Chris-1238288 Posted March 30 Share Posted March 30 HI I recently got the new Prince of Wales and it worked fine for a while, but suddenly it will not move when using my DCC controller DR5000 but will work if I switch to bluetooth though the app has anyone had a similar issue? 1 Link to comment Share on other sites More sharing options...
LTSR_NSE Posted March 30 Share Posted March 30 There is a bug that appears to alter CV19 to an incorrect value (triggering the consist address.) Check CV19 & if incorrect reset it to default - then movement control should be regained. 1 Link to comment Share on other sites More sharing options...
Brew Man Posted March 30 Share Posted March 30 @Chris-1238288 Hold on, which is it? In the thread title you say stopped working on Bluetooth but not on DCC, but in your post you say stopped working on DCC but not on Bluetooth. 1 Link to comment Share on other sites More sharing options...
LTSR_NSE Posted March 30 Share Posted March 30 I’m fairly sure the title is just missing a comma after stopped! Link to comment Share on other sites More sharing options...
Chris-1238288 Posted March 30 Author Share Posted March 30 sorry I cannot edit the title, to confirm it will not move when using my DCC controller DR5000 but will work if I switch to bluetooth though the app Link to comment Share on other sites More sharing options...
Chris-1238288 Posted March 30 Author Share Posted March 30 27 minutes ago, LTSR_NSE said: There is a bug that appears to alter CV19 to an incorrect value (triggering the consist address.) Check CV19 & if incorrect reset it to default - then movement control should be regained. I will have a look , thank you Link to comment Share on other sites More sharing options...
RB51 Posted March 30 Share Posted March 30 Title amended. R- 1 Link to comment Share on other sites More sharing options...
