both the 1/72 and 1/32 sets.Here is the list of 1/72 and 1/76 figures that are awaiting painting - could someone please provide me with recommend colours and instructions? - it would be greatly appreciated thank you.:German WWI infantryAmerican WWI infantryAmerican WWII paratroopersRussian WWII infantryGerman WWII Africa CorpsBritish WWII CommandosBritish WWII RAF personnel Link to comment Share on other sites More sharing options...
Ratch Posted November 7, 2020 Share Posted November 7, 2020 WW1 GermansVallejo Model Color 102 70830 German Fieldgrey WWII = uniform, helmetVallejo Model Color 140 70984 Flat Brown = water bottleHumbrol Acrylic 85 Satin Coal Black = boots, strapsHumbrol Acrylic 94 Matt Brown Yellow = straps, bagsTamiya XF-20: Medium Grey = greatcoatTamiya XF-22: RLM Grey = canisterTamiya XF-9: Hull Red = entrenching tool handleTamiya XF-16: Flat Aluminium = cook potRevell Aqua 36 382 Silk Wood Brown = rifle stockTamiya XF-23: Light Blue = small packTamiya XF-25 Light Sea Grey = fuel bagHumbrol Acrylic 237 Matt Desert Tan = strapsVallejo Model Color 179 70863 Gunmetal Grey = firearms WW2 RussiansVallejo Model Color 115 70988 Khaki = uniformVallejo Model Color 141 70921 English Uniform = uniformVallejo Model Color 93 70887 Brown Violet = uniformVallejo Model Color 103 70821 German Camouflage Beige = uniformVallejo Model Color 147 70871 Leather Brown = beltsVallejo Model Color 166 70994 Dark Grey = valenki (boots)Vallejo Model Color 169 70950 Black = bootsHumbrol Acrylic 60 Matt Scarlet = collar patchesHumbrol Acrylic 155 Matt Olive Drab = helmetHumbrol Acrylic 186 Matt Brown / Vallejo Model Color 163 70868 Dark Seagreen = greatcoatHumbrol Acrylic 9 Gloss Tan = Moisin Nagant 7.62mm M.1891/30 rifle stockVallejo Model Color 138 70940 Saddle Brown = PPSh-41 stockVallejo Model Color 179 70863 Gunmetal Grey = Moisin Nagant 7.62mm M.1891/30 rifle, PPSh-41 with clip magazine, helmet WW2 Afrika KorpsHumbrol Acrylic 155 Matt Olive Drab = uniformTAMIYA XF-59: Desert Yellow = blouse, trousers, capVallejo Model Color 102 70830 German Fieldgrey WWII = blouse, trousers, capVallejo Model Color 104 70884 Stone Grey = helmet, ammunition boxVallejo Model Color 141 70921 English Uniform = socksVallejo Model Color 90 70890 Reflective Green = socksVallejo Model Color 102 70830 German Fieldgrey WWII = socksVallejo Model Color 136 70818 Red Leather = bootsHumbrol Acrylic 186 Matt Brown = entrenching tool handle, Mauser rifle stock, stick grenade 24 handleHumbrol Acrylic 11 Metallic Silver Fox = goggle & binocular lensesTAMIYA XF-16: Flat Aluminium = cook potHumbrol Acrylic 93 Matt Desert Yellow = bread bagVallejo Model Color 48 70898 Dark Sea Blue = collar & shoulder strapsVallejo Model Color 70871 147 Leather Brown = field flaskHumbrol Acrylic 91 Matt Black Green = gas mask caseVallejo Model Color 88 70895 Gunship Green = Zeltbahn (cape)Humbrol Acrylic 9 Gloss Tan = holsterX-10: Gun Metal = Mauser rifle, bayonet, field flask cap, entrenching tool, stick grenade 24 headHumbrol Acrylic 113 Matt Rust = Camouflage pattern on Zeltbahn (cape)Humbrol Acrylic 90 Matt Beige Green = Camouflage pattern on Zeltbahn (cape)Humbrol Acrylic 21 Gloss Black = binoculars, belts, Y straps, cartridge pouchesHumbrol Acrylic 29 Matt Dark Earth = rifle straps British InfantryVallejo Model Color 70921 141 English Uniform = blouse, trousersHumbrol Acrylic 26 Matt Khaki = blouse, trousersVallejo Model Color 70843 133 Cork Brown/70818 136 Red Leather = jerkinVallejo Model Color 70872 149 Chocolate Brown = water bottleHumbrol Acrylic 33 Matt Black = bootsVallejo Model Color 70988 115 Khaki / 0880 113 Khaki Grey = gaiters, packs, bayonet frog, webbing, chin strapHumbrol Acrylic 155 Matt Olive Drab = gaiters, packs, bayonet frog, webbingHumbrol Acrylic 186 Matt Brown = Bayonet handleVallejo Model Color 70864 178 Natural Steel = bayonet hub, water bottle cap, pick axe head, shovelVallejo Panzer Aces 310 Old Wood = tool handlesVallejo Model Color 70890 90 Reflective Green = helmetVallejo Model Color 70801 174 Brass = buckles, cap insigniaVallejo Model Color 70820 4 Off White = chevrons WW2 RAFThe ARMED FORCES Of WORLD WAR II ISBN 0-85613-296-9 Illustration 71RAF Airman 1939Humbrol Acrylic 65 Matt Aircraft Blue = shirtHumbrol Acrylic 33 Matt Black = tie, bootsVallejo Model Color 70843 133 Cork Brown = thermally insulated jacket, trousersVallejo Model Color 70871 147 Leather Brown = flying helmet, glovesVallejo Model Color 70988 115 Khaki = Parachute strapping, packVallejo Model Color 70882 118 Middlestone = Fur liningThe ARMED FORCES Of WORLD WAR II ISBN 0-85613-296-9 Illustration 73 RAF Fighter pilot, Flying Officer 1940Humbrol Acrylic 65 Matt Aircraft Blue = shirtHumbrol Acrylic 33 Matt Black = tie, shoesVallejo Model Color 70964/058 Field Blue = uniformVallejo Model Color 70871 147 Leather Brown = flying helmet, glovesVallejo Model Color 70921 141 English Uniform = straps, parachuteThe ARMED FORCES Of WORLD WAR II ISBN 0-85613-296-9 Illustration 74 RAF Sergeant G. W. Garton, Hurricane fighter pilot, ‘A’ Flight, No. 43 Squadron 1940Humbrol Acrylic 65 Matt Aircraft Blue = shirtHumbrol Acrylic 33 Matt Black = tie, shoesVallejo Model Color 58 70964 Field Blue = uniformHumbrol Acrylic 155 Matt Olive Drab = Mae West lifejacketVallejo Model Color 70898 48 Dark Sea Blue = backing to insigniaVallejo Model Color 70901 63 Pastel Blue = insigniaHumbrol Acrylic 160 German Camouflage Red Brown = flying helmetThe ARMED FORCES Of WORLD WAR II ISBN 0-85613-296-9 Illustration 75 RAF Sergeant Ground Support Crew 1940Humbrol Acrylic 65 Matt Aircraft Blue = shirtHumbrol Acrylic 33 Matt Black = tie, shoesVallejo Model Color 70964/058 Field Blue = uniformVallejo Model Color 70898 48 Dark Sea Blue = backing to insigniaVallejo Model Color 70901 63 Pastel Blue = insigniaThe ARMED FORCES Of WORLD WAR II ISBN 0-85613-296-9 Illustration 76 RAF Leading Aircraftwoman RAF 1940Humbrol Acrylic 65 Matt Aircraft Blue = shirt, stockingsHumbrol Acrylic 33 Matt Black = tie, shoesVallejo Model Color 70964/058 Field Blue = uniformVallejo Model Color 70898 48 Dark Sea Blue = backing to insigniaVallejo Model Color 70901 63 Pastel Blue = insigniaVallejo Model Color 70921 141 English Uniform = haversack & strapVallejo Model Color 67 70961 Sky Blue = stockingsRP-3 (Rocket Projectile 3 inch) 60lb RocketsHumbrol Acrylic 33 Matt Black = shaft, tailHumbrol Acrylic 15 Matt Olive Drab = warheadHumbrol Acrylic 130 Satin White or Vallejo Model Air 71001 White or Vallejo Model Color 4 70820 Offwhite = nose band HTH Link to comment Share on other sites More sharing options...
BillMC Posted November 12, 2020 Share Posted November 12, 2020 Thanks for that Ratch. Link to comment Share on other sites More sharing options...
