gilbo2 Posted November 21, 2014 Share Posted November 21, 2014 Railmaster Version 1.58 has been made available. I do not know what the changes are as Release notes.txt has not been updated. The issues I have had since 1.57 are stil present; You may recall that I had assistance in getting my Train-tech “2 Aspect Home” signals to correctly change associated points and vis versa. This concluded with everything working under 1.56 Rev 9 although I did report “4 Point Pulses”. Unfortunately under 1.58 Rev 0 the Train-tech signals are no longer working as they should. When I first click on the signal the point will change but further clicks keep pulsing the point in the same direction however the signal itself does change though. This is the same for all my signals. Also, clicking on the point dots changes the points but do not change the signals anymore. Any suggestions? (Reverting back to 1.56 Rev 9 the signals & points once again work correctly). Other Observations; 1) The “Locomotive CV Settings” window would always remember the values read from the decoder. With 1.57, this information is not remembered i.e. when returning to the Locomotive CV Settings window the values are all blank again. 2) Similar to above, if I open an existing locos CV Settings window that I have never opened in 1.57 previously, I can see the CV values logged from 1.56 but if I close and go back in, the settings are cleared. 3) The resent Hornby releases, e.g. the P2, Santa Express, are not appearing in the loco library? Link to comment Share on other sites More sharing options...
jonworld.trains Posted November 21, 2014 Share Posted November 21, 2014 Railmaster Version 1.58 has been made available. I do not know what the changes are as Release notes.txt has not been updated. The issues I have had since 1.57 are stil present; You may recall that I had assistance in getting my Train-tech “2 Aspect Home” signals to correctly change associated points and vis versa. This concluded with everything working under 1.56 Rev 9 although I did report “4 Point Pulses”. Unfortunately under 1.58 Rev 0 the Train-tech signals are no longer working as they should. When I first click on the signal the point will change but further clicks keep pulsing the point in the same direction however the signal itself does change though. This is the same for all my signals. Also, clicking on the point dots changes the points but do not change the signals anymore. Any suggestions? (Reverting back to 1.56 Rev 9 the signals & points once again work correctly). Other Observations; 1) The “Locomotive CV Settings” window would always remember the values read from the decoder. With 1.57, this information is not remembered i.e. when returning to the Locomotive CV Settings window the values are all blank again. 2) Similar to above, if I open an existing locos CV Settings window that I have never opened in 1.57 previously, I can see the CV values logged from 1.56 but if I close and go back in, the settings are cleared. 3) The resent Hornby releases, e.g. the P2, Santa Express, are not appearing in the loco library? It's early hours yet and i am still testing out this version 1.58. But i think this update is to address problems experienced by some users since the 1.57 release in the last few weeks. Concerning problems with ordering the Pro Pack within Railmaster, Railmaster becoming non-responsine( requiring a Forced Close) and internet access to our PC's from Railmasters order/licensing gateway. Also see Topic titled Colin. It would be nice if RM Support could make a urgent post re this newer update 1.58 to help all those who have been caused difficulties since 1.57 release. Your truly, John Link to comment Share on other sites More sharing options...
PJ_model_trains Posted November 21, 2014 Share Posted November 21, 2014 Version 1.58 states at download options 'minor updates' and refers to 'Release notes' file. Release notes file only includes details up to v1.57? HRMS can you confirm please PJ Link to comment Share on other sites More sharing options...
PJ_model_trains Posted November 21, 2014 Share Posted November 21, 2014 HRMS Since updating to 1.58 my points are not firing? They change in RM on screen but NOT on the layout? Maybe there sould be a roll back built in the software so if a version is installed and something doesn't work we can restore a previous version? Help please. Has anyone else experienced this or other problems? PJ Link to comment Share on other sites More sharing options...
PJ_model_trains Posted November 21, 2014 Share Posted November 21, 2014 Very strange? eLink power light is on but no power to track/signals/etc? This sums up why the points were not firing. Connections from eLink to DCC Bus are sound? I have re-started the PC, I have disconnected USB and power to eLink and plugged back in after 20 seconds? Help please Link to comment Share on other sites More sharing options...
RB51 Posted November 21, 2014 Share Posted November 21, 2014 On my Elite / RM combo all is well. R- Link to comment Share on other sites More sharing options...
PJ_model_trains Posted November 21, 2014 Share Posted November 21, 2014 Sorry guys The cable in the cable connector, connecting the eLink cable to the DCC Bus was faulty. Slight movement knocked the power off yet it all seemed sound. Thanks everyone. Link to comment Share on other sites More sharing options...
Yelrow Posted November 21, 2014 Share Posted November 21, 2014 PJ, mines fine on 1.58, but then of course, i have not , nor see any reason for, a bus. Not into public transport. john Link to comment Share on other sites More sharing options...
PJ_model_trains Posted November 21, 2014 Share Posted November 21, 2014 PJ, mines fine on 1.58, but then of course, i have not , nor see any reason for, a bus. Not into public transport. john Hi John I checked the wires back from the eLink and all seemed sound. The two wires only go from the elink and into a cable connector for the bus. After continued checking as it didn't make sense, I found although the connection into the cable connector was sound the black wire from the eLink to it caused the signals to go on and off. I cut the wire back and made a new connection and it is all sorted. There was abviously a break in the plastic sleeve of the wire about 1" back from the connection to the cable connector. Frustrating but sorted. PJ Link to comment Share on other sites More sharing options...
tony_forward Posted November 21, 2014 Share Posted November 21, 2014 1.58 ??? I've only just downloaded 1.57 ! What does 1.58 do that 1.57 didn't ? Link to comment Share on other sites More sharing options...
RB51 Posted November 21, 2014 Share Posted November 21, 2014 It's minor Tony - Release notes not updated so difficult to tell. R- Link to comment Share on other sites More sharing options...
Yelrow Posted November 21, 2014 Share Posted November 21, 2014 Tells you dont forget to download, 1.57. john Link to comment Share on other sites More sharing options...
96RAF Posted November 21, 2014 Share Posted November 21, 2014 Auto-update to v1.58. All working AOK. Link to comment Share on other sites More sharing options...
hawksdown Posted November 21, 2014 Share Posted November 21, 2014 1.58 ??? I've only just downloaded 1.57 ! What does 1.58 do that 1.57 didn't ? Hi ho Here's another twist chaps Switched on earlier, system 1.57 mode, screen says update 1.58 available, so go for download, situation now is elite not recognised, I have tried several times to reboot, got a message driver missing, quote 'CDC RS232 emulation demo' any ideas would be useful.thanks Link to comment Share on other sites More sharing options...
RB51 Posted November 21, 2014 Share Posted November 21, 2014 Hi Hawksdown - sounds as though you have a corrupted dowload. Have you the Powerpos download link address to get the download again? I'll try to find it for you and re-post here. Found it quicker than I anticipated - paste this into your browser to get the update again http://www.powerpos.com/rail-master/rm_setup.exe R- Link to comment Share on other sites More sharing options...
mcrook62 Posted November 21, 2014 Share Posted November 21, 2014 Hi Have downloaded 1.58 as directed when rai-master detected update and touch wood all signals points working ok funny no release notes on this upgrade train tronic 4 aspect + route indecator working fine Regards mcrook62 Link to comment Share on other sites More sharing options...
RDS Posted November 21, 2014 Share Posted November 21, 2014 ... all seemed sound... Is that TTS sound? Link to comment Share on other sites More sharing options...
Tee1707818014 Posted November 21, 2014 Share Posted November 21, 2014 Updated to 1.58 all seems well except voice control still hit & miss & my signals are still working as train tech colour light decoders even though they are connected to Hornby R8247s Link to comment Share on other sites More sharing options...
Graskie Posted November 22, 2014 Share Posted November 22, 2014 Downloaded 1.58 and it seems to have messed up trying to revise my layout plan. When I superimpose tracks crossing others underneath, all seems OK on the plan, but when I save a new plan, it reverts to the same old one and I get loose bits all over the place, some of them stacked very high on top of many others, which were not placed by me. I'll have another go, but can anyone else check this out on their system and report back? Link to comment Share on other sites More sharing options...
Augustus Caesar Posted November 22, 2014 Share Posted November 22, 2014 Hi PJ... if you wanna roll back the software it shouldn't be that difficult. If you use the direct download link like I have for most of the previous versions from powerpos you should be able to just install it by running the .exe file and it should overwrite what's on your PC. (When you download these just rename it with the current version number). That effectively gives you the rollback and all settings should stay the same as it does when you update the program to a newer version as data files are untouched. I don't think I got the chance to download v1.57 though!!! Hornby caught us with this speedy update! Link to comment Share on other sites More sharing options...
Fishmanoz Posted November 22, 2014 Share Posted November 22, 2014 Hi Hawksdown - sounds as though you have a corrupted dowload. Have you the Powerpos download link address to get the download again? I'll try to find it for you and re-post here. Found it quicker than I anticipated - paste this into your browser to get the update again http://www.powerpos.com/rail-master/rm_setup.exe R- I think sometimes people conclude too quickly that a download/installation is corrupted. The first thing I'd be doing is fault finding the software. In in this instance the stated fault was driver not found, so the first thing I would try would be to update the driver. There are 2 choices here being the Windows driver and the new RM driver. I'd try both in turn if necessary. Then if still a problem, I'd be checking the comm port to make sure it didn't get changed from the previous version. Then if still a problem, I'd be emailing HRMS before thinking about reinstalling. Link to comment Share on other sites More sharing options...
96RAF Posted November 22, 2014 Share Posted November 22, 2014 ...I'd be checking the comm port to make sure it didn't get changed from the previous version. Then if still a problem, I'd be emailing HRMS before thinking about reinstalling. You have a point with the COM port Fishy. My 'new improved' router is unable to lock on an IP address to a particular pc or tablet, so I have to check each time before using any bit of kit or software that needs to know this. No doubt some pcs may adopt this attitude with COM ports. Link to comment Share on other sites More sharing options...
gilbo2 Posted November 22, 2014 Author Share Posted November 22, 2014 Checked the latest download file from PowerPos and release notes.txt now updated; Hornby RailMaster 1.58 Release Notes - November 2014 ============================================= The latest release of RailMaster is a maintenance release. ● +Security update ● +Minor enhancements based on customer feedback ● +Minor improvements to Voice Control I wonder what the "security issue" was? Perhaps explains why 1.58 was issued relatively quickly? Link to comment Share on other sites More sharing options...
gilbo2 Posted November 22, 2014 Author Share Posted November 22, 2014 I think sometimes people conclude too quickly that a download/installation is corrupted. I agree, in my experience a corrupt download usually comes up with a general windows type error as soon as you try to run it, preventing the installation. Link to comment Share on other sites More sharing options...
Augustus Caesar Posted November 22, 2014 Share Posted November 22, 2014 I think sometimes people conclude too quickly that a download/installation is corrupted. I agree, in my experience a corrupt download usually comes up with a general windows type error as soon as you try to run it, preventing the installation. Usually, but not necessarily. If the header code of the file is corrupt it will not run. If data files are corrupt the install will work but upon reading that corrupt data the software could break down. If the error is in a .dll file for example then the install will pop up an error and will not complete. Link to comment Share on other sites More sharing options...
