Rallymatt Posted March 14, 2023 Share Posted March 14, 2023 I am in same position as Bob, 60004 is at ‘the works’ decoder could be en route, no DPD info so not sure at moment. I am glad I have zee Germans keeping things going at High Fell. Link to comment Share on other sites More sharing options...
von Klinkerhoffe Posted March 14, 2023 Share Posted March 14, 2023 Railbob/RallymattSorry to hear your A4’s are in the ‘works’ being repaired. Let’s hope they are returned soon? Link to comment Share on other sites More sharing options...
Rallymatt Posted March 14, 2023 Share Posted March 14, 2023 It will be sorted I am sure 😁 Link to comment Share on other sites More sharing options...
von Klinkerhoffe Posted March 14, 2023 Share Posted March 14, 2023 RallymattIt will, I had to send my A4 (William Whitelaw) back as well. Link to comment Share on other sites More sharing options...
Skelton Junction Posted March 15, 2023 Share Posted March 15, 2023 Link to comment Share on other sites More sharing options...
Dave the Busker Posted March 15, 2023 Share Posted March 15, 2023 Some more track arrived today (Cheers TooTall!), so that's the inner loop connected, the outer loop extended to pretty much where it will be finally, and the branch line started, to connect to the points at the bottom of the picture when Hornby get more in stock. Now that the diamond crossings are available I'll soon be getting the terminus station platforms built over on the right hand side. Link to comment Share on other sites More sharing options...
Baz657 Posted March 15, 2023 Share Posted March 15, 2023 R7337 arrived here too today. I guess I'd better start planning. Link to comment Share on other sites More sharing options...
Artyp Posted March 15, 2023 Share Posted March 15, 2023 My R7337 also arrived today. Link to comment Share on other sites More sharing options...
Rallymatt Posted March 16, 2023 Share Posted March 16, 2023 Bluetooth Next18 sound decoder, looks excellent. and Some double sided station name boards, in paint now 😁 Link to comment Share on other sites More sharing options...
david_watts1 Posted March 16, 2023 Share Posted March 16, 2023 An Acer 10inch tablet to run the app when available, since my phone is an antique. Link to comment Share on other sites More sharing options...
Daedalus Posted March 16, 2023 Share Posted March 16, 2023 Of course I can't guarantee it will work as the app and it's requirement have not been released,Android-X86 will run Android Apps on PC or Laptop hardware either as a separate boot partition or a virtual machine.There are other ways to run Android Apps on X86 architecture OS. Link to comment Share on other sites More sharing options...
david_watts1 Posted March 16, 2023 Share Posted March 16, 2023 @Daedalus If the app doesn't work on a brand new tablet running the latest android software then Hornby have made a huge mistake. Link to comment Share on other sites More sharing options...
Daedalus Posted March 16, 2023 Share Posted March 16, 2023 I was not referring the App not running on a native Android device but running it on X86 hardware which may be an option for people without a phone or tablet as an alternative so they can spend more on their layout. Link to comment Share on other sites More sharing options...
Chris98 Posted March 16, 2023 Share Posted March 16, 2023 I received 1 next 18 decoder, supposed to have been 2. Rang customer services and they were fantastic. Link to comment Share on other sites More sharing options...
Dave the Busker Posted March 17, 2023 Share Posted March 17, 2023 Oxford Diecast Bedford coach, Scammel trailer and fire engine arrived in the post today. Still waiting on a delivery with a 4 track Gaugemaster controller and some Noch passengers which hopefully won't be far away. Link to comment Share on other sites More sharing options...
Rallymatt Posted March 17, 2023 Share Posted March 17, 2023 Dave, is the front wheel ok on the Scammell? Most seem to disappear up inside the nose, easy fix though 😁 Link to comment Share on other sites More sharing options...
Dave the Busker Posted March 17, 2023 Share Posted March 17, 2023 No issue with the wheels on my Scammell glad to say. I've posted some photos on the Hollybush Railway thread. Link to comment Share on other sites More sharing options...
Artyp Posted March 17, 2023 Share Posted March 17, 2023 How do you fix the Scammell wheel? Link to comment Share on other sites More sharing options...
Rallymatt Posted March 17, 2023 Share Posted March 17, 2023 Pop the cab off, clear tab in chassis, it’s quite tight. The axle for front wheel is meant to be located by the interior moulding. Pop wheel and axle into place, dab of superglue on the interior glue to the chassis. That will securely locate the axle. Then when you clip the cab back on it doesn’t dislodge the interior and let axle jump out of its location. Link to comment Share on other sites More sharing options...
von Klinkerhoffe Posted March 18, 2023 Share Posted March 18, 2023 HiJust had some track delivered including TT8013 Uncoupling Ramp Assembly.This will fit to TT8012 Half Straight Track (83mm).Instructions:Contains three separate parts which are not difficult to assemble. Not sure this can be servo operated as the lever has no hole just a peg to operate it manually and the lever is only about 1mm wide? This may be possible with some ingenuity? Link to comment Share on other sites More sharing options...
number1 Posted March 18, 2023 Share Posted March 18, 2023 Received today, Track pack 4 & 5 plus decoupler, still waiting for Track pack 2 & 3, which shows as dispatched, funny thing is the 3 things I had today came in 3 separate boxes, what a waste of packaging, come on Hornby put it all in the same parcel! Link to comment Share on other sites More sharing options...
Herbie Posted March 18, 2023 Share Posted March 18, 2023 Received two radius 2 curve pieces yesterday.Unfortunately I'd ordered two Track Pack 2s...Return arranged. Link to comment Share on other sites More sharing options...
Clement Matchett Posted March 18, 2023 Share Posted March 18, 2023 I got my Toad.Or with apologies to Lewis Carroll, Towed…’We called it Toad because it is towed.” Link to comment Share on other sites More sharing options...
Artyp Posted March 18, 2023 Share Posted March 18, 2023 Thanks Rallymatt I'll have a go. Link to comment Share on other sites More sharing options...
Artyp Posted March 18, 2023 Share Posted March 18, 2023 Brake van & three tankers. Link to comment Share on other sites More sharing options...
